Getting scared...truck,snow
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zum, Jan 7, 2022.
  1. Jan 8, 2022 at 6:59 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Skimmed over that other thread, some foolishness(deserved) but was a few things that caught my eye.
    Couple guys mentioned in 2wd turn traction control off, some guys seem to be driving fine with the nannies off.
    I know, take it with a grain of salt. Im old enough and poor enough that most my vehicles never had any abs or traction control or it wasnt working.
    Over 35 years of winter driving, never had a vehicle pull that quickly to the left(2 times now),no abs or traction lights before it happened(i know it can happen quick) ...anyways just venting. Again, totally my fault, to fast for driving conditions.
  2. Jan 8, 2022 at 8:09 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Driving with the nannies off is fine until it isn't. Having the nannies on gives you that second to react to black ice or snow drifts, without them you're lighting up the rear tires before you can react and in a very bad predicament. My thing is if I think 70-80 km/h is the max I can do safely, I'm in 4wd. It means there's snow or ice around for sure, if there's not I'm doing 100 km/h or more on the highway.
    SLA10 and HulkSmurf14 like this.
  3. Jan 8, 2022 at 9:47 AM
    Ericsopa
    Ericsopa Old man and the sea
    I only turn nannies off on dry roads.
  4. Jan 8, 2022 at 10:10 AM
    Wallygator
    Still think it was the snow on the bridge that pushed you over. Don't care what anyone else says even the OP, I know I'm right!
    batman900 likes this.
  5. Jan 8, 2022 at 10:36 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    You were higher than 35 PSI before? Recommended on door has that in the back and 33 up front.
  6. Jan 8, 2022 at 11:05 AM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    Don’t be afraid to use your 4wd. Use it up, it’s meant to be used. Like others said good tires too. Weight in bed, I usually don’t but. Even if experienced, winter driving is obviously dangerous, sometimes shit just happens, just gotta try to think what could I’ve done different for next time. Black Ice is a killer though and Bridges freeze first, just can’t get complacent and never judge road conditions based on how fast others are driving
    SLA10 likes this.
  7. Jan 8, 2022 at 12:10 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I'm still a little confused, did the steering wheel move to the left and drive the front end over the center line? Did the ass end break lose and drift over the center line or did the whole vehicle just slide 3 ft to the left? Did traction control lights flash? Were you in any kind of bank, lean or slight curve? Any chance you were on the brakes when you transitioned to bridge deck? Sounds like you just hit an icy spot, with too much speed. Bridges freeze up easily due to cold air passing above and below, wind chill factor is more reliable than temps with bridges.
  8. Jan 8, 2022 at 12:33 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    My dad runs a set of Michelin ice x on his Accord year around and hasn't had too much problem with wear in the summer. He used to drive 180 miles a day but now that he's retired he has just given up on swapping them out.
  9. Jan 8, 2022 at 12:56 PM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2wd pickup in the snow? Rather be driving a Camry.
  10. Jan 8, 2022 at 1:00 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I didn't read all the posts but I don't get it either
    Use your brain. Slow down on ice. Slow down on bridges. Use 4HI on snow/ice, especially straight aways.
    If it's pulling to the side for no reason, have a garage look at it.
    SLA10 likes this.
  11. Jan 8, 2022 at 3:00 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Weight for it...o_O
  12. Jan 9, 2022 at 9:34 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Toyota's answer to locker rear end is to apply brakes on tire loosing traction so the opposite side tire would start pulling more stopping the spinning tire. I think what is happening you're right rear tire is braked and is the tire that normally pulls the most due to configuration of differential. So due to slippery road conditions when brake is applied it pulls front of truck around to left. I don't need to tell you this is extremely dangerous with oncoming traffic and also dependent on road conditions as to how far left the front will move. I live in south east Texas with last snow being in 2008 so we don't have this issue, also because front of truck is in mud, sand or wet grass so when brake is applied to spinning rear tire it is not strong enough pull front around.
    In order to solve this problem you can run in 4x4, put weight in front of bed or turn nannies off that would stop the traction braking.
    Good luck,
  13. Jan 9, 2022 at 9:44 AM
    belanger9
    Edmonton, AB
    A bunch
    I've had the TC kick in a few times when I'm testing the road conditions and the front end barely moves. Really feels like the system not only brakes the rear wheel thats spinning, but the VSC works on the front end as well to keep the vehicle attitude staying as straight as possible
    JLS in WA likes this.
  14. Jan 9, 2022 at 10:22 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I don’t understand how people think the traction control is causing this. The TC saves my ass yesterday when i hit a glaze of black ice yesterday coming up the Lewiston grade.
    If traction control systems and ABS were so dangerous or of no use, you wouldn’t get insurance discounts for having them.
  15. Jan 12, 2022 at 6:59 PM
    Zum
    Zum [OP] New Member
    NS Canada
    Sorry for the late replies, you know life and all.
    Again, my fault to fast for roads conditions.
    1 inch of snow on the road, tempeture falling from above freezing to below, going up a slight grade, 45mph, no brakes applied, cruise off, in 2wd(truck is a 4wd),truck does a hard quick left(front end) 3ft or so ...Im counter steering, sliding sideways 50 or more feet. The road was alittle hollowed(hump in the middle), most likely what happened , lost traction right drivers side rear, left rear became power wheel grabbed traction and pulled me over? No never noticed any lights at the time, was trying to gain control.
    Ive been trying to re create the issue, roads have been a mess up here lately, cant do it. Step on it traction control does its thing but no hard movements any direction.
