Grille Interchangeable?
Discussion in '3rd Gen Tundras (2022+)' started by sinisterj, Dec 31, 2021.
  1. Apr 8, 2024 at 2:39 PM
    #421
    SATX-TUNDRA
    SATX-TUNDRA New Member
    2024 Toyota Tundra Limited 4x4
    @angrygiraffe, I appreciate the info! I assumed it required a separate bracket but all the info I could find was changing over to the heritage grille.
    @PBNB, I'd take you up on that offer but that would be a heck of a drive.
  2. Apr 8, 2024 at 3:27 PM
    #422
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    What were the "Waterproof Wire connectors:" used for?
  3. Apr 9, 2024 at 5:34 AM
    #423
    angrygiraffe
    angrygiraffe New Member
    '22 SR5 CrewCab 5.5'
    I wanted to be able to disconnect each individual light, or the whole harness quickly just in case a single light failed or toyota gave me warranty trouble for adding this. So the waterproof wire connectors are in-line just before each light and where the harness gets to the front where it is visible. Just like you have a disconnect on a fog light or headlight. These aren't required but makes swapping things out in the future easier because I all my wiring is pretty hidden.
    dccrens[QUOTED] likes this.
  4. Apr 9, 2024 at 5:13 PM
    #424
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    I’m looking to do the exact same swap. How long did it take?
    What about the grill shutters?
  5. Apr 10, 2024 at 5:50 AM
    #425
    angrygiraffe
    Took me around 3 hours to do. Getting everything apart was pretty straight forward, I watched a few youtube videos that show where all the clips are to pop things off. Once you have the whole front grill/bumper assembly off, I would recommend taking pictures before you remove all the screws. There are a ton of them and it wasn't super obvious (to me at least) where they all went without pictures. Also, a second pair of hands would have saved me a lot of time on re-assembly. Putting the new grill insert in while holding this big flopping plastic thing wasn't easy by myself. Lots of clips all that have to be perfectly aligned so you don't break them off.
    Once you take the whole grill/bumper assembly of, the shutters are just screwed to the back of it. That was pretty simple, just ~4 screws holding it on.
    arrampico[QUOTED] likes this.
  6. Apr 10, 2024 at 10:37 AM
    #426
    arrampico
    thanks for the tips!
    and videos you recommend specifically?
  7. Apr 10, 2024 at 10:52 AM
    #427
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Just adding my own recommendation but this one helped me tremendously and was the easiest to follow stop by step
  8. Apr 11, 2024 at 5:38 AM
    #428
    arrampico
    Thanks! thats a great video
  9. Apr 11, 2024 at 2:58 PM
    #429
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I could have sworn I saw people putting mesh behind the pro grill. What are people using, can’t seem to find the post.
  10. Apr 21, 2024 at 4:47 PM
    #430
    Pgain88
    Pgain88 Just Keep Truckin
    Valparaiso Indiana (Chicago)
    2024 Tundra
    Metal pet resistant window/door screen. It's useless for what people want it for. If a rock is coming at you at 70+ mph it will go through that mesh too.
  11. Apr 22, 2024 at 7:49 PM
    #431
    SATX-TUNDRA
    @machd08, do you have the part number for your grille? I've found a couple different ones for the TRD Offroad/Sport grille, with one being more of a matte finish and the other being a glossy finish. I'm curious about your setup because mine also has the more shinny TUNDRA on the bumper compared to a lot of others that are more matted.
  12. Aug 22, 2024 at 7:31 AM
    #432
    nmk_61802
    nmk_61802 New Member
    Anyone got an illustrated guide to all the various grilles? I have a limited with a gray version of the SR5 grille. I am considering the purchase of a TRD OR grille. I think the part number I need is 53101-0C500, which should be a matte black grille. I am mainly curious if the TRD OR grille has other color variants that I should consider.
  13. Aug 22, 2024 at 10:17 AM
    #433
    nmk_61802
    I may have answered my own question:
    It looks like with the matte black above they also have 53101-0C210 which should be a gray variant. I think they also have a gloss black one, but couldn't find that part number.
  14. Aug 26, 2024 at 6:32 AM
    #434
    SATX-TUNDRA
    @nmk_61802 When I was searching the different TRD OR grilles, I was in the same boat as you. I found that they have a matte black one or a gloss grey one, but I did not find a gloss black one. I believe my truck should have come with the grey version of the SR5 grille, but since I have the nightshade package mine came with the black version. I ended going with the matte black TRD OR grille and I'm glad I went with that one.
  15. Aug 26, 2024 at 9:38 AM
    #435
    nmk_61802
    Thanks for the reply, it appears like we have same year/ trim of truck. I too assumed that my truck would have had the gray grille if it would have been ordered as a TRD. I went ahead and ordered a matte black grille over the weekend to simplify the color scheme on the front. With the removal of the factor gray limited grille, and plans to get color matched flares (vs the dark gray), I should get things to a more unified color.
  16. Aug 26, 2024 at 10:43 AM
    #436
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Were the spacers needed to mount the air dam on the heritage grill from earlier in the thread needed for the Toyota Factory TRD grills?
  17. Aug 26, 2024 at 12:55 PM
    #437
    SATX-TUNDRA
    @Wtundra2023 I'm not sure what spacers are needed for the TRD Pro grille, if any, but I did not need any spacers going from the SR5 type grille to the TRD OR grille.
  18. Nov 28, 2024 at 4:08 AM
    #438
    MTwiford
    MTwiford The second mouse always gets the cheese
    2025 Platinum TRD Magnetic Gray
    I have tried searching for this but almost everything I have seen is TRD pro related.
    I have a platinum with the TRD Off Road package. I would like to remove the off road grille and install the regular platinum grille. Does anyone know if the camera bracket is compatible? Or if not, where I can get a bracket to fit the platinum grille?
