Go Fast Camper........anyone have one?
Discussion in '2.5 Gen Tundras (2014-2021)' started by CorsoTundra, Jun 5, 2019.
  1. Apr 13, 2021 at 3:47 PM
    #121
    pandapro
    pandapro New Member
    I had an august spot and then came across this one and jumped on it no more than 2 minutes after the seller posted it. Transfer was completed today and options have been selected :D
  2. Apr 13, 2021 at 4:35 PM
    #122
    WVTRDPRO
    WVTRDPRO New Member
    WV
    2016 TRD Pro DC White
    V1 Unit 347
    Picked up in September of 2019
    I scheduled my hinge replacement for August so a big trip with the family is currently being planned to wonder around Montana for a few weeks.
    MTRock, pandapro and CorsoTundra[OP] like this.
  3. Apr 13, 2021 at 4:36 PM
    #123
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    clean. been following ur build on the GFC forums. very nice setup
    WVTRDPRO[QUOTED] likes this.
  4. Apr 13, 2021 at 4:41 PM
    #124
    WVTRDPRO
    WVTRDPRO New Member
    WV
  5. Apr 13, 2021 at 4:43 PM
    #125
    pandapro
    pandapro New Member
    Deets on that drawer system? Looks great!
  6. Apr 13, 2021 at 4:47 PM
    #126
    WVTRDPRO
    WVTRDPRO New Member
    WV
    @pandapro
    It’s a diy build I did after 2 other previous iterations. I’m hoping this is the “final” design I will stick with for a while. You can see some more pics and details on my build thread if you’d like.
    pandapro likes this.
  7. Apr 13, 2021 at 4:50 PM
    #127
    pandapro
    pandapro New Member
    Nice work! I’m looking for something simple just like yours in case I need to stealth camp.
    The build thread in the GFC forums? Will do a search.
  8. Apr 13, 2021 at 5:05 PM
    #128
    WVTRDPRO
    WVTRDPRO New Member
    WV
    @pandapro
    I have a build thread on both the GFC forums and on here.
  9. Apr 14, 2021 at 12:17 PM
    #129
    CorsoTundra
    CorsoTundra [OP] This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    What are most of you running for rear suspension with your Go Fast? I have the Toytec shackles set at 1.5" I'm debating on add-a leaf or the OME Dakar pack.
  10. Apr 14, 2021 at 1:46 PM
    #130
    WVTRDPRO
    WVTRDPRO New Member
    WV
    Icon RXT leafs set at option 3 and CoachBuilder +1 shackles. I have a lot of weight in the rear with my gear, drawers, fridge, and water storage. The leafs seem to be handling it pretty well. I was at option 2 on the leafs when I first got the camper and noticed them starting to flatten out when I added more gear to the bed.
  11. Apr 14, 2021 at 1:56 PM
    #131
    pandapro
    pandapro New Member
    I have the RXT leaf pack as well. I haven’t installed them yet, but I was planning on using the stock shackles. Is there any negatives to using the stock shackles? Or on the flip side, is there any benefit of going CB?
    Probably going to run option 2 with the RXTs.
  12. Apr 14, 2021 at 2:03 PM
    #132
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    Not needed If you’re not hauling a bunch of stuff. Stock with basic camping supplies is more than adequate.
  13. Apr 14, 2021 at 2:14 PM
    #133
    pandapro
    pandapro New Member
    I guess I could just add them later if I find I need them. I’ll probably have 700# back there when loaded and probably 400# as a daily.
  14. Apr 14, 2021 at 2:47 PM
    #134
    WVTRDPRO
    WVTRDPRO New Member
    WV
    I had the stock shackles and the rxt leafs at option 2 when I got the camper installed. That rode fine and didn’t have too much sag. When I started adding more static weight I noticed the leafs start to sag. The big thing that also happened was the rear eyelet bushing in the RXT leafs started shifting out of the eye of the leaf. That is why I swapped to the CoachBuilder shackles and poly bushings that come with them. I didnt really want the lift they provide, just the stiffness and tighter fit than stock shackles.
  15. Jul 30, 2021 at 7:10 AM
    #135
    rhino8541
    rhino8541 New Member
    Ryan
    I’ll be picking up my GFC at the end of August. :bananadance:
