Go Rhino RB20
Discussion in '2.5 Gen Tundras (2014-2021)' started by Borgs, May 19, 2018.
  1. Aug 1, 2021 at 8:03 PM
    #181
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    I'm reading this after the fact. Makes me feel a bit like a rebel....
    I didn't check anything. Yep, instructions said double cab for my crew max. Yep, instructions showed lock washers ..
    I just aligned the brackets and started putting stuff together and see if it all worked out. It did.
    But yeah, seriously, Go Rhino needs to update their stuff can't be expensive to print off a piece of paper. ..
    Also, mounted backwards because that's how they should be
    Rica25, jr1016 and Pillslinger like this.
  2. Aug 13, 2021 at 8:36 AM
    #182
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    I was thinking of switching to the RB20s. I was wondering how they would look on my truck then I found your pics. I absolutely know now! thanks a lot man
  3. Aug 26, 2021 at 8:46 PM
    #183
    Borgs
    Borgs [OP] New Member
    PA
    Sorry, just saw this. Yes indeed bro. I still have them on. Love them. And surprisingly durable for price and intended use. I don’t wheel. But. Do hunt and go off road in fields and mountain power lines and roads. Pennsylvania salt. Just under carriage wash as much as possible.
  4. Jan 19, 2022 at 4:31 PM
    #184
    rattmobbins
    rattmobbins New Member
    2021 Platinum 4x4
    Been seeing for a little while on the Go Rhino website that they have a "slim" RB10 and RB20 listed for the Tundra, but no real info on it. Called today and found out they are real, they are actually going to be available in the next couple weeks, and they are 5" wide instead of 6.5" or 7" like the regular steps. I went ahead and ordered up a set!
    I'm pumped! Love the look of the RB20, but they stick out WAY too far on a stock-ish truck IMO. Can't wait to get the slimmer ones!!!
    Skew12 likes this.
  5. Jan 20, 2022 at 4:32 PM
    #185
    baron
    baron New Member
    Brett
    2021 TRD Pro
    You have got to be kidding me! I put my "regular" RB20s on a couple weeks ago and the first thing I thought was that they need to be slightly narrower unless you're running a more aggressive wheel and tire combo. I did not even notice a "slim" option. I'm not going to swap them out, but interested to see what yours look like!
    rattmobbins[QUOTED] likes this.
  6. Jan 20, 2022 at 4:59 PM
    #186
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Same post some pics when you get them.
    Also would it be a good idea to have stainless steel bolts vs the ones they provide? I drive up north a lot during the winter months and all that salt and brine eat everything.
    rattmobbins likes this.
  7. Jan 20, 2022 at 5:08 PM
    #187
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Mine are on going on 5 years. No lock washers, just the supplied with the flat. No issues, no worries. GREAT RB's
  8. Jan 20, 2022 at 5:31 PM
    #188
    paulbk
    paulbk New Member
    With higher offset rims the wideness of the steps are definitely noticeable.
    But once lower offset rims are installed, the boards really flow well.
    I have them installed “backwards” since day one.
    2D08233F-2554-4007-9F0B-E6AB19447720.jpg 45E8F960-DA2A-4418-A3AD-961275395559.jpg 1B7EBA84-A508-474A-97FA-5733D631A4D4.jpg 1A94531B-AC1D-4164-8F99-08BEE1731821.jpg 6F2F49BF-0E33-4460-B865-BA81992D23BC.jpg 5D55C1AC-DE2A-4518-9C0D-FE07FFBBD5D9.jpg 64633EFB-14A2-4529-A5E1-00ED2B0A35D5.jpg D839FE13-61A2-4BA7-8978-7598E5FAD7FD.jpg
  9. Jan 20, 2022 at 6:58 PM
    #189
    baron
    baron New Member
    Brett
    2021 TRD Pro
    Exactly right. I also installed mine backwards. I think it makes more sense.
    Now, does a $450 set of running boards warrant me spending $2-3k on wheels and tires haha....
    hANNAbONE likes this.
  10. Jan 20, 2022 at 7:17 PM
    #190
    Bulldog9
    NOVA
    To each his own, I put them on with the wide section forward. Works great for me. IMG_20211106_142736065.jpg IMG_20220103_220829258.jpg
  11. Jan 25, 2022 at 10:03 AM
    #191
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    Hey everyone, new to the forum, but wanted to get in on the RB20 slim chat. I've been looking at getting the RB20s, but was really excited when I saw the new slim option coming. However, I just finished a chat on the Go Rhino site and they confirmed that the new slim ones should be available around 2/18, but they will still have a taper and that the are 5.5 inches wide in the front and 2.5 inches in the back. I was excited about a slimmer option, but that amount of taper seems a bit extreme to me. Now I'm back to thinking of getting the regular RB20s. Anyone else think a 3 inch difference from one end to the other would look a bit weird?
    Skew12 likes this.
  12. Jan 25, 2022 at 6:31 PM
    #192
    baron
    baron New Member
    Brett
    2021 TRD Pro
    That seems pretty aggressive to me as well. Still curious to see them installed, however.
    I will say, I've had my regular RB20s on for a few weeks now and I don't even notice the width anymore. I think it's one of those things you stare at initially and like an hour later you no longer care. They look good and function well.
    LR23[QUOTED] likes this.
