Good Tow strap what do you guys recommend?
Discussion in 'General Tundra Discussion' started by Rica25, Jan 13, 2021.
  1. Jan 15, 2021 at 8:04 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
  2. Jan 15, 2021 at 8:10 AM
    Rica25
    Ricardo
    Tulare
    I ordered Rhino Shackles, Rhino recovery strap, and the rhino shackle receiver.
  3. Jan 15, 2021 at 8:10 AM
    AZBoatHauler
    So.Arizona
  4. Jan 15, 2021 at 8:10 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    But what if you're the stuck asshat?
    argtexas, CodyP[QUOTED], JMB and 3 others like this.
  5. Jan 15, 2021 at 8:11 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @ColoradoTJ can probably give a better explanation.....but here's my understanding
    If you want to pull something, a strap is fine.
    If you need to get something un-stuck, then a kinetic rope would be best.
  6. Jan 15, 2021 at 8:15 AM
    The Californian
    Eric
    Yah, a strap can snap under the pressures of trying to get someone un-stuck, which has in the past maimed, injured, and decapitated people. Kinetic ropes are made to absorb, and release the energy in a useful way so they don't snap.
  7. Jan 15, 2021 at 8:20 AM
    Speed_dmon
    Speed_dmon New Member
    2020 TRD Pro Hulk
  8. Jan 15, 2021 at 8:38 AM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    What they said^^ Also straps are a million times more compact to store in your truck.
    A strap is like a “wack” a sudden burst or hit of force because it doesn’t really stretch.
    A kinetic rope is more like a long push of force. It spreads the same amount of force out in a more progressive manner. This gives you the ability to have harder yanks and in the end, exert more force.
    It also just makes life more enjoyable and puts less stress on both vehicles by smoothing out the yank.
    I have towed/pulled out upwards of 50 vehicles in the last few years with both standard straps and kinetic ropes. Kinetic ropes definitely work better and allow for better yanks. But at the end of the day, if this is just an “incase of emergency” item, then save the money and get a strap.
    But no matter what you do, PLEASE make sure you use a good recovery point such as a hitch pin or the hooks under the bumper. Do not ever hook to the chain hooks (is that what they’re called?) next to the hitch or a ball hitch.
    bulldog93 and Skey44 like this.
  9. Jan 15, 2021 at 8:38 AM
    Rica25
    Ricardo
    Tulare
    So I read recovery strap is better than a tow strap because it is more stretchy.
    saybng, The Californian and Nic146 like this.
  10. Jan 15, 2021 at 8:40 AM
    Rica25
    Ricardo
    Tulare
  11. Jan 15, 2021 at 8:48 AM
    The Californian
    Eric
    And it gives you good, smooth, gentle yanks.
  12. Jan 15, 2021 at 8:49 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    TreatyOak Houston Texas, pricey but once you receive what you order a person will see why!! Handmade to order, fine craftsmanship, very nice products.
    Rica25[OP] likes this.
  13. Jan 15, 2021 at 8:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    if you haven't, you should watch some youtube videos (check out matts offroad recovery) to see kinetic ropes in action.
  14. Jan 15, 2021 at 8:51 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Nice. A 30’ 7/8” rope is still less than half the price of Matt’s.
  15. Jan 15, 2021 at 8:55 AM
    AZBoatHauler
    So.Arizona
    Sumo91, KillaahCam, Kung and 3 others like this.
  16. Jan 15, 2021 at 8:55 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    If I am not mistaken, ARB snatch straps have some stretch to assist in the recovery and can be had at a sun $100 price point if I remember correctly. I have used mine for pulling multiple vehicles out of sand and mud.
    Rica25[OP] and Nic146 like this.
  17. Jan 15, 2021 at 9:53 AM
    Rica25
    Ricardo
    Tulare
    So the biggest difference between the kinetic and the recovery is how many uses you can get out of it.
  18. Jan 15, 2021 at 10:09 AM
    The Californian
    Eric
    Depends on what you mean by "how many uses you can get out of it". If you mean diversity of applications, then yes. If you mean amount of times you can use it, then no.
    Rica25[QUOTED][OP] and saybng like this.
  19. Jan 15, 2021 at 10:18 AM
    #49
    Kung
    KG, VA
    (Given your handle, you should get this one. LOL)
  20. Jan 15, 2021 at 10:26 AM
    #50
    This will be just fine. No need to worry about “stretch” since you shouldn’t give this tow strap shock loads.
  21. Jan 15, 2021 at 10:29 AM
    #51
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I bought a 30' 7/8" Bubba Rope to ride around in the truck with me.
    I doubt I will ever need it but if I don't have it I will most certainly need it...
    Rica25[OP] and AZBoatHauler like this.
  22. Jan 15, 2021 at 11:06 AM
    #52
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I use the ARB 18k snatch strap. You generally want the break strengthen to be about 3x the weight of the vehicle you’re recovering so you’ll get some stretch. I also use a cheap 30k tow strap to tow broke trucks for long distances. You do not want to use your nice expensive snatch straps to tow. Dirt will get in the fibers and there’s also a high chance the truck can either run it over or wrap it around a wheel.
    Personally, I like the ARB’s because they store nicely and they’re cheap. You’re likely to damage your line, usually by running it over, long before the line itself fails. So I’d rather replace an $80 line rather than a fancy $300 one before I even get the full life out of them.
  23. Jan 15, 2021 at 12:10 PM
    #53
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
  24. Jan 15, 2021 at 12:56 PM
    #54
    Rica25
    Ricardo
    Tulare
    Just arrived
    bulldog93, Skew12 and saybng like this.
  25. Jan 15, 2021 at 2:19 PM
    #55
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    https://www.deadmanoffroad.com/
    This is what I’m looking to get real soon! They’re made in the U.S., great customer service, great people.
    A few guys on YouTube have reviewed their products with great feedback.
  26. Jan 15, 2021 at 4:01 PM
    #56
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    3/4 inch steel shackle vs soft shackle? Any feedback on this?
    I'm in process of putting together a recovery kit for my truck also, I can see advantages to the soft shackle but doesn't seem possible to be as durable as steel.
  27. Jan 15, 2021 at 4:57 PM
    #57
    Rica25
    Ricardo
    Tulare
    Ordered the Warn Dampner bag just now.
  28. Jan 19, 2021 at 4:51 AM
    #58
    Luckydog
    Luckydog New Member
    Dominic
    I switched to soft shackles. More options to hook up. Faster, safer, less weight.
    AZBoatHauler and Rica25[OP] like this.
  29. Jan 19, 2021 at 5:10 AM
    #59
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  30. Jan 19, 2021 at 5:14 AM
    #60
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    x2 on the bubba rope. Good product. Better to have and not need then need and not have...
