GoPro video of a weird noise
Discussion in '1st Gen Tundras (2000-2006)' started by Musashi66, Jun 3, 2019.
  1. Jun 4, 2019 at 9:13 AM
    Musashi66
    Musashi66 [OP] New Member
    2022 DC TRD Sport Lunar Rock
    P-Factor[QUOTED] likes this.
  2. Jun 4, 2019 at 9:36 AM
    P-Factor
    P-Factor New Member
    As a secondary confirmation, (or not) aim your GoPro at each bushing point and drive your vehicle to see if the sound matches visual movement.
    Good luck! :thumbsup:
    Musashi66[OP] and Hooptytrix like this.
  3. Jun 4, 2019 at 3:20 PM
    Professional Hand Model
    Hand Protectors
    P-Factor with the X-Factor!
    Maybe a new winner of the chicken dinner!!!
    Musashi66[OP] and Medic343 like this.
  4. Jun 4, 2019 at 4:21 PM
    Hand Protectors
    I went out for grins and checked my shackles per the vid. They are solid. My noise is the lack of washers/silencers on the springs.
    Musashi66[OP] and P-Factor like this.
  5. Jun 4, 2019 at 4:43 PM
    Ryedog12
    Ryedog12 New Member
    2006 Tundra TRD 4.7L V8 4X4
    Sounds like it could be the carrier bearing starting to go out. Maybe it’s got just enough play to wiggle when you coast. Maybe point the camera at the carrier bearing and see if the sound is consistent with its movement. The sound in the video I posted sounds like what I’m hearing in your video to a less severe degree. But then again you did say your mechanic checked the driveshaft so I could be wrong.
    Musashi66[QUOTED][OP] likes this.
  6. Jun 4, 2019 at 7:13 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My old Titan would creak from the leaf springs having bad bushing isolators between the leafs. It just took some grease on them every once in a while.
  7. Jun 4, 2019 at 7:55 PM
    Musashi66
    The whole driveshaft has been checked and it has been greased. I don’t think that’s the issue. It really seems more like metal rubbing than a rotational noise.
  8. Jun 4, 2019 at 7:56 PM
    Musashi66
    That’s what PHM seems to be suffering from as well. How do you grease those? Just some grease between the springs wherever you can squeeze it in?
  9. Jun 4, 2019 at 8:02 PM
    KarmaKannon
    Utah
    Some junk
    Yeah basically I would just get some grease in better the springs where the rubber isolators were supposed to be. By hand or with a brush, and I just used wheel bearing grease. Seemed to work well unless I spent a lot of time on the dirt roads and then it would get noisy faster.
  10. Jun 4, 2019 at 8:06 PM
    sargebt
    sargebt New Member
    Brandon
    2016 Platinum Tundra
    7 inch BDS, running 35’s
    Have you actually looked at the leaf springs them self. I have a 2016 platinum Tundra that just had both replaced because they were separating and I had the same noise
    Musashi66[OP] likes this.
  11. Jun 4, 2019 at 8:10 PM
    Musashi66
    I guess I have nothing to compare them to. They look good to me, I don’t see any cracks, but... not 100% sure. I’ll have some help this weekend - they’ll bounce on the bumper and I’ll spend time under trying to locate the sound.
  12. Jun 4, 2019 at 8:11 PM
    Musashi66
    Nothing to lose, I have my grease gun, I can just squirt some grease and see what happens.
  13. Jun 4, 2019 at 8:13 PM
    sargebt
    sargebt New Member
    Brandon
    Mine looked fine as well.
  14. Jun 4, 2019 at 8:39 PM
    Musashi66
    If I can pinpoint the noise, I’ll pay for the new leaf springs and install a pair. I just need to verify what’s making the noise first.
  15. Jun 4, 2019 at 9:17 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is the tailgate rattling?
    I would move the camera around and see it from different angles down there
  16. Jun 5, 2019 at 3:21 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I doubt grease would help. If the leaf springs rivet is worn or separating, shackle bushing or shock bushing is worn or loose then you have a gap which causes the rattle. My front end would creak sometimes and for that problem grease is all it takes.
  17. Jun 5, 2019 at 8:01 PM
    Musashi66
    I tried removing the tailgate to eliminate this and it still made the noise.
  18. Jun 5, 2019 at 8:02 PM
    Musashi66
    I’ll replace them if they are bad, as long as I can identify where the damn noise is coming from.
  19. Jun 5, 2019 at 8:08 PM
    #49
    KarmaKannon
    Utah
    Some junk
    Grease is cheap. It sounded crazy when I had my Titan but for 2 years it kept that thing quiet. Never know, you might get lucky.
    Hbjeff likes this.
  20. Jun 10, 2019 at 7:03 AM
    #50
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Did you ever get a chance to see if it was the same problem as in the video? I'm curious.
  21. Jun 11, 2019 at 7:10 PM
    #51
    Musashi66
    Nope :/.
    I had my dad swing left and right on the bumper but couldn’t pinpoint the noise. It didn’t seem to be the coming from the leaf spring bushings. It seems it’s somewhere further up. Might be the bed mounts, but I can’t tell. It’s still driving me insane.
  22. Jun 12, 2019 at 4:07 AM
    #52
    FirstGenVol
    East TN
    2002 AC
    Doesn't your truck have a topper on it? I mentiomed before that my truck is making similar noises as yours. When my dad was in my truck he seemed to think it might be the topper making noises.
  23. Jun 12, 2019 at 5:38 AM
    #53
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    On my 04' I went two months looking for a rattle/knocking when I turned left or hit speed bumps. I eventually tracked it down to a rock (from a gravel load) was wedged between my bed and the cab, about two feet below the rear window. It would bind when the cab and bed had pressure applied under bumps or turning. It is frustrating though!
  24. Nov 11, 2021 at 11:06 AM
    #54
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    Did this ever get solved?
  25. Nov 15, 2021 at 9:16 PM
    #55
    Musashi66
    It stopped making noises. No clue how or why. Maybe I had a rock too, maybe it was the topper, maybe it whatever it was settled and stop bumping. No clue, but I am glad it is not there.
    Punk1974 likes this.
