Good thoughts needed for Brian (csuviper)
Discussion in 'Off-Topic Discussion' started by T-Rex266, Mar 29, 2018.
  1. Apr 9, 2018 at 9:07 PM
    #181
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Went to the neurologist today. Was told that the numbness is not typical of the dissection but most likely I had a small stroke that was not detected with the MRI. Nothing to worry about, no change to how I would be treated if I did or if I didn’t. Numbness is most likely temporary and I should start seeing improvement soon. The neck pain and headache on the opposite side of my neck is not typical of the dissection and most likely something separate. Will be working with a massage therapist that happens to also be a physical therapist to figure it out. 325mg Asprin once a day is adequate for blood clot prevention. Have a follow up mid May and will schedule another cat scan in 3 months to see if it is healed.
  2. Apr 9, 2018 at 9:10 PM
    #182
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Sounds like good news to me. Light at the end of the tunnel sir.
  3. Apr 9, 2018 at 9:40 PM
    #183
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    That's wonderful to hear. :cheers:
  4. Apr 9, 2018 at 11:47 PM
    #184
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    All things considered, that's some good news.
    Continue to get well man! I'll keep you on the main line.
    Sunnier likes this.
  5. Apr 10, 2018 at 1:07 AM
    #185
    That’s good news Brian.
  6. Apr 10, 2018 at 5:24 AM
    #186
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Brian, I’m hoping I’m over-analyzing but have a question for you because I’ve “normally” had issues with this exact area, including severe and crippling headaches that are only relieved by the chiro. Have you ever had ongoing stress to those muscles or nerves in that region? Originally posted you referred to gym or chiro as a leading idea of where is “injury” might have come from. Are you still leaning in that direction?? I know it’s still a mystery but sometimes we can self diagnose because of the obvious sensations, and it sounds like you’re already doing such. Your experience has me nervous due to my ongoing stressed muscles and headaches.
    I’m hoping the best brother!
    EDIT*. I must’ve missed a post earlier about the mini stroke. Just read it after I wrote this. After all the horror stories and Dr mishaps I’ve read through here I have to inquire about your confidence. Does the prognosis sound like it’s legit? I’m not discounting it, just asking you, the one that’s experiencing the sensations
  7. Apr 10, 2018 at 6:17 AM
    #187
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Hopefully you’ll be as right as rain soon
    :thumbsup:
  8. Apr 10, 2018 at 8:04 AM
    #188
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    Glad you got some good news :)
  9. Apr 10, 2018 at 9:04 AM
    #189
    csuviper
    Broomfield, CO
    Most likely cause is chiropractor. I have not had any other neck trauma besides that. Its the fast neck cracking that is the typical cause.
    Just working out and lifting heavy weight would not have caused this artery tear. Could have made it worse but not initial cause.
    I have been working out a lot and building muscle while loosing fat. I have felt alot of pressure on my traps over the past 6 months or so. Have had this same neck/head pain back last august/November. I lost taste. Everything tasted bitter. Neurologist doesnt think that is related to the dissection. Im thinking i did something else that is affecting my traps. Massage was able to help the pain last time. Taste took about a month to come back.
    Not going back to the chiropractor.
  10. Apr 10, 2018 at 1:02 PM
    #190
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Glad to hear you got some answers and have a treatment plan. Good luck and please keep us posted on your progress!
  11. Apr 15, 2018 at 1:35 PM
    #191
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Prayers sent my friend.
  12. Apr 15, 2018 at 7:01 PM
    #192
    csuviper
    Broomfield, CO
  13. Apr 15, 2018 at 7:05 PM
    #193
    This is definitely a better condition to solve and cure right?
  14. Apr 15, 2018 at 7:10 PM
    #194
    csuviper
    Broomfield, CO
    Yea seems like inflammation to nerves that might need some help to calm down. Since I’m at 2 weeks now without it going away I may need a shot or so to get rid of it. Possibly also caused by the chiropractor.
    Still had the artery dissection and possible mild stoke. Just another thing wrong at the moment.
