Greetings from Northern California!
Discussion in 'New Member Introductions' started by mobdez123, Apr 10, 2017.
  1. Apr 10, 2017 at 2:01 PM
    mobdez123
    mobdez123 [OP] New Member
    2002 Toyota Tundra 4x4
    King 2.5 front coil overs
    Hey yall! i picked up a 2002 Toyota Tundra 4x4 with 106XXX miles on it about a year ago in Oregon. I noticed shortly after I purchased it as i was driving back and forth up into the mountains that often times there would be a lagging thud between only the first couple gears.. its has started to get a little worse now at 122 XXX miles and it is annoying because i feel it takes away from the acceleration as i dont want to punch threw the first gears..
    i read on some forums a while back that the 2002 tundra transmissions have been known to go out early and some people were throwing in 2003 or 2004 trannys to help resolve this issue.
    Any advice on what i could do or where i can find a solution to this issue?
    Also i have recently installed King 2.5 coil overs up front as the stock ones were completely blown and i had to drive up the state of Calinornia after new years.. I didnt realize these shocks wouldn't support a long travel kit so if anyone is interested in purchasing them or trading for longer travel King or Fox shocks, let me know!! They are in perfect condition, only about 1,000 miles on them never raced or off roaded with them.
    T-Rex266 likes this.
  2. Apr 10, 2017 at 2:23 PM
    Welcome from CO!
    @Mike is our first gen resident expert
  3. Apr 10, 2017 at 2:26 PM
    Bienvenidos de Tejas!...no pics it doesn't exist o_O
    GNTundra likes this.
  4. Apr 10, 2017 at 2:30 PM
    mobdez123
    No i have not doing anything for fuel yet..
    What do you recommend?
    would that fix a tranny slip issue?
  5. Apr 10, 2017 at 2:31 PM
    mobdez123
    Pics of the truck? or the coil overs?
  6. Apr 10, 2017 at 2:32 PM
    Mike Tread lightly.
    south carolina
    You are correct.. the 2000 to 2002 transmission where bad. Toyota beefed up the transmission in 2003 to fix problems from lagging to reverse blowing out totally.
    Before going to extreme drop the tranny oil and filter replace both see if the transmission comes back. I will assume you have checked the oil and it's red in color and no burning smell..
    Edit what price for the king's?
  7. Apr 10, 2017 at 2:45 PM
    mobdez123
    haven't calculated it recently... i will start to though just in case.. I did a full tranny service..
  8. Apr 10, 2017 at 2:48 PM
    mobdez123
    already have done full tranny service ! So im thinking i need to find a 03 or 04 swap... Kings are 1000
  9. Apr 10, 2017 at 2:50 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome to the forum from Las Vegas!!
  10. Apr 10, 2017 at 3:10 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO!
  11. Apr 10, 2017 at 3:15 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    welcome from NC
  12. Apr 10, 2017 at 3:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    welcome bud
  13. Apr 10, 2017 at 4:25 PM
    Mike Tread lightly.
    south carolina
    If service didn't help unfortunately swap would be needed. If you are looking at keeping the truck have the doner transmission rebuild or get a remanufactured transmission. As I tell people don't just goto the junk yard and pick one up you are more likely to do the job twice not once.
  14. Apr 10, 2017 at 5:08 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome!
  15. Apr 10, 2017 at 5:38 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome from :canada:
  16. Apr 10, 2017 at 6:35 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    Welcome from Texas!
  17. Apr 10, 2017 at 6:58 PM
    mobdez123
    should i get remanufactured 03 or 04 from factory and installed?? will that be my best most reliable option and provide me with the proper acceleration and performance i am looking for?
    thanks for the advice i really appreciate it !
  18. Apr 10, 2017 at 7:01 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  19. Apr 10, 2017 at 7:05 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Welcome from the southern part of your state !
  20. Apr 10, 2017 at 8:53 PM
    Mike Tread lightly.
    south carolina
    If you can get a 03 reman that would be your best option for you. 03+ has stronger internals. Mine is a 03 and the transmission is very smooth even under some fast moving or towing.
    On the flip side I will say this. If you can get someone to beef up the tranny you have now that's other option. Alot depends on the scope of the tech they have, and what he can do, and what he has access too in parts.
    While you are in there don't forget about the torque converter. Make sure it's still good not leaking or locked up.
    While the transmission is also out perfect time to inspect rear crank seals and inspect flywheel for anything wrong also.
    My motto to it right the first time.
  21. Apr 10, 2017 at 10:58 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Welcome from the Northeast Bay!
