Got Rid of the Alpha Rex headlights went Toyota OEM
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Aug 25, 2021.
  1. Jun 5, 2022 at 12:44 PM
    #91
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    So I figured out that if there’s two wires that are connected to the Amber bulb in the center of the Nets mainly a turn signal and if there’s three wires in the amber bar is a turn signal and can be a parking light. Mine only has two wires so the Amber doesn’t work as. Parking light.
    now I do know that even though you have two wires to that bulb there are a couple ways to make that center Amber a parking light. One of which is splicing into the second wire…
  2. Jan 10, 2023 at 8:47 PM
    #92
    BasicAverageTruck
    BasicAverageTruck New Member
    Thank you to Shanet421, your advice fixed my issue with the Alpha Rex always running Amber DRL. The three wire plug was delivered plugged into another socket on the headlight. I had to disconnect that to plug one end into the factory turn signal 3-wire plug. The other end plugged into the back of the turn signal bulb. Now the white DRL is on all the time AND the sequential turn signal works.
    FYI, for those who actually want the full time amber DRL, keep the 3-wire plugs on the back of the Alpha Rex headlight plugged in as it is shipped.
    Shanet421[QUOTED] likes this.
  3. Jan 14, 2023 at 3:22 PM
    #93
    davids_1718
    davids_1718 New Member
    2014 blizzard pearl platinum sequoia
    Alpharex nova gen 2 headlight Diode Dynamic ss3 pro fogs Dasaita head unit Blacked out interior silver panels Color matched rain visors, bug shield and oem fender flares AFE cold air Dirty Deeds 8" catback system
    I just replaced my 08 with the pros and upgraded to a 14 with the Nova gen2. I've tried everything and i cannot get the amber function to work as drl & park with sequential. Ive plugged in all harness. As it stands here is how it is wired and the end results...
    With the below wiring my start up display starts amber then white and stays white. My drl stays white in all functions. My sequential does turn amber.
    1) black harness -factory truck gray harness, 2) gray harness - gray factory light plug, 3) im using led switchback bulbs as turn signal bulbs with resistors installed.
    When i plug in the corner light harness the amber stays on at all times and the drl does not work as turn signal.
    When i tried plugging the alpharex black and gray harnesses together and plug vehicle factory turn signal wire into light bulb no sequential function nor white drl.
    Im looking for amber all time except when headlights are on. What am i not understanding?
  4. Jan 14, 2023 at 8:06 PM
    #94
    BasicAverageTruck
    Correct. When I plugged the Alpha Rex harness to itself and plugged the factory turn signal wire directly to the turn signal bulb, the DRL stay amber (if that's what you want), but the sequential turn signal is gone AND no white DRL.
  5. Jan 15, 2023 at 2:21 PM
    #95
    davids_1718
    This makes no sense. $1000 headache just to get things working right. Aint easy in 28 degree weather.
  6. Jan 19, 2023 at 5:12 PM
    #96
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
    First pair I would assume I received 08/06/2021
    Second pair of Alpha Rex 06/26/22 failed 11/24/22
    First sign of hope when I received the new Toyota OEM headlights.
  7. Jan 19, 2023 at 6:07 PM
    #97
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    well dang, for the price of the NOVA's you'd figure they'd last longer.
    I'm about to hit 3 years with my first gen NOVA's but I know it's not always going to be the same for everyone, just one out of many. On a side note I did purchase a set of the NOVAs on Amazon that have the amber function to upgrade my first gens before alpharex released the new G2 NOVA. Unfortunately only half the DRL lit up on both of them so returned them and kept my first gen NOVAs. Figured since I haven't had any issues with them why change them, and I'm still happy with them. Hopefully the OEM leds workout great for you.
    Part_time[QUOTED][OP] likes this.
  8. Jan 19, 2023 at 6:13 PM
    #98
    Part_time
    Oregon
    So the difference between the two I am not here to bash just point out.
    The Alpha Rex DRL is a smoked ring, were as the Toyota is more of a crisp ring.i think it may be the way it is cut.
    Alpha:
    Toyota:
  9. Jan 19, 2023 at 6:39 PM
    #99
    Part_time
    Oregon
    Harnesses:
    Alpha
  10. Jan 19, 2023 at 6:40 PM
    #100
    Part_time
    Oregon
    Toyota:
    Regardless I am now a light installing maniac now.
  11. Jan 20, 2023 at 5:42 AM
    #101
    pursuit2550
    pursuit2550 New Member
    Yeah, I didn’t want to deal with any aftermarket stuff. I use to be a big fan of Morimoto but the last few time I used them, they failed me. The price on their tundra headlights was crazy. Didn’t want to take another chance with them. So I went OEM. Can’t beat Toyota quality.
    Part_time[OP] likes this.
  12. Jan 21, 2023 at 6:10 AM
    #102
    davids_1718
    So after hours and hours of trouble shooting. Seems like there is a bypass by alpha that not many have been aware of. Apparently for some reasons the built in relay box on the novs has to be disconnected and then the 2 yellownwire pigtailsncoming from the turn signal harness go together. Wala..... amber drl, park mode. Sequential turn. White drl while headlights on.
    I gotta say these gen2's are bright as hell when compared to the pros i had on the 08.
  13. Mar 5, 2023 at 11:28 PM
    #103
    Goofinator
    Goofinator New Member
    Bernard
    Sorry to re question this thread but have questions on the alpha Rex and hope someone can explain why. I was looking at buying a pair but damn you guys had some issues. My issue was that a negative and positive wire have to connect to the battery and a fuse in the fuse box. I also see when the headlight are on or parking light the turn signal lights up. But on my truck the turn signal only lights up when using it. My DRL is LED I don’t want it too. So if you buy and install these no matter what you have to do the battery, fuse and the turn signal will glow?
  14. Mar 6, 2023 at 4:38 AM
    #104
    Just curious on what issues you had. You don't hear too many with Morimotos.