    Ive been driving with traction control off in 2wd but most likely will just use 4wd in those type conditions.
    It was just the quickness of the left that bothers me, thought maybe i had a truck issue....most likely just a driver issue.
    Like to add...i really dont know what happened
    Thanks for the replies
    Wallygator and HulkSmurf14 like this.
  16. Jan 13, 2022 at 5:37 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Still sounds odd to me. Almost sounds like something is off on your truck. Have you checked for sticky calipers or anything else in the suspension?
  17. Jan 13, 2022 at 9:19 AM
    Legbuh
    Legbuh New Member
    2019 Crewmax Limited
    If it's that slick, I take my Kia Stinger GT2 AWD out instead of my Tundra (yes, it's 4x4). I didn't realize how much better my Frontier with offroad package was in snow than m 19 limited Tundra. But the Stinger is a beast on ice/snow. :)
  18. Jan 13, 2022 at 9:28 AM
    GoatMilker
    GoatMilker New Member
    2016 Tundra SR5 Crewmax
  19. Jan 13, 2022 at 9:30 AM
    #49
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is this the same poster as the tundras are horrible in the snow thread????
  20. Jan 13, 2022 at 9:32 AM
    #50
    GoatMilker
    If i leave my truck in 4x4 mode, as soon as i hit the pavement without snow and turn, the front dif locks both wheel together.
    i have to drive in 2 wheel drive and only turn on 4x4 if i am stuck.
    I complained to Toyota and they said that's normal? (Sorry, did not mean to hi jack the thread)
    So how did you do 250k miles in 4x4?
  21. Jan 13, 2022 at 9:37 AM
    #51
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Snow tires ! I have them, could be 10 one day and 45 the next as Connecticut is not a wicked winter place, but if it is , I'm prepared.
  22. Jan 13, 2022 at 11:16 AM
    #52
    Adventurepew
    Adventurepew New Member
    2018 tundra trd offroad crewmax
    What do you mean the front diff locks both wheels together ? 4x4 is fine to use on dry pavement we just have to be careful when it's perfectly dry out we don't go blasting around tight corners roads which can cause diff binding, ( engineering explained has a good video on YouTube ) but if its that dry you won't need 4wd, if there is any chance of ice it'll be wet/ snowy / slippery and 4wd is fine.
    if you have some issues with your diff get it checked out, by a diff shop not the Toyota dealer.
  23. Jan 13, 2022 at 6:28 PM
    #53
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Is the truck always pulling the same way? If so, you could have an alignment issue. On ice, I'd imagine even a small alignment error could cause problems. There are ways to check the alignment yourself, but I'll leave advice on that to others. If your tires are worn, rotating them might help as well.
  24. Jan 13, 2022 at 7:53 PM
    #54
    Ronster
    Ronster New Member
    Ron
    2017 Tundra Crewmax
    If there is any snow or ice on the road put it in 4Hi. Good winter tires make all the difference in the world too. Remember that bridges freeze long before the roads will so ways be leery hen transitioning onto a bridge in near freezing temps. My truck goes in 4Hi usually around late October and stays there until April or so. No noticeable difference in mpg or other wear. Of course that is Alaska winter driving but you get my jist.
  25. Jan 13, 2022 at 8:12 PM
    #55
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    You answered your question. Slow down, keep in 4H if the roads are snow covered. But mostly slow down. Hitting patches of ice under the snow or loose stuff combined with momentum and grade when driving too fast, or not in 4wd, and you can expect to be sliding all over.
  26. Jan 15, 2022 at 10:07 AM
    #56
    Zum
    Zum [OP] New Member
    NS Canada
    Let me say, I dont dislike my truck., things a tank. Last night, I was on call and had to drive in blizard conditions, through unplowed roads. 2' plus drifts,then bare icy roads, very high winds, white outs...4 high and the Wildpeaks did fine.
    My concern when i started this thread was the quickness of the hard left(although it only happened twice in 3 years, didnt(doesnt)seem normal).Lots of hours, years driving and playing in the snow, it just didnt seem normal. I have new shocks all around(year or so) my leafs springs are weak for sure so there the next on the replacment list.
    Again , most likely all my fault, to fast and not in 4x4 at the time
    HulkSmurf14 and Wallygator like this.
  27. Jan 15, 2022 at 11:05 AM
    #57
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    It's almost impossible to say, what exactly happened. If you had alignment issues I would expect you'd realize it by third year. I wouldn't turn nannies off except in certain specific situations, usually off road or launches. But winter driving in a 6k lb truck is not the same as a car. With inertia and gravity and ice, things can get squirrelly quick. I would be in 4hi in snow. And add some weight over rear tires if you routinely get snow. But 4x4 isn't magic on black ice or icy conditions, once tires loose traction your going where inertia takes you. I lost a 69 T37 in New Hampshire back in the 80s on a banked curved overpass, I wasn't speeding, prob should of had winter tires, but was only stationed there for a few months. Lesson learned. 20220103_122917.jpg
  28. Jan 15, 2022 at 11:57 AM
    #58
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    Yep...same here in PA... But it didn't even have to be winter. time..... just say 'n :wave:
  29. Jan 25, 2022 at 11:11 AM
    #59
    Adventurepew
    As I posted earlier its not the vehicle it's just a flaw in rwd/ open differentials and lack of weight in the rear.
    Here is a good video of rwd trucks / vehicles going out of control when they hit an icy bridge deck.
    https://fb.watch/aM17ybcEq4/
