Goodyear UltraTerrain AT
Discussion in 'Wheels & Tires' started by kparrow, Sep 9, 2019.
  1. Nov 14, 2020 at 10:11 PM
    kparrow
    kparrow [OP] New Member
    Kevin
    Nampa, ID
    For sure, I’ve had to use it 3 times in 2 years....beginning to think I’m cursed on tire issues! I hope it stops!
    NWPirate[QUOTED] likes this.
  2. Nov 14, 2020 at 10:12 PM
    kparrow
    Kevin
    Nampa, ID
    Bummer! Out of curiosity were yours P rated or LT?
  3. Nov 14, 2020 at 10:16 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    I’ve been running these on my land cruiser for 20k miles. They are an excellent tire! They will be going on the tundra when the stockers wear out. I had run duratracs prior and was looking for something that weighed a little less and was a little less noisy and still looked aggressive. Pleased with performance in all conditions and can barely tell they are worn after 20k. 10/10 would recommend
    Tundra1078, kparrow[OP] and NWPirate like this.
  4. Nov 14, 2020 at 10:19 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    They were P rated so maybe that had something to do with the sidewall being soft but they also took out chunks of tread on some easy rocky trails. Seems like people like them in the LT but in the P rated no bueno for me.
  5. Nov 14, 2020 at 10:23 PM
    kparrow
    Kevin
    Nampa, ID
    That might explain the soft sidewall. I’ve been happy with the LT. Similar experience for me with the P rated Coopers I had prior, sidewall was soft so truck felt swishy and all over the road, tread didn’t chunk though. Good to know for at least this brand/model go LT. Unlikely on the truck I’ll ever go with P rated again though honestly
    NWPirate likes this.
  6. Nov 14, 2020 at 10:24 PM
    NWPirate
    Zach
    WA
    That sucks man, the LT is SOLID!
    MS22[QUOTED] and kparrow[OP] like this.
  7. Nov 14, 2020 at 10:27 PM
    kparrow
    Kevin
    Nampa, ID
    Circling back around, were your tires P rated or LT? Seems most all positive feedback is from the LT. I didn’t realize these even came in a P rated till I looked closer.
  8. Nov 14, 2020 at 10:44 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    They were P rated. I bought them when they first came out so I dont remember if they had the LT or I didnt pay attention but I got the P rated. This is an old picture but they chunked really easy. 20190903_174400.jpg
    kparrow[QUOTED][OP] likes this.
  9. Nov 14, 2020 at 11:33 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    These tires are purely awesome in the snow. So far best A/T tire I have ran in the snow. My only gripe is they are stone magnets. I had a gravel driveway till we moved and driving out the first 15 miles once on blacktop was all the stones clearing out. And they will pick up big ones not just pebbles. Feel bad for the guy driving behind for the first few miles....but we moved and no longer have gravel so theres that....I have 285/70r17 and they "feel" heavy on the truck. Definitely takes a little more grunt to get them going. But once they are they are smooth and have a nice growl to them. 2 took quite a bit of weight to balance and the other 2 barely took any.
    kparrow[OP] likes this.
  10. Nov 15, 2020 at 12:55 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Are these the tires the went with on the Dodge TRX?
  11. Nov 15, 2020 at 10:37 AM
    kparrow
    Kevin
    Nampa, ID
    Nope, that would be the Goodyear Wrangler Territory AT.
    Flyinryank[QUOTED] likes this.
  12. Nov 16, 2020 at 11:10 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    @kparrow are you 100% stock suspension? I'm looking to run this same size tire (275/70) on my stock OR 18" wheels. Everything I've seen says you can run this size with stock suspension and no issues with rubbing. Has that been the case with these?
  13. Nov 16, 2020 at 11:30 AM
    kparrow
    Kevin
    Nampa, ID
    Yup, 100% stock. Also running 1.5” BORA wheel spacers
  14. Nov 16, 2020 at 11:39 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    Do you think they would still fit fine without the spacers?
  15. Nov 16, 2020 at 11:43 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Yes.
    kparrow[OP] and GT87[QUOTED] like this.
  16. Nov 16, 2020 at 12:31 PM
    kparrow
    Kevin
    Nampa, ID
    Yes
    GT87[QUOTED] likes this.
  17. Nov 16, 2020 at 12:42 PM
    NWPirate
    Zach
    WA
    I'm running the same size on my OR wheels (no spacer), only had minor rubbing on the skid plate but I just bent that out of the way.
    JLS in WA and kparrow[OP] like this.
  18. Nov 16, 2020 at 12:50 PM
    kparrow
    Kevin
    Nampa, ID
    I had to take off the little mini front flaps, that’s all
  19. Nov 16, 2020 at 3:10 PM
    #49
    kparrow
    Kevin
    Nampa, ID
    And yeah they fit fine before I got spacers
  20. Mar 31, 2021 at 1:20 PM
    #50
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    They have the Goodyear Fierce Attitude M/T's
  21. Jun 14, 2021 at 6:17 PM
    #51
    kparrow
    Kevin
    Nampa, ID
    UPDATE!
    Still running tires and loving them. Road noise is good, very quiet, wearing very well. Was wearing the middle a little more than edges in the rear at my last rotation cause I forgot to drop the rears back down to 45 after towing my camper here from the move. No big deal and it has been corrected. Took minor weight to rebalance. Still very pleased!
  22. Mar 27, 2022 at 3:17 PM
    #52
    aaronoto
    aaronoto New Member
    Old post, but I was just looking though this thread again to see if anyone else had experienced the same as me, as I’m looking at needing a new set of tires again and was thinking about giving them another shot. Mine were LT’s in 275/65/18 that I had tried.
  23. Mar 27, 2022 at 3:23 PM
    #53
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have them in 275/60/20 and they are SL rated.
    Been very happy with them..
    Going from D-rated KO2s in the same size, the ride and wet traction is much better with the Goodyears.
  24. Mar 28, 2022 at 10:19 AM
    #54
    kparrow
    Kevin
    Nampa, ID
    Still running the same set. Still super happy with them and wearing well!
    Warreng likes this.
  25. Sep 10, 2023 at 5:36 PM
    #55
    blenton
    blenton New Member
    Miles on them? Any change in fuel economy? No tread water warranty on these, but I’ve never bothered with that warranty since you usually have to run them down below 3/32’s..
