Got the bump steer?.... (edit: juts brakes locking up I found out)
Discussion in 'Off-Topic Discussion' started by Vladdroid, Jul 20, 2018.
  1. Jul 20, 2018 at 6:58 PM
    Vladdroid
    Vladdroid [OP] New Member
    Vlad
    2013 White Tundra DualCab 2WD
    Leveled on Bilstein, Toyo's, and nothing else really
    Anothwr posting had this video i have exactly same issue on my 2013 DoubleCab
    https://www.tundras.com/threads/2013-dodge-ram-3500-death-wobble.2522/
    It's got a 3/1 lvl on it, 35's, and been aligned TWICE already. Had the wheels balanced multiple times .
    Everything is perfect . And then like every 3 weeks..... I'm driving and all is fine .and then I start to get a little vibration . 2-4 seconds later I'm flapping over the entire road and have to pull over (pressing the brakes makes it even worse). I don't even know what to do at this point.... Suspension is all torqued. Wheels balanced. Alignment done .even went to Toyota Dealership for that already. Just happened yesterday to my dad when he borrowed it. Almost crashed .
  2. Jul 20, 2018 at 7:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Big difference from solid axle and independent suspension. Def not the same issue.
    Bushings or ball joints are bad if everything is torqued correctly under there. Definately need to get someone under there to find and fix the issue. Very big safety issue. We want our members to be safe.
  3. Jul 20, 2018 at 7:09 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Never experienced it but CB shackles and Drive shaft spacers should take care of it. Talk to David @Coachbuilder1 about it.
    Vladdroid[OP] likes this.
  4. Jul 20, 2018 at 7:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Do you have the print-out from your alignment? Post it if you do. I’m curious about caster.
    Stock UCA’s still?
  5. Jul 20, 2018 at 7:40 PM
    Vladdroid
    Vlad
    @landphil yes stock UCA's. An offroaof shop said I should be fine with them because I just drive on the highway .
    I asked the dealers about the numbers .They said this is the closest they will be able to get . Was gonna go tomorrow to an actual off-road shop and see what they say about that though, because over phone he said they will prob be able to get it in spec.
  6. Jul 20, 2018 at 7:53 PM
    csuviper
    Broomfield, CO
    You are most likely feeling bump steer. You need to get that in better alignment. Higher caster would be better so you need new UCAs.
    4x4_Angel, 831Tun and ColoradoTJ like this.
  7. Jul 20, 2018 at 8:14 PM
    Vladdroid
    Vlad
    @csuviper so that posting above with the video . That's how bad my truck gets thrown around. Like it's bad . Would bump steer be that bad?
  8. Jul 21, 2018 at 1:48 PM
    csuviper
    Broomfield, CO
    Maybe, maybe not. I agree something is wore out. Lift the front end letting the wheels droop. Try pushing on the top of the tire back and forth toward the truck. See if it anything is loose.
  9. Jul 21, 2018 at 3:46 PM
    Professional Hand Model
    Hand Protectors
    This sounds serious. Hope you can rectify this situation easily.
  10. Jul 21, 2018 at 4:25 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
  11. Jul 21, 2018 at 4:45 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    I thought the post said death bounce for some reason oops :anonymous:
  12. Jul 21, 2018 at 6:45 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Post some photos of your front suspension.
  13. Jul 21, 2018 at 6:57 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Death wobble is a by product of a style of suspension used on heavy duty trucks, and some Jeeps. Nothing close to what we have. In your case I would suspect you have a bad tire, broken belt, whatever. You hit a bump, sets the tire out of wack, and wobble. Rotate, figure it out, particularly dangerous during the heat of summer.
  14. Jul 21, 2018 at 8:57 PM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
    Like someone above said. lift the fronts off the ground then push and pull against the top of the tire. My guess is something is worn out also.
  15. Jul 21, 2018 at 9:53 PM
    LML 3500HD
    This is how you get death wobble. The track bar bushings/joints are shot, and under the correct circumstances of side loading or cycling the suspension that sends the axle in a violent side to side motion. Ball joints don’t cause death wobble.
    This is an IFS system.
    And this is bump steer by definition...
    http://www.longacreracing.com/technical-articles.aspx?item=8162
    It’s not a coincidence that this happened after a suspension lift.
    Tires and suspension set up would be my suggestion. Anything over 2.5” of lift, you should get new upper control arms.
    Vladdroid[OP] and landphil like this.
  16. Jul 21, 2018 at 10:26 PM
    15whtrd
    15whtrd Mr. Blonde
    Have you considered possibly the brakes?
    ColoradoTJ likes this.
