Greetings from Winchester, VA. New to the site
Discussion in 'New Member Introductions' started by Tundra2001, Sep 25, 2018.
  1. Sep 25, 2018 at 1:57 PM
    Tundra2001
    Tundra2001 [OP] 2001 Tundra SR5
    Winchester
    2001 Toyota Tundra TRD, 160,000 miles
    Hello to all. I have a 2001 dark green Tundra TRD. I bought it about 4 years ago with 87,000 miles and I currently have close to 150,000 on it. It has been one of the better vehicles I have ever owned and definitely the best truck I have ever owned. I hope to gain some insights from this site as the miles roll up and different systems start to need attention. I have had two instances in which the truck wasn't running 100% and no "check engine light" was thrown to try to diagnose the issue. The first time it happened, the truck received a major tune-up at about the 95,000 mile mark. It began to miss while both idling and in Drive and under acceleration, but no CEL. Fortunately, the repair shop said that they had run into issues with new, replacement spark plugs that were not firing correctly. They replaced all of spark plugs a second time and the problem went away. More recently, the truck has started buck and lug under acceleration, but only intermittently. Again, no CEL. I am hoping people on this site who have had similar experiences will steer me in the right direction when trying to figure out what to do next. The repair shop apparently lives and dies by the CEL, so if there isn't one, they just roll their eyes because it could be any one of many systems causing the problem but not throwing a code.
  2. Sep 25, 2018 at 2:01 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA...:)
    Tundra2001[OP] likes this.
  3. Sep 25, 2018 at 2:03 PM
    Welcome from NY.
  4. Sep 25, 2018 at 2:07 PM
    Marty McFly
    Morty McBoonJug
    Welcome from SoCal sir :hattip:
    Let’s see the ride :worthless:
  5. Sep 25, 2018 at 2:17 PM
    Professional Hand Model
    Hand Protectors
    I’ve had my 2002 since new and she sits at 158k miles. Never had a breakdown problem except for a bad ignition coil in which I still limped back.
    Stealerships/service stations do the basics.
    Here are some preventative maintenance things that are easy for DIY (that dealerships over look?). Clean your throttle body/tighten throttle cable and clean your MAF Sensor. Change your transmission fluid. Clean your PCV valve and its port in which it sits. Change your gas filter.
    Try better quality gas. Not sure what you use? Maybe run some fuel injector cleaner through a tankfull.
  6. Sep 25, 2018 at 2:19 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  7. Sep 25, 2018 at 2:22 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  8. Sep 25, 2018 at 2:22 PM
    Welcome
  9. Sep 25, 2018 at 2:35 PM
    Welcome from Texas
  10. Sep 25, 2018 at 2:40 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Welcome from OK
  11. Sep 25, 2018 at 2:46 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  12. Sep 25, 2018 at 2:51 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiyas! Welcome from SoCalif!
    :worthless:
  13. Sep 25, 2018 at 6:48 PM
    Welcome from Ohio!
  14. Sep 25, 2018 at 7:20 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  15. Sep 26, 2018 at 1:06 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    Welcome from Smithfield, VA!
  16. Sep 26, 2018 at 6:01 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  17. Sep 26, 2018 at 6:08 AM
    Welcome from CO!
  18. Sep 26, 2018 at 7:40 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Kinda sounds like fuel delivery. I'd start by checking the filter.
  19. Sep 26, 2018 at 7:40 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  20. Sep 26, 2018 at 8:13 AM
    Notachickmagnet
    Notachickmagnet New Member
    Welcome from Ohio!
