Going back to stock
Discussion in '2nd Gen Tundras (2007-2013)' started by Haroldgomez18, Aug 23, 2016.
  1. Aug 23, 2016 at 8:00 AM
    Haroldgomez18
    Haroldgomez18 [OP] New Member
    2013 toyota tundra platnium
    image.jpg is there any way to go Back to stock after installing a suspension lift
  2. Aug 23, 2016 at 8:06 AM
    Easy, put back on the OEM goodies.
  3. Aug 23, 2016 at 8:18 AM
    Haroldgomez18
    The place that put my lift on told me I couldn't go back to stock that like I think the sub Frame or something like that came out in three pieces.
  4. Aug 23, 2016 at 8:41 AM
    Why are u wanting to go back to stock?
    Black Wolf likes this.
  5. Aug 23, 2016 at 8:58 AM
    ToyotaTundraMike
    2015 Tundra
    You wouldn't be able to fit those rims/tires with stock suspension, but assuming you'll be putting the originals back on I don't see why they couldn't just put your stock suspension back on if they gave it back to you?
  6. Aug 23, 2016 at 9:33 AM
    There is a way, but oh will it cost you to weld back in what was cut out.
    Leave it alone or sell as is.
  7. Aug 23, 2016 at 11:01 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    If they did a drop bracket lift and cut out the crossmember like many of them require then there wouldnt be any going back to stock, at least not without a LOT of effort. You'd have to source the cross member from another truck getting the same drop bracket lift installed (maybe you can work a deal of giving someone your lift in return for their stock parts during the swap?) and then re-weld the cross member back in on your truck. Plus you need the stock coilovers and spindles in the front, and smaller tire setup as well.
  8. Aug 23, 2016 at 11:04 AM
    Sounds like a lot of fun..
    Relentless[QUOTED] likes this.
  9. Aug 23, 2016 at 11:55 AM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    Don't do it!
    Law323 likes this.
  10. Aug 23, 2016 at 1:23 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    seems like a lot of threads today that have the same answer... too much trouble. sell and buy your truck the way you want it or leave it as is.
  11. Aug 23, 2016 at 1:57 PM
    Haroldgomez18
    Just want to change it up honestly. Do something different with it. But yes I would be getting a whole new set of wheels and tires.
  12. Aug 23, 2016 at 5:07 PM
    Law323 likes this.
