Go Rhino RB20
Discussion in '2.5 Gen Tundras (2014-2021)' started by Borgs, May 19, 2018.
  1. Aug 20, 2020 at 1:05 PM
    #91
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Can you just drill the rivets out on the badges to remove them? Wondering if the bedliner is sprayed on before the badges are applied. Looks that way but can't say for sure.
  2. Aug 20, 2020 at 4:22 PM
    #92
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I drilled them out and there is liner under the logos.
  3. Aug 20, 2020 at 4:26 PM
    #93
    AggiePhil
    College Station, TX
    Awesome. Have a photo of what it looks like without the badge but with the holes?
  4. Aug 20, 2020 at 4:28 PM
    #94
    Crunch527
    Iowa
    Honestly you cant really see the hole unless you are looking for them...
    AggiePhil likes this.
  5. Aug 20, 2020 at 4:29 PM
    #95
    Crunch527
    Iowa
  6. Aug 20, 2020 at 4:31 PM
    #96
    Crunch527
    Iowa
    I put mine on with narrow end up front...that’s where the badge was...if you look close you can see the holes...inconsequential in my opinion.
  7. Aug 20, 2020 at 4:34 PM
    #97
    Crunch527
    Iowa
    I wanted the wider part in the rear for the dogs and kiddos...plus they are wide and I was scraping the back of my leg on them. Overall I am happy with them. Been on the truck about 2 years.
  8. Aug 20, 2020 at 5:03 PM
    #98
    AggiePhil
    College Station, TX
    My dogs and kids have smaller feet than me so I'll probably install them normally.
    Side note... What color is your Tundra? Sunset Bronze Mica or Smoked Mesquite?
  9. Aug 20, 2020 at 6:28 PM
    #99
    Crunch527
    Iowa
    Bronze Mica...2014
  10. Aug 20, 2020 at 8:00 PM
    #100
    Borgs
    Borgs [OP] New Member
    PA
    I drilled mine out. But I had the powder coat finish. I filled the holes with a black poly caulk. Still looks great after 3 years.
  11. Oct 16, 2020 at 6:54 AM
    #101
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    B84C3C63-38EC-4E72-A75A-1D075510B2D4.jpg B84C3C63-38EC-4E72-A75A-1D075510B2D4.jpg 56418B20-C0B6-4E54-BB9E-B048140E9DB8.jpg 569BB3D6-8150-408E-B2E0-EE621B6DF863.jpg B84C3C63-38EC-4E72-A75A-1D075510B2D4.jpg 56418B20-C0B6-4E54-BB9E-B048140E9DB8.jpg 569BB3D6-8150-408E-B2E0-EE621B6DF863.jpg Finally pulled the trigger on the RB20’s and they arrived this week. A couple issues:
    It came with brackets that were boxed with instructions for double cab but I ordered a crewmax. I checked with GoRhino, first guy said double cab and crewmax might be different brackets, second guy said they were the correct brackets. Hopefully the second guy is correct, guess we’ll see when I install.
    2nd issue: They came packaged pretty well except for a couple spots that had some rubbing in transport, see pics. The lip on the inside edge of the boards must have been hitting each other and causes some scratches in the powder coat. Would you send these back over this? I’m worried the next set could be even more damaged than these.
    Anyone use a touch up paint or something to cover the scratches before installation?
  12. Oct 22, 2020 at 12:33 PM
    #102
    jlarkin1918
    Jared
    This thread might be dead but I’ll try anyway.
    I just mounted these on my 2020 crewmax and I’ve been tinkering with how to adjust these to look best. I have them on forward wide side up front for now but before I play with that, a question on the brackets.
    Does it make difference which side you use the brackets on? Do people have them mounted so the flat side of the bracket is facing front of the truck or facing the back?
    I also have been trying to figure out if there is way to adjust these so the brackets fall in a spot on the board that is solid so you can’t see them through the holes, no luck so far, seems like I always will have one bracket that is showing. I even tried reversing the center front bracket by switch sides of the truck but it still didn’t line up well with board holes.
    Is there a magic trick to this or do I need to live with it and stop being ocd?
  13. Oct 22, 2020 at 1:11 PM
    #103
    PNW1794
    PNW1794 New Member
    Woodinville, WA
    2019 Smoked Mesquite 1794
    Go Rhino Running Boards - RB20 Bedliner Coating Line-X Spray-in Bed Liner Tanneau Cover - BAKFlip MX4 Fuel Sledge 20x9 Wheels Toyo Open Range 275/70 R20 1.5" Front Level - Ruff Country Coil Spacers Front Window Tint TRD Air Intake Ronin Short antenna Console Organizer Back-seat USB charger De-chrome Black door handles Color match Mirror Caps Color matched Grill assembly/bulge Platinum Grill swap Wireless Charging Tray A Pillar Handle Rear TRD Sway Bar Engine Light LEDs (Warm White) from Matt Gecko LEDs
    I had a similar experience with my RB20s. I put the wide side forward and flat side of the bracket facing forward. No idea if that is correct, but worked for me.
    Not sure if there is a good way to line up the brackets so they don't show. I messed around with it for a while and never quite got it perfect so eventually just tightened everything down and called it a day.
    Let me know if you do find the sweet spot.:thumbsup:
  14. Dec 17, 2020 at 8:19 PM
    #104
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    GO Rhinos website is offering 25% off with code FIRSTHERO for First Responders. Another member posted it on another thread.
    plumber802 and BobsYourUncle like this.