  13. Jan 25, 2022 at 6:56 PM
    #193
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    I had a set for about eight months until I realized they’re worthless off-road. I sold them and I’m getting sliders now. They’re awesome for day to day use though. Especially the bed-liner coated ones.
  14. Jan 25, 2022 at 8:58 PM
    #194
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    I agree, I would like to see them on. I’m kind of now leaning back to the original RB20s given the taper is less drastic on those. My truck came with W drop steps that I really like, but I keep coming back to the Go Rhinos. Looking forward to pics of the slim ones.
  15. Jan 26, 2022 at 8:15 PM
    #195
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Watching this thread to see some of the narrow RB20's installed. The regular RB20's are indeed wide and provide a substantial platform for stepping in and out of the Tundra. If you like to step out of the truck, bypassing the step, then they are a bit wide for my leg length (32" inseam). So, I step in and step out using these steps. They are excellent for the intended purpose. One of the unexpected benefits of the RB20's is the protection from parking lot shopping carts and adjacent car door dings.
    TransplantTundra, hANNAbONE and LR23 like this.
  16. Jan 27, 2022 at 5:46 AM
    #196
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    I've been trying to decided between RB10's and the Tygers. But with a slim option...RB10 slims might be in the lead now.
  17. Jan 27, 2022 at 6:24 AM
    #197
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    As much as I liked the RB20’s being anal like i’am Lol. After having to return them because I was not happy with the finish and especially the stuff they put down on our roads in Pa and also how close they sat to the truck to get in between to clean the rocker jams I chose the Tyger steps. I had them on my 4runner Pro for years but a different design and held up without getting any rust. As you can see I can get in there to wash that area really well.
  18. Jan 27, 2022 at 6:40 AM
    #198
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    Awesome truck man, Army Green looks so killer. I have a Pro in Lunar Rock, but always love pics of Army Green ones. Great pic of the RB20s too. I'm trying to decide between keeping the W drop steps that came on mine, or switching to Go Rhinos.
  19. Jan 27, 2022 at 7:58 AM
    #199
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    The one and only problem I've had with my RB20's is my dog has gotten her nails caught in the little slots when trying to get into the back seat. Good lord the pain that must cause her and yelping like you've never heard. Yes she gets her nails trimmed every three weeks and she's 75lbs so that's a lot of weight on on one paw nail getting caught.
    I now have to place a board down on the running board so she'll be confident in getting in the back seat. Besides that I love my RB20's.
    GELCW, Skew12 and TelemarkTumalo like this.
  20. Jan 28, 2022 at 1:13 PM
    #200
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    I installed mine this last weekend. So far so good. I like they way they look and now my wife can get in without jumping into the passenger seat!
    superdenk and hANNAbONE like this.
  21. Jan 28, 2022 at 5:42 PM
    #201
    rattmobbins
    2021 Platinum 4x4
    I called and ordered my set over the phone and "Michelle" (think that was her name) told me they're 5.5" at the widest, and 4.5" at the narrowest. That seems a LOT more likely than 2.5". 2.5" isn't even a side step. It would barely clear the rocker panel.
    hANNAbONE and LR23[QUOTED] like this.
  22. Jan 28, 2022 at 6:26 PM
    #202
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    Yeah that makes a whole lot more sense. I asked the person I chatted with twice and they confirmed two times, but glad to hear that’s not the case. I probably should have just called to confirm. These are back on my list now, thanks for the info. Make sure and post some pics when you get yours on.
  23. Jan 28, 2022 at 6:28 PM
    #203
    SouthWestGA
    SouthWestGA New Member
    Just get them lol.
    My wife hates driving my truck but absolutely lives my RB20 running boards.
    TelemarkTumalo likes this.
  24. Jan 28, 2022 at 7:18 PM
    #204
    rattmobbins
    2021 Platinum 4x4
    Of course!
  25. Jan 30, 2022 at 11:02 AM
    #205
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    This is with SCS +25 offset. I installed them backwards. Also a good defense from door dings.
  26. Jan 30, 2022 at 5:07 PM
    #206
    Borgs
    PA
    Dudes, stop overthinking this. They are running boards, on a truck. I have had my 20’s, backwards, on my 2017, for several years, and they are awesome. Cheap, durable, look good. Not sliders of course. Stop overthinking this.
  27. Feb 11, 2022 at 6:26 PM
    #207
    localmotion
    localmotion New Member
    anyone have a picture of the slim Rb20s installed?
  28. Feb 11, 2022 at 6:48 PM
    #208
    rattmobbins
    2021 Platinum 4x4
    My slim RB20's shipped yesterday and will be here Monday. Pics as soon as they're installed!
    GELCW and LR23[QUOTED] like this.
  29. Feb 11, 2022 at 7:21 PM
    #209
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    Just checked the Go Rhino site and the new slim line RB10s and RB20s are
    Nice! I was on the Go Rhino site yesterday and saw they were available now. Can’t wait to see them!
  30. Feb 12, 2022 at 12:55 PM
    #210
    dystepanov
    dystepanov New Member
    Hey guys i bought some rb20s bedliner sprayed finish and didn’t like how they looked installed but my left some running board came with a slight chip of the bedliner finish and company didn’t wana take them back since they were installed.. I payed 750 for both, selling just the left side for $100 no brackets. If anyone is interested let me know.
