Grease Fittings?
Discussion in '2.5 Gen Tundras (2014-2021)' started by joesTundra, May 26, 2022.
  1. May 26, 2022 at 8:20 AM
    joesTundra
    joesTundra [OP] New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    Anyone now if any grease fitting on 2018 tundra, the dealer never tell me if there is ?
  2. May 26, 2022 at 8:39 AM
    AZBoatHauler
    So.Arizona
    That’s the transition year where they started to disappear. You may have zerks on your driveline - you might not. If you have them, should be two on the front (if 4x4) and three on the rear.
  3. May 26, 2022 at 11:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You can check easily. If you are 4wd and have them, there are 2 in the front driveshaft and 3 in the rear. Newer trucks went to unserviceable driveshafts but yours could have them.
  4. May 26, 2022 at 12:43 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
  5. May 26, 2022 at 1:44 PM
    737fixer
    737fixer New Member
    Just a word of caution. If you are looking under your truck and seeing the sealed bearings on your driveshaft you still need to look at the front since in a couple of forums guys have stated the front may still have the zerks. I can only assume during the transition some trucks received a mixture.
  6. May 26, 2022 at 2:01 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Here is the zerk diagram.
    AgileTundra likes this.
