Good low cost OBD2 scanner w/Bluetooth or WiFi for iPhone?
Discussion in '2.5 Gen Tundras (2014-2021)' started by a522467, Feb 17, 2021.
  1. Feb 17, 2021 at 11:02 PM
    a522467
    a522467 [OP] Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Can anyone recommend a good OBD2 scanner for my ‘20 SR5 DC that will talk to an iPhone over Bluetooth? I want to be able to check/monitor critical data, such as trans temps, check and reset fault codes, change parameters such as footwell timer, seat belt chime, etc. Hoping to find one under $50 and not really wanting to have to pay for an ongoing subscription. TIA
  2. Feb 18, 2021 at 5:39 AM
    couchpotato013
    couchpotato013 New Member
    "Best" and "low cost" usually don't go together. From what I've seen, iPhone compatibility is also a challenge for bluetooth OBD readers for some reason.
    For low cost code scanning, any ELM327 based OBD reader or knockoff is fine, but won't come with any software. There is this thread that talks about iPhone OBD reader software though. I have a knockoff and rarely use it, but that's because I also have a BlueDriver and OBDLink MX+. Also lets me know how to reset the maintenance reminder like ignition key and trip reset sequences to get the lights to turn off for TPMS or oil change indicators. Clear codes would probably do it as well.
    BlueDriver code scanning and gives recommendations on what part is likely at fault for a given error code. BlueDriver is only compatible with its own app though, and can not be used with Torque for Android. Way over your budget, but it's paid for itself by recommending fixes unique to vehicle models/years. No subscriptions or addons. An example of a BlueDrive repair report https://www.bluedriver.com/sites/default/files/2018-07/Sample-BlueDriver-Repair-Report_0.pdf . I don't believe the BlueDriver reader is completely required. Just the BlueDriver app with the vehicle manually inputted and error code manually inputted should give you the repair report as well, all for free if you go with a ELM327 reader or similar.
    OBDLink MX+ I use for data monitoring. BlueDriver does it as well, but I prefer OBDLink for this due to how the UI works. Supposedly has polls the data faster as well. Also has enhanced code scanning that understands vendor specific error codes, available for free. These enhanced functions used to be paid addons, or free trial like things. Completely free now. But the UI is still setup like a shopping cart where you have to "buy" a certain year of a manufacturer. Gives you the error code and maybe a description of it and then you have to Google the fix. Also way over your budget. https://www.youtube.com/watch?v=CQCMvHJLnZY
    Now these are READERS. They can reset error codes, but won't change other parameters. Both units I listed are at the $100 budget, but they provide free ongoing support for new vehicles and information on how common an error code is on a specific vehicle model as well as known fixes for them.
    Because they're constantly being update, there is a lot of outdated information in reviews. I can answer any questions or provide screenshots for those curious, as it's quite expensive without being able to trial/test it beforehand.
    Note that the ELM327 based readers with Bluetooth will most likely not work for iPhone, but the wifi versions will.:
    https://medium.com/@gepeto42/using-an-iphone-or-ipod-touch-with-an-elm327-wifi-obd-ii-3527562a33d3
    https://www.lifewire.com/elm327-iphone-adapter-doesnt-work-534643
    a522467[OP] and Vang530 like this.
  3. Feb 18, 2021 at 3:37 PM
    a522467
    Michelle
    Ohio
    Thanks for the great info! The MX+ looks super cool. I searched again and managed to find a trans cooler thread that discusses this subject too.
    Your reply makes me curious though what people are using to reset parameters, and does that device use the same port?
    :monocle:
  4. Feb 18, 2021 at 4:31 PM
    couchpotato013
    I put in my vin on the obdlink mx+ app, but the app gives me access to all possible parameters, rather than what the vehicle supports. Blue driver will show which parameters are supported, but the obd reader must be plugged in. I'll try that tomorrow.
    It doesn't look like obdlink mx+ supports transmission temperature. But again, I didn't have the reader plugged in but the app allows you to preset what you want to monitor.