  15. Dec 18, 2020 at 5:26 AM
    #105
    SouthWestGA
    SouthWestGA New Member
    Dang it i can’t get Paypal to work on their site
  16. Dec 18, 2020 at 5:39 AM
    #106
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I've had the RB10's in bedliner finish on my 2010 for about 4 years now. They are showing no signs of wear, plenty of grip and are still comfy on bare feet. I've had them in sand snow and typical east coast weather and they are holding up great.
  17. Dec 18, 2020 at 6:09 PM
    #107
    SouthWestGA
    Is anybody successful in getting Paypal checkout to work from the GoRhino website? Their online chat told me the Firsthero code stops tonight
  18. Dec 18, 2020 at 6:14 PM
    #108
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Couldn't get it to work in Microsoft Edge or Safari (both with and without ad blocking disabled) at all. It wouldn't even load it up. I think it's something weird on their site. I went ahead and just used AmEx on their site and it went fine (bought mine with different promo code, but that shouldn't matter at all).
  19. Dec 18, 2020 at 6:37 PM
    #109
    SouthWestGA
    Thanks for the reports!
    The online rep said they are having Paypal issues but they are still willing to give me a discount once the issue is fixed on their end in the future
  20. Dec 18, 2020 at 7:38 PM
    #110
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I just ordered mine. PAYPAL link was not working so I just used the regular VISA link. Went through no problems.
  21. Dec 20, 2020 at 5:25 PM
    #111
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Installed yesterday after a lengthy delay (first order lost by FedEx), but 2nd order arrived in good shape. Two boxes: one with brackets and bolts. The other with the boards. They were packaged and protected very well. There is a PDF instruction file that can be downloaded on the Go Rhino website but it is missing a page of the directions. And, the printed directions included in the box were for a Dodge, but there aren't many parts to sort out and everything fit. I'm impressed with the fit and finish. I slid them laterally on the brackets as a first trial. Figuring that this will give me a max. footprint and protect against parking lot door dings. I can loosen the hardware and slide them in-board maybe 3/4" or so.
    First impressions are:
    1. Steps are definitely an advantage for those of us who are vertically challenged
    2. They are very solid
    3. Underfoot traction is good. I got the bedliner finish and like sandpaper
    4. Still not convinced I like the looks of side steps. Function over form?
    5. The logo face plate is definitely going away.
  22. Dec 20, 2020 at 7:11 PM
    #112
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    @TelemarkTumalo those look good. If you decide you don’t like them and want to sell them, let me know.
    TelemarkTumalo likes this.
  23. Dec 24, 2020 at 3:48 PM
    #113
    YotaTruckLtd
    2014 MGM Limited CM
    Just received my RB20s. Packaging was very good and everything was well wrapped. Every piece is covered with the textured powder coating. I know some in the past said the underside and brackets were not. Can't wait to install them. A little more chrome delete.
    plumber802 and TelemarkTumalo like this.
  24. Dec 25, 2020 at 12:34 PM
    #114
    Tinnitus
    Tinnitus New Member
    Tinnitus
    2020 SR5 4x4 Crew Upgraded Off-Roaded
    Yota: I notice you have a CrewMax. Got a question.
    Did these boards come with an instruction sheet that said something like "CrewMax Installation Guide"? Or did they, for some strange, unexplained reason come with instructions that said "Double Cab"?
  25. Dec 25, 2020 at 1:24 PM
    #115
    YotaTruckLtd
    2014 MGM Limited CM
    Yes they sent me the Double cab version as well. I will look for exact instructions/video online just in case.
  26. Dec 25, 2020 at 1:59 PM
    #116
    TelemarkTumalo
    Mark
    Bend, OR
    You should be fine following the DC directions. Basically the same brackets and hardware. Just your boards are a little longer. Go Rhino seems to struggle a bit with the directions. Mine came with directions for a Dodge.
  27. Dec 26, 2020 at 9:13 AM
    #117
    Tinnitus
    Tinnitus New Member
    Tinnitus
    I ordered mine through CARiD, for a Crew Max.
    TWICE, GoRhino directly shipped me running boards for a Double Cab. No invoice. No indication on the exterior of the boxes which model was inside. Instructions only for Double Cab.
    I sent photos of parts numbers to CARiD both times, and they confirmed that I was sent the Double Cab running boards both times. CARiD has apologized profusely both times, but not a word from GoRhino.
    Two months into the process, I still don't have my CrewMax running boards. Pretty sure my card has been charged, though.
    Maybe the third time I'll be lucky.
  28. Dec 26, 2020 at 10:56 AM
    #118
    BobsYourUncle
    Were there part #'s on the outside of the boxes? Mine had the double cab instructions as well, but I checked with GoRhino and from the part #'s on the boxes, they had sent the proper ones. I verified it with their website info as well.
    (Attached a photo of the box part # for reference.)
  29. Dec 26, 2020 at 5:46 PM
    #119
    Tinnitus
    Tinnitus New Member
    Tinnitus
    I took photos of the labels on the outside of the box, and of the part numbers on the parts inside and sent them to CARiD. They coordinated with GoRhino for GoRhino's return authorizations and UPS shipping labels both times.
    So, GoRhino is apparently saying to CARiD, "Yeah, we sent the wrong ones twice."
    I even sent a photo of my VIN to CARiD the first time, at their request, to prove ... I don't know what. Their computer system and the purchase confirmation showed I ordered CrewMax.
    I can't believe they will do this a third time (I'm waiting on delivery), but then I would never have believed they would do it a second time.
  30. Jan 24, 2021 at 9:53 AM
    #120
    hennly
    hennly New Member
    nice setup. Can you give specs on your setup?
