Grille Interchangeable?
Discussion in '3rd Gen Tundras (2022+)' started by sinisterj, Dec 31, 2021.
  1. Nov 15, 2022 at 7:21 AM
    #361
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    its just as piss poor as the oem light bar output.
  2. Nov 15, 2022 at 7:23 AM
    #362
    eddiefromcali
    Eddie
    100% Stock
    Top: Low Beam Only
    Middle: Low beam and bar
    Bottom: High and bar
    PERRY1060 and Durtywrench like this.
  3. Nov 15, 2022 at 7:29 AM
    #363
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    Thank you, that’s pretty good.
    Do you have one with just the light bar on? Everything else off or does the ECU not allow that?
  4. Nov 15, 2022 at 7:32 AM
    #364
    eddiefromcali
    Eddie
    100% Stock
    i can get one. The bar is wired independently from the ECU...unlike the Pro, I dont have to have my high beams on for the bar to work. Toyota really screwed the pooch on that one. I get that its not a fog light, but it should be available in Low beam as well.
    ryanwgregg likes this.
  5. Nov 15, 2022 at 7:35 AM
    #365
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    sweet! Thanks
  6. Nov 15, 2022 at 8:26 AM
    #366
    Breathing Borla
    AZ
    they dont want people using it on the road with the low beams blinding everyone is my guess.
  7. Nov 15, 2022 at 8:34 AM
    #367
    eddiefromcali
    Eddie
    100% Stock
    you can still blind people with low beam and the bar. Toyota is just being an overprotective nanny, imo.
  8. Nov 15, 2022 at 8:40 AM
    #368
    eddiefromcali
    Eddie
    100% Stock
    i get that, thats the first light I've seen thats limited to high beam operation only. Any auxiliary lights Ive seen have been limited to low beam operation, not high. Luckily this is an easy fix, even for the oem bar.
  9. Nov 15, 2022 at 9:27 AM
    #369
    Breathing Borla
    AZ
    that was my point, unless Im mistaken toyota doesn't let you use the bar with low beams, likely because they are not design for on road use with no cut off
  10. Nov 15, 2022 at 9:57 AM
    #370
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    Realistically how many lumens are these ebay lights?
  11. Dec 17, 2022 at 8:01 AM
    #371
    sjeoid
    sjeoid New Member
    2022 Limited TRD Off-road
    I have the same question. I have a TRD Off road grill. So if I install the TRD Pro grill would I need a different bracket for the camera? Or not? Thanks!
    Yaboy likes this.
  12. Dec 17, 2022 at 11:58 AM
    #372
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    Yes you'll need a new camera bracket. Hit me up if you would like one of mine!
  13. Dec 17, 2022 at 1:14 PM
    #373
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    I can barely tell that they’re on whenever my headlights are on, so not very bright lol
  14. Dec 17, 2022 at 2:06 PM
    #374
    sjeoid
    sjeoid New Member
    Can you explain why I would need it? Both the TRD Offroad limited and TRD Pro have cameras.
  15. Dec 17, 2022 at 2:08 PM
    #375
    roboots21
  16. Dec 17, 2022 at 2:17 PM
    #376
    sjeoid
    sjeoid New Member
    Thanks! That explains it. Does the camera have to be recalibrated afterwards? How much is your mount?
  17. Dec 17, 2022 at 2:20 PM
    #377
    roboots21
    It will likely be off slightly in alignment of the rest of the cameras, and mine is $25 shipped.
  18. Dec 21, 2022 at 8:15 PM
    trd1993
    trd1993 New Member
    What was the length of the spacers? Inch and a quarter?
  19. Jan 29, 2023 at 1:07 PM
    #379
    sjeoid
    sjeoid New Member
    How many hours did it take to take off the surround and grill and re-install it?
  20. Mar 15, 2023 at 10:13 AM
    #380
    rboyer224
    rboyer224 New Member
    Robert
    2022 SR5 TRD Off Road Army Green
    None Yet
    Hello. Has anyone on here ordered a grill or anything from the webiste www.goodmatchup.com? They seem to have the TRD pro grill with lights in stock for a reasonable price but not sure if they are legit or not. Thank you.
  21. Mar 16, 2023 at 11:42 AM
    #381
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    the very first image when the website opens should have let you known that their stuff isn't genuine, hmm arrival..
    those are the same grilles / marker lights and lightbar that can be found all over ebay
  22. Mar 16, 2023 at 1:13 PM
    #382
    rboyer224
    Robert
    None Yet
    Yeah, I have no doubt it's not genuine Toyota, most on the internet is not, unless you are buying from a legit Toyota dealership. I'm more wondering if the site is legit? According to this forum, even the China made grills fit just fine and tend to actually be available and affordable.
  23. May 25, 2023 at 10:56 PM
    #383
    BaronGianni
    BaronGianni New Member
    Sir can you share pictures of how you’ve got the light bar wired from the light bar to battery to the switch please?
  24. May 25, 2023 at 10:57 PM
    #384
    BaronGianni
  25. Aug 29, 2023 at 2:08 PM
    #385
    Black22tundra
    Black22tundra New Member
    2022 black tundra sr5
    6" ready lift 35" tires
    I am wanting to swap out my SR5 grill for the TRD grill only to find out after calling the dealership I have to have a vin number associated to a TRD to order a TRD grill. Is this true?
  26. Aug 29, 2023 at 2:11 PM
    #386
    Black22tundra
    If the SR5 grill can't be swapped out for the TRD, do you guys have any reco's for installing a light bar in the SR5 grill in the DFW area?
  27. Aug 29, 2023 at 4:52 PM
    #387
    TexTunToy
    TexTunToy New Member
    2023 Tundra 1794 TRD O/R
    Sequoia front end, billet bed tie downs, bed floor tie downs track, BAK Revolver X4S, Tufskinz inserts
    No, this is not true. They may not guarantee the fit, and decline a refund or charge a restock fee if it “doesn’t fit” and you wanted to return it, but they should still sell it to you. If they actually do refuse to sell it to you (their loss?) there are dozens and dozens of dealerships online that will!
  28. Aug 29, 2023 at 5:46 PM
    #388
    Black22tundra
    Yeah the parts dept at Vandergriff Toyota in Arlington seem to be very lazy. He acted like I was putting him out when I called to ask about it. Thanks for the info! Ill try a few other places unless someone else here can point me in the right direction
  29. Aug 29, 2023 at 6:11 PM
    #389
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I got my Heritage grille from Sparks! I just didn’t input a serial number.
    Are you looking for the TRD grille or the TRD Pro grille (Heritage)?
    They are all interchangeable. The camera mounts can be different if you have the front camera in the grille. Just make sure you order one with or without to suit your needs.
    You might need a mount as well as well and you can get one in the marketplace on this site.
  30. Aug 29, 2023 at 6:32 PM
    #390
    Black22tundra
    I found the one I was looking for on eBay actually with the light inserts, is this the Heritage grille? From what I understand this should fit no problem.
    Yaboy likes this.