    EDIT: I forgot about the rest of your reply. There are other OBD devices that can do a lot of things with ABS, as well as autobleed the breaks. Those cost a lot more and aren't bluetooth. Will most likely require a subscription too. I believe the term for these are bidirectional obd.
    An example: https://youtu.be/RMLSWDfUAYs
    a522467[OP] likes this.
  5. Feb 18, 2021 at 6:33 PM
    a522467
    Michelle
    Ohio
    On an OBD thread I found, another poster confirmed that trans temps are accessible.
  6. Feb 20, 2021 at 7:19 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I just set up the Veepeak and had to get the $49.99 add on to get tranny temps. By the time I was done, it was close to the same cost as the MX+. Maybe I did something wrong, no expert, but that’s what I found. I do like the functionality.
  7. Feb 20, 2021 at 11:25 AM
    a522467
    Michelle
    Ohio
    Thanks for sharing your experience. That’s what I was afraid of. I’m going to try the $10 adder first and see if that will work for me. My scanner is due to arrive Monday.
  8. Feb 20, 2021 at 12:19 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I have used a $20 WiFi elm327 reader from Amazon with both iPhone and Android in various vehicles. Can read all obd2 codes and shows all sensors using “Car Scanner ELM OBD2” app.
  9. Feb 20, 2021 at 1:01 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I have the OBDMX+ and yes transmission temps are available.
    Also when you scan the truck with the truck on it will whittle down the list to only what is readable. Compared to just typing in the VIN which gives you a bunch of useless and redundant readings.
  10. Feb 20, 2021 at 2:17 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Customization settings that would normally require Toyota dealer intervention will likely require the professional-level software Techstream.
    Legitimate access to Techstream is far beyond the means of most hobbyists and private owners; think $$$$. Many Toyota (Tundra, T4R, Lexus) forum members have been successful with bootlegged versions of Techstream that can be made to work with a laptop and cables available on Amazon and eBay. The best of the working bootleg versions, and there are many imitators, can be $80.
    a522467[QUOTED][OP] likes this.
  11. Feb 20, 2021 at 2:29 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    You can customize settings, read and reset codes with Carista. You get a free trial period when you buy the device and then it works on a subscription basis. The only issue is it is rather slow.
  12. Feb 20, 2021 at 4:06 PM
    a522467
    Michelle
    Ohio
    Have you tried to monitor real-time transmission temps with that setup?
  13. Feb 20, 2021 at 5:51 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Yes, I have. I think it shows three trans temp sensor spaces- but I think that is the app default. I think the Tundra just has one. To monitor multiple sensors though you have to pay for subscription. You can read any live data for which there is a sensor through obd2 port. I don’t think it will show any for abs or trac systems since it can’t read abs.
  14. Feb 23, 2021 at 3:35 PM
    couchpotato013
    Screenshot of obdlink mx+
    Like said earlier, by default there are 3 sensors. Once the enhanced PIDs are scanned, it shows 2.
    Blue driver was unable to see transmission temps
  15. Feb 23, 2021 at 4:19 PM
    a522467
    Michelle
    Ohio
    I went with the $17 Veepeak mini WiFi scanner and OBD Fusion app ($10 + $10 Toyota upgrade). For $37 total, I’m monitoring all the data I wanted and a bunch more. Only downside so far is I need to remember to unplug it when not in use so I don’t drain the battery. Thanks to @jtwags and @snwbrdr852 from the Taco forum for the cool dashboards to start with; after a few minutes of minor tweaking, I got both trans temps working on my ancient iPhone. Spotify, Pandora, CarPlay, and other cellular and Bluetooth stuff started working again after I set a static IP address on the Veepeak. Still need to work on some of the other points, but I think this is going to be fine.
    https://www.amazon.com/gp/aw/d/B00WPW6BAE?psc=1&ref=ppx_pop_mob_b_asin_title
    Dalandshark and jtwags like this.
