Glue removal??
Discussion in 'Detailing' started by JimBeam, Apr 10, 2020.
  1. Apr 10, 2020 at 11:50 AM
    JimBeam
    JimBeam [OP] Moderator Staff Member
    South Carolina
    2015 Limited
    Picked up a 2015 Limited last week
    First order of business was to remove the chrome tailgate letters. They appear to be foam backed with glue on the foam. I was able to remove the majority of the foam and all of the letters, however a good portion of the glue and some foam has hardened and I cannot for the life of me get it cleaned up.
    I have tried mineral spirits, WD40, goo gone, a plastic non marring scraper and my fingernails...I have applied heat from a hairdryer and let it sit baking in the sun before working on it
    Any suggestions??
    Vince likes this.
  2. Apr 10, 2020 at 12:11 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Try a 3M Eraser wheel. Removed my pinstripes with one. Used my cordless drill. Make sure you charge them up, it will burn a battery up quick :eek:. I was pleased with the results
    JimBeam[QUOTED][OP] likes this.
  3. Apr 10, 2020 at 12:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  4. Apr 10, 2020 at 12:21 PM
    JimBeam
    South Carolina
    2015 Limited
    Those safe for clear coat?
    I looked at them, but they're pricey and I wanna make sure they work and wont damage my paint
  5. Apr 10, 2020 at 12:22 PM
    JimBeam
    South Carolina
    2015 Limited
    Tried it
    No effect
  6. Apr 10, 2020 at 12:34 PM
    rons23
    Ron
    Kill Devil Hills
    Yes there safe, shop around, I got one off Amazon for around $20. There are cheaper options vs 3m. I used my wife's nail polish remover to clean the residue up. Acetone won't mess with your clear coat either.
  7. Apr 10, 2020 at 12:37 PM
    rons23
    Ron
    Kill Devil Hills
  8. Apr 10, 2020 at 12:41 PM
    BoTheTundra
    BoTheTundra New Member
    Thomas
    2007 tundra TRD sr5
    Lift with rims and tires, exhaust mirrors skid plate, whole interior sound system and head unit
    Be careful on some, the head and speed could "burn" the paint, I have a red caddy that had a mad yellow tint after taking the adhesive off from the CTS letters on the trunk
    JimBeam[OP] likes this.
  9. Apr 10, 2020 at 12:42 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I used one of these:
    jewsNbrews likes this.
  10. Apr 10, 2020 at 12:49 PM
    JimBeam
    South Carolina
    2015 Limited
    That's kind of been my concern but I figure the pricey 3M is less likely than the $10 Amazon one
  11. Apr 10, 2020 at 12:49 PM
    JimBeam
    South Carolina
    2015 Limited
    Nope! Unless you're gonna bring him and supervise him
  12. Apr 10, 2020 at 12:51 PM
    Squatting Pigeon
    Holden
    North Texas
    Pay me in beer and him in chicken nuggets and you might have yourself a deal.
  13. Apr 10, 2020 at 12:51 PM
    BoTheTundra
    Thomas
    2007 tundra TRD sr5
    Mine is the one snap on carries for about 15 bucks, just know it's made to be softer than clear coat so it'll shoot rubber off the wheel when used so it's ok, just be slow and watch the speed, I'm seeing if some light wet sanding would make the yellow go away and I'll post back when I do it
  14. Apr 10, 2020 at 12:52 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    If all the foam is gone, just tacky sticky adhesive, try goo be gone. Worked great for me. Since its a vertical side, get a rag saturated in it and hold against it to soak for a few minutes. Then rub it all off.
    Never mind see you tried it already.
  15. Apr 10, 2020 at 12:54 PM
    rons23
    Ron
    Kill Devil Hills
    It's pretty much same material, your paying for the name. Just my .02
  16. Apr 10, 2020 at 12:58 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    That's the eraser wheel I also used and had zero issues. Just don't go crazy with a high speed and you'll be fine. I used Goof Off spray to get the remaining residue off and then followed with a quick soap and water wash and spray wax.
  17. Apr 10, 2020 at 1:02 PM
    rons23
    Ron
    Kill Devil Hills
    Yes I used something similar, wish I would've found this one. Yes speed is critical, but there's no need to put a ton of pressure on it.
  18. Apr 10, 2020 at 1:05 PM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    Looks like you've tried what I used to successfully remove the chrome badges. It takes time, perseverance, and patience. Use WD-40, Goof-off, or goo-gone and scrape with a plastic scraper. Clean with an all-purpose surface cleaner, then repeat. On some larger spots, I would soak a paper towel with goof-off, tape it over the sticky spot, and let it soak for a bit.
    Edit: I should add that there are two formulas of goof-off. The one in the metal can is basically acetone, the spray bottle is less harsh. Use the spray.
  19. Apr 10, 2020 at 1:09 PM
    Grumpy Uncle
    Pat
    CO
    I have used this in the past.
  20. Apr 10, 2020 at 1:14 PM
    JimBeam
    South Carolina
    2015 Limited
    Thanks guys...going to pick up one of the wheels shortly
    rons23 likes this.
  21. Apr 10, 2020 at 1:55 PM
    daria
    daria N+1 Staff Member
    Same.
    The body shop just removed all other badges as a courtesy for me and they used a rubber wheel. I think I can handle the tailgate letters. Changing from black and chrome tailgate letters to blacked out American flag.
  22. Apr 10, 2020 at 3:17 PM
    JimBeam
    South Carolina
    2015 Limited
    Ok rubber wheel works wonders
    Best I can tell, previous owner used gorilla glue to secure the chrome letters
    The 3m wheel took it right off with ease and a little goof off to help
    RangerBP, TRDFerguson and jewsNbrews like this.
  23. Apr 10, 2020 at 3:19 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Magic eraser and wd40
    FrenchToasty likes this.
  24. Apr 10, 2020 at 5:39 PM
    JimBeam
    South Carolina
    2015 Limited
    And new letters are on
    jewsNbrews and TRDFerguson like this.
  25. Apr 10, 2020 at 5:51 PM
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    I have had good luck with the 3M adhesive remover/cleaner in the past. It was about $20 bucks a can but worked really well.