  15. Apr 15, 2018 at 7:12 PM
    #195
    csuviper
    Broomfield, CO
    Ibuprophin an anti inflammatory helps calm it down. Tylenol doesn’t. Inflammation it def is.
    ColoradoTJ and Watt maker like this.
  16. Apr 15, 2018 at 7:17 PM
    #196
    csuviper
    Broomfield, CO
  17. Apr 15, 2018 at 8:27 PM
    #197
    I do believe you might be on to something there Brian.
    We all are pulling for you.
  18. Apr 15, 2018 at 8:33 PM
    #198
    Eclipsed & Floating
    Voluptuous Whitey
    Are you gonna check with doc on the likeliness, or have you lost confidence?
  19. Apr 15, 2018 at 9:54 PM
    #199
    csuviper
    Broomfield, CO
    Going to send a message to neurologist and probably set up appointment with primary to see what can be done. I would feel so much better if my head didn’t hurt all the time.
    Watt maker and ColoradoTJ like this.
  20. Apr 15, 2018 at 10:29 PM
    #200
    Are you getting much sleep?
  21. Apr 15, 2018 at 10:30 PM
    #201
    csuviper
    Broomfield, CO
    I wasn’t for 4 days after the hospital visit but am now. No issues laying down. Some nights I have to take ibuprophin to calm it down first
  22. Apr 15, 2018 at 10:32 PM
    #202
    Glad your getting some decent sleep Brian. My issues, I would finally just pass out from exhaustion...my body just shut down.
  23. Apr 15, 2018 at 10:36 PM
    #203
    csuviper
    Broomfield, CO
    Mine is very mild compared to what you went through man.
  24. Apr 16, 2018 at 7:51 AM
    #204
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I used to work in pain management, if it's indeed neuralgia, consistent anti-inflammatory medication should clear it up in a couple of months. It's a gradual process over time and is used in combo with acute pain relievers, that's why you have to take them every day as prescribed, and it won't be something you take forever.
    Go at it from different angles... heat, massage, physio, acupuncture and if first line drugs don’t help, you can progress to meds used for epilepsy and depression in dosage/frequencies designed for nerve pain. At one-time they were off label uses but it's now established, supported by peer-reviewed studies.
    Of course I’m a webchair here so always consult a professional in-person and maintain a relationship because managing pain is trial and error, we all respond differently. Follow-up is important to modify the regimen specific to your needs and eventually wean you off them.
    Good luck man, you got this!
    https://www.medicinenet.com/occipit...ain_and_other_symptoms_of_occipital_neuralgia
  25. Apr 16, 2018 at 7:55 AM
    #205
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Just keep an eye on your liver with all that Advil you're taking.
  26. Apr 16, 2018 at 8:06 AM
    #206
    Eclipsed & Floating
    Voluptuous Whitey
    ^^this
    Especially if any alcohol is consumed
  27. Apr 16, 2018 at 8:18 AM
    #207
    csuviper
    Broomfield, CO
    Thanks for the info. I have had to take ibuprofen every day for 2 weeks now to keep the pain down. Definitely worried when i have to take that many meds.
  28. Apr 16, 2018 at 8:22 AM
    #208
    csuviper
    Broomfield, CO
    Will be talking to the dr soon to figure this out and get the blood work.
  29. Apr 16, 2018 at 8:49 AM
    #209
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    No problem, your specialist would have gotten baseline liver/kidney function and other bloodwork results, then repeat them at intervals if any of your meds may affect your organs. At minimum, never exceed what's on the bottle, and be honest with your doc how much you are taking OTC, holistically, or anything they might not be aware about.
    Ibuprofen will be fine for acute relief, but I don't believe it's the type of anti-inflammatory that will settle those nerves in the long run (if that's the cause). Again, my opinion means squat over the net. I just have a good feeling with everything I've read you're going to be okay managed correctly by your health care professionals, keep positive Brian!
    Sunnier likes this.
  30. Apr 16, 2018 at 10:21 AM
    #210
    csuviper
    Broomfield, CO
    Thanks for the good words of advice.
