Greetings from Santa Barbara County, CA!
Discussion in 'New Member Introductions' started by tunyota, May 3, 2020.
  1. May 3, 2020 at 9:21 PM
    tunyota
    tunyota [OP] Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    We recently purchased a one-owner Phantom Gray 2006 Regular Cab Long Bed Tundra V8 4.7L 4WD with 224,000 miles for $4500 after negotiations. Also, included a ProTops High Rise Camper Shell. At 204K miles, the radiator, serpentine belt, timing belt, water pump, head gasket, and fluids were replaced. Current tires are Hankook Dynapro ATM (RF10) 265/70R16 112 T.
    The previous owner was a retiring firefighter who took it on annual surf trips along the Pacific coast and has since upgraded to a new Mercedes Sprinter van.
    So far I have performed the following:
    I plan to inspect the brakes and suspension components later and service as needed. I will potentially install Bilstein 5100 or 4600 series shock absorbers.
    We will eventually design and build out some drawers with additional storage/organization for camping and recreational activities.
    Please do not hesitate to let me know if you have any questions about the truck or work that I have done/plan to do.
    I look forward to participating in the community forums/discussions and learning from the experiences of others!
  2. May 3, 2020 at 9:35 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada, and congrats.
    tunyota[OP] likes this.
  3. May 3, 2020 at 9:36 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    how are the sylvania LEDs inside the cab. i wasnt impressed with my corolla. they bright in the tundra?
    Also, welcome from northwest indiana from another RCLB owner (use to be phantom grey. not anymore)
  4. May 3, 2020 at 9:38 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
    Nice write up complete with pics ~ good job !
    tunyota[OP] and Rica25 like this.
  5. May 3, 2020 at 10:06 PM
    tunyota
    I opted to go with LEDs to save on energy consumption and make it feel more updated/modern. I went with the ZEVOs over their standard LEDs as they are double the wattage as to ensure sufficient lumen output. They are considerably more expensive compare to standard incandescent bulbs, but I feel they were worth the investment.
    Thanks, Yardbird! Nice RCLB. I plan to upload additional photos this week once I get a chance to detail it since doing all the work.
    YardBird[QUOTED] likes this.
  6. May 3, 2020 at 10:07 PM
    empty_lord
    05 rollover special
    care to grab some night photos? i have the zevo in the corolla. but its from when zevo first came out. i wouldnt doubt they've updated them since then
    tunyota[QUOTED][OP] likes this.
  7. May 3, 2020 at 10:35 PM
    tunyota
    Coming right up!
    *Interior door handle bezels are not installed in these photos as I am currently working on replacing the door speakers.
  8. May 3, 2020 at 10:38 PM
    empty_lord
    05 rollover special
    awesome! thank you.
    also is your truck a work spec model or not? dont think ive ever seen a 05-06 v8 reg cab with power options and the center overhead. i couldnt even find the part number for the headliner before i modified mine. i figured i had a rare bird now that ive added all that! lol
    not to mention you have a grey interior, not tan.. must be rare. if i had grey i wouldnt of blacked my interior out!
  9. May 3, 2020 at 10:58 PM
    tunyota
    You're welcome! I am not sure what the factory options or lack thereof define the work spec model. I entered the VIN into Toyota's website and it generated a PDF that provides information on the truck. See below. The previous owner bought it knowing he would be taking surf trips to Baja which explains the factory-installed vinyl flooring and 4WD options. The regular cab long beds are rather rare birds. I was pretty set on the double cab Limited w/ sunroof, but this one grew on me after a couple of weeks and turned out to be a much better "investment".
    YardBird likes this.
  10. May 3, 2020 at 11:08 PM
    empty_lord
    05 rollover special
    interesting. this is mine, All regular cabs of the 1st gen era were vinyl floor. never any option for carpet. Your interior color is the same as mine. must just be the lighting. but according to your interior color code youve got fawn (tanish)
    anyways yours trucks almost a twin to mine. feel free to ask questions.. ive added quite a bit of things to mine and have had it torn down to almost a shell
  11. May 3, 2020 at 11:38 PM
    tunyota
    Thanks for sharing and clarifying! You must be proud of yours as I see you have put a lot of time and energy into restoring it. Kudos!