  17. Jul 22, 2018 at 1:54 AM
    Vladdroid
    Vlad
    @GiantsFanDan I'll get some pics tomorrow.
    @Masher59 my trucks got 55k on it. And about 4k with the leveling kit... All highway and city.... and about 10 minutes of beach driving .... i hope nothing wore out this soon...
    @Vizsla it's definitely not the tires because I've had it balanced, alignment, got new Toyo A/T's, and rebalanced again and alignment. And less than a week in, it happens again.
    @csuviper I've tried that already. Almost shook the truck off the jack and nothing.... That's what has me puzzled the most..... And when I try to recreate it on purpose, there's nothing...
    @ColoradoTJ well thanks man! I guess I'll change topic to bump steer and research some reasonable UCA's now (was kinda avoiding that lol)
    @15whtrd I have.... But there didn't seem to be anything off about them when I checked....
  18. Jul 28, 2018 at 11:17 PM
    Vladdroid
    Vlad
    Wasn't the bump steer i guess . Something to do with my brakes. Had it happen today. And then it kinda smoothed up but I noticed more resistance to driving. Stopped on a red light . It turned green, my truck wouldn't budge .I added about a half throttle (ya prob shouldn't have but wasn't a good road to stand on) to get it moving to cross the intersection and pull over to on other side..... Caused my brakes to smoke up. After walking around kicking tires for bout half hour cuz it was midnight and I had no way to move the truck, got back in and it WAS ALL GOOD!!!! So I set out to recreate the problem. I went about 30 and kicked the brake pedal enough to jerk the car and it happened again. So at least I know how to make it happen to be and to trouble and get somewhere with it now. So it wasn't the suspension at all coulda saved me couple hundred if I find out earlier lol
  19. Jul 29, 2018 at 7:32 AM
    15whtrd
    15whtrd Mr. Blonde
    I think you have dragging pad or sticking caliper. At this point you probably replace. Hopefully you don’t have to replace the calipers. At a minimum you should disassemble them and check for any abnormal wear on the slides and pins. Lube everything up and put back together. Make sure the surface that the rotors are being mounted to is completely clean and smooth. I put a small amount of caliper grease on the backside of my rotor mounting surface. A very thin layer. This also helps him to come off easier next time.
    TheBeast and ColoradoTJ like this.
  20. Jul 29, 2018 at 7:43 AM
    trdprobped17
    trdprobped17 New Member
    Casters of 4 or more are the best for any Tundra running with a lift, and or oversized wheels/tires. Plus your UCAs may be too small for your setup.
  21. Jul 29, 2018 at 7:57 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s his brakes though
    trdprobped17[QUOTED] likes this.
  22. Jul 29, 2018 at 2:02 PM
    Vladdroid
    Vlad
    @trdprobped17 yeah I just got new SPC UCA's delivered last night. Putting them on this week when I get the chance.
    @15whtrd I probably should have mentioned..... It was all 4 wheels smoking and it was pretty bad... My friend thought they ca ght on fire that's how bad it smoked. I guess it was kinda dragging and I didn't notice until it started to seriously slow the car, and by then they got very hot.
    15whtrd likes this.
  23. Jul 29, 2018 at 2:08 PM
    trdprobped17
    Wow, all four wheels?? Either you were running it in the Indy 500, causing it to smoke like that or you have some serious brake/wheel binding problems. Sorry to hear that bro!
  24. Jul 29, 2018 at 2:36 PM
    Vladdroid
    Vlad
    @trdprobped17 on bright side, I know what it is now, and don't replace the entire suspension
    trdprobped17 and ColoradoTJ like this.
  25. Jul 29, 2018 at 2:42 PM
    trdprobped17
    Ok, cool. Do you think that you could get the repairs done by Toyota under some type of warranty or vehicle malfunction? It’s worth the try. All they can say is no.
  26. Jul 29, 2018 at 3:10 PM
    csuviper
    Broomfield, CO
    All 4 the it’s somewhere in the hydraulic sysem
  27. Jul 29, 2018 at 3:34 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    All 4tires smoking? That's BA drifting a truck in 4WD. :benchpress:
  28. Jul 29, 2018 at 3:36 PM
    LML 3500HD
    Your surprised? It’s a Tundra....:D
  29. Jul 29, 2018 at 3:51 PM
    blizz86
    blizz86 New Member
    seconded. either hydraulic system or the computer is activating the traction control somewhere causing the lockups upstream somewhere.. try to have a video recorded of it doing it. i know it might be difficult but best to try to get it on video so you can show a tech.
  30. Jul 29, 2018 at 4:46 PM
    NCinCO
    Gary
    Thornton, CO
    Well true TJ. I must have spaced it for a minute or so.
