Grease Maintenance Advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tsm503, Oct 5, 2022.
  1. Oct 5, 2022 at 9:53 AM
    Tsm503
    Tsm503 [OP] Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Hello everyone, I’m no mechanic but I’m looking to take my truck maintenance to the next level. I have a 2021 2wd DC, I’m familiar enough to change/flush all the fluids in these trucks. But like I mentioned, I want the take the maintenance a little further.
    What all needs to be greased on these trucks?
    What type of grease for each component?
    How often should each component be greased?
    Thanks for your input
  2. Oct 5, 2022 at 10:16 AM
    Retired...finally
    I could be wrong but I don't think the 21 had grease fittings. I didn't see any under mine.
    AZBoatHauler likes this.
  3. Oct 5, 2022 at 10:32 AM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    They phased them out around 2018. Another reason 2017 is the best MY ever. :muscleflexing:
  4. Oct 5, 2022 at 10:37 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The owners bunghole due to no transmission cooler.
    Anything that has KY on it should work.
    Anytime, guy.
  5. Oct 5, 2022 at 10:45 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  6. Oct 5, 2022 at 10:45 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep #2016life
  7. Oct 5, 2022 at 10:46 AM
    Tsm503
    2021 DC SR5
    I installed a transmission cooler already, Genuine Cooling Systems
    Spyker and texasrho83 like this.
  8. Oct 5, 2022 at 10:48 AM
    Tsm503
    2021 DC SR5
    So zero zerks throughout the entire truck?
  9. Oct 5, 2022 at 10:51 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Crazy huh
  10. Oct 5, 2022 at 10:52 AM
    Tsm503
    2021 DC SR5
    Yeah, guess I’ll have to replace eventually. Thanks for the info
  11. Oct 5, 2022 at 10:52 AM
    AZBoatHauler
    So.Arizona
    Don’t feel too bad - if my truck was 2WD it’d only have three - u-joints and spline shaft on the driveline.
    texasrho83 likes this.
  12. Oct 5, 2022 at 10:52 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Seems wrong....but makes it easier for me as a schmoe, new to DIY truck, driveway mechanic.
  13. Oct 6, 2022 at 4:44 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    My 2017 does not have any. So some time in 2017.
    Ely010606 likes this.
  14. Oct 6, 2022 at 4:52 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    They can be added.....
  15. Oct 6, 2022 at 4:54 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you ever upgrade your UCAs, you'll have some there. When your ball joints blow (BJs blow) you'll have some in the replacements, when your driveline U-joints go, you'll have some in those replacements.
    Tsm503[QUOTED][OP] and hagrid like this.
  16. Oct 6, 2022 at 4:56 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Actually not having zerk fittings is a pretty good thing. The totally sealed U joints have a longer life span typically since its impossible for anything to get in them. Plus, with cat thefts and the valhallas sheild that I have on, it would be an absolute nightmare to grease those things twice a year having to take those shields off.
    BravoDeltaRomeo and Jaypown like this.
  17. Oct 7, 2022 at 9:46 AM
    737fixer
    737fixer New Member
    What MadMax said. The sealed U joints are a far superior product. Far, far stronger the is ancient greaseable joint and maintenance free. Everything new is condemned by the previous generation and those who don't have it. The end of the world.......fuel injection, seat belts, air bags, sealed headlights - halogen headlights - LED headlights, etc, etc, etc, etc, etc, etc, etc, etc, etc, etc, etc, etc.........
    Tsm503[OP], Jaypown and Rodtheviking like this.
  18. Oct 7, 2022 at 9:56 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Same here, my 2017 doesn’t have any also.