    Are you still running the factory alternator? I am considering replacing mine as preventative maintenance and upgrading to a 130A model - Denso (210-1065)
    Are you running the Bilstein 5100s? I am considering installing new shock absorbs and springs so any recommendations are appreciated.
  12. May 3, 2020 at 11:42 PM
    empty_lord
    05 rollover special
    I have Billie 5100s with arb 885 springs and energy suspension isolators (so the springs fit) and I have 5100s rear with an icon 3 leaf aal. Lifted 2” up front and the rears about a 1/2” taller to keep some rake. Camburg upper control arms up front too. Thing drives like a dream with this setup.
    Still on the stock alternator. But I have a sequoia 150 amp I’ll install eventually. (If your going to upgrade may as well go with the 150)
  13. May 3, 2020 at 11:44 PM
    empty_lord
    05 rollover special
    rear
    front
    and how it sits
    porkitt and tunyota[OP] like this.
  14. May 4, 2020 at 12:05 AM
    tunyota
    Nice ride/setup! I was originally thinking it would be nice to have my camper painted to match the truck, but the white actually makes sense for staying cooler under the sun while camping, etc.
    I was considering going with the 4600s but might end up going with the 5100s. I don't want to regret not paying the extra $$ and getting the 5100s instead.
    I forget the Sequoia is essentially the exact same platform when searching for parts. I will certainly have to go with the 150A option then when it comes time! Thanks for the recommendation!
    empty_lord[QUOTED] likes this.
  15. May 4, 2020 at 12:06 AM
    empty_lord
    05 rollover special
    i bought the cap for 150 if i remember right. it was phantom grey, but body shop that painted the truck told me 200 bucks and they'll do the cap. so i decided to paint it
  16. May 4, 2020 at 11:19 AM
    Welcome
  17. May 4, 2020 at 11:25 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from Santa Clarita, CA
  18. May 4, 2020 at 11:50 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  19. May 4, 2020 at 6:59 PM
    Welcome from Ohio
  20. May 4, 2020 at 7:03 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Welcome from Ventura
  21. May 4, 2020 at 7:03 PM
    Hillbilly Taz
    Hillbilly Taz New Member
    Glenn
    AL
    2011 Tundra SR5 DC, Silver Sky, 4.6 L V8
    Westin Steps, Tonneau Cover, Vent Visors, Go Rhino Dominator Step, Husky X-act mats
    Howdy from Alabama.
  22. May 6, 2020 at 11:29 AM
    yellowrider
    yellowrider New Member
    San Diego, CA
    2016 White Tundra DC TRD 4x4
    Bilstein 5100s, Tuff Country AAL
    Truck looks super clean for its age! Welcome
  23. Jun 20, 2020 at 10:39 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Welcome! I was looking at that truck a month or so ago on CL, almost made the trip home to pick it up but settled for a 05 AC 4x4 in ND where I work. I'm happy with mine but was just looking at Toyota owners and saw a service ticket with " owner states noise in front end****needs new front diff" so naturally I'm flipping out lol but have not heard any noise in 4x4 or experienced any problems going in and out of 4x...that's a sweet ride and I'm glad I bumped into your post because I'm going to model my maintenance off your list.
  24. Oct 18, 2021 at 9:28 PM
    tunyota
    Finally getting around to posting the current list of parts I have installed since ownership. I wonder how much more it would have cost me to have a mechanic install some of these parts. Thank goodness I am mechanically inclined!
  25. Oct 19, 2021 at 4:14 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You are making this classic into one VERY nice truck!
  26. Oct 19, 2021 at 6:56 AM
    Parksareforever
    Parksareforever New Member
    2020 TRD DC 4x4
    Welcome from San Diego. Looks like ya got a great start on your project.
  27. Oct 25, 2021 at 7:01 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
