Grill not lining up after headlight removal!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pepperonipizzzza, Jun 14, 2020.
  1. Jun 14, 2020 at 4:06 PM
    Pepperonipizzzza
    Pepperonipizzzza [OP] New Member
    Anyone else have had this problem? How did you fix it? I’ve taken everything off and put it back on numerous times and the same thing has happened! Help! C5B61816-A3B4-4CFA-9FC1-AEA3E9F5F88E.jpg391CA4E8-7AB4-4CCB-B036-B68AE237A7CA.jpg
  2. Jun 14, 2020 at 4:11 PM
    Recheck the clips, maybe they are not sitting right.
    Tundyfundy likes this.
  3. Jun 14, 2020 at 4:23 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Check to see if the headlight is installed correctly. It has to clip on the bottom near the grill to a metal piece.
  4. Jun 14, 2020 at 4:28 PM
    Pepperonipizzzza
    They’re both in, everything lines up perfectly except the holes on top of the grill to put the screws in 7BAA78FF-53D4-4885-AC67-2FA4FC3901B1.jpg
    BamaMan44 likes this.
  5. Jun 14, 2020 at 5:11 PM
    Pepperonipizzzza
    Just noticed that I bought the truck like this and never noticed :rolleyes: guess the grill came warped
    Black Wolf likes this.
  6. Jun 14, 2020 at 6:10 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    From here, it looks like your hood is not aligned.
    Pepperonipizzzza[OP] likes this.
  7. Jun 14, 2020 at 6:21 PM
    Pepperonipizzzza
    I bought the truck only a few weeks ago... how does one realign the hood?
  8. Jun 14, 2020 at 6:29 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    I have never done it. But there are usually rubber bumpers along the front near the corners for up and down adjustments. For front to back adjustments, I suppose you would need to loosen the hood to hinge bolts.
  9. Jun 14, 2020 at 6:35 PM
    Pepperonipizzzza
    Man I thought I was losing my damn mind with this grill I even ordered a new pro grill from spark parts... I’m going to try to adjust it now
    Ely010606 likes this.
  10. Jun 14, 2020 at 6:45 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Curious if you got it aligned with the grill
  11. Jun 14, 2020 at 7:00 PM
    Pepperonipizzzza
    Adjusted those rubber stoppers a bit and it did help but yeah the hood is unaligned to the right a bit, I’m going to tell them at my first oil change and see if they fix it 569F4BF6-59BC-4658-9419-1002B4C06461.jpg
  12. Jun 15, 2020 at 6:41 PM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    I see it but it looks good overall!
  13. Jun 15, 2020 at 7:31 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Definitely diggin that grill. Looks sweet!
  14. Jun 16, 2020 at 5:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Adjusting the rubber bumpers will only change the height of the hood at the grille when the hood is latched closed. Side gaps on a properly adjusted hood should be approximately equal width from the windshield to grille, the same from one fender to the other, and the hood surface flush with the tops of the fenders. Your hood gaps actually look good. Beyond that, adjusting the bumpers is going to compromise the hood fit slightly, but may be worth it for improvement elsewhere.
    Your gaps are different at the tops of the headlights (see below). I would suspect one of the headlights is not seated properly as mentioned earlier. My gaps above the headlights are equal and about 3/8" on both sides. My experience was the that bottom of the headlight needs to be installed first (not easy to properly engage the bottom tab), then the tabs on the top of the headlight will very tightly snap over the screw hole dowels when the headlight is rotated into position. During the rotation, you'll be fighting the harnesses behind which are determined to get in the way. As I recall, there is no interference between headlights and grille, so the headlights should not be affecting grille fit.
    Toyota designs these headlight/grille parts to snap together with precision like Legos, and they train their people how to do it properly on the assembly line. There is virtually no opportunity for adjustment after installation, and the only way it wouldn't be perfect after proper installation is that the steel underneath is wrong. If you can find no reason for the difference in headlight gaps, and this is a new truck, you may want to investigate the possibility that the front end has been previously repaired.
  15. Jun 16, 2020 at 7:17 PM
    Pepperonipizzzza
    I was started to suspect myself that there could be front end damage, I was scrolling through my photos and noticed that when they first brought the truck up I snapped a pic and the grill is crooked 60F78211-DF96-4155-9FEC-84AA2F624EC3.jpg
  16. Jun 16, 2020 at 7:23 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Hopefully no front end damage, I would go to your dealership asap and point out, dont wait any longer..
  17. Jun 16, 2020 at 8:23 PM
    BamaMan44
    Andre
    Tucson
    Yeah, something definitely looks off in that picture.
  18. Jun 16, 2020 at 8:32 PM
    Pepperonipizzzza
    I’m looking at some other peoples tundras and some do have this problem, I’m thinking from the factory they place the hood on not lined up properly
    BamaMan44[QUOTED] likes this.
  19. Jun 16, 2020 at 9:11 PM
    BamaMan44
    Andre
    Tucson
    Hopefully it's an easy fix. Good luck brother!
  20. Oct 6, 2021 at 6:14 AM
    Sweet Action
    Sweet Action New Member
    Missouri
    2021 Cement CM SR5
    Did you ever figure this out? I have the same issue.
