Getting a 6" - 7" lift?
Discussion in 'Suspension' started by Bari2008, May 9, 2017.
  1. May 9, 2017 at 4:21 PM
    Bari2008
    Bari2008 [OP] New Member
    Hey guys i need some advice on lifting my 2008 2WD Tundra. my truck is leveled with bilstein 5100 which is about a 2.5" front lift (pic attached). i will like to get my truck up to a 6-7" lift and will like to know if i can achieve this by installing the 3.5" CST spindles lift?
    I am also planning to lift the rear with 3" shackles.
    I will be getting 35" tires with 20x10 -12 offset fuel krank D517 rims.
    Will appreciate your advice.
    Thanks.
    Jsena likes this.
  2. May 9, 2017 at 4:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Welcome bro.. I don't know to much about getting more other than starting fresh, but the fellas here will chime in and give you their expert advice..
  3. May 9, 2017 at 4:26 PM
    Bari2008
    Thank you.
  4. May 9, 2017 at 9:35 PM
    Spacer lift??? Avoid if possible...its rough bouncy ride.. check out toytec.com (Boss Kit)
    Law323 likes this.
  5. May 9, 2017 at 10:48 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Boss kit isn't over 3 inches , right?? Or is that what he already has plus trying to add that??? Can you do that
  6. May 10, 2017 at 1:06 AM
    I mean i know he wants a high lift...but with the boss kit.. 35s will fit..but its jus MO
    zcarpenter92 and Jsena[QUOTED] like this.
  7. May 10, 2017 at 7:36 AM
    Bari2008
    thanks guys.
    all of my driving is done in city and highway, i dont ever go off road. i want a 6" lift that will give me close to factory ride.
    Jsena likes this.
  8. May 10, 2017 at 8:12 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Im pretty sure you can. Usually the spindle lifts they combine with a strut spacer up front or people have swapped out new coilovers. I think you will need more than just the shackles to keep that rear level with the front after the spindles. Im not too familiar with 2nd gen but that tire and wheel combo your looking at is pretty wide even 6" or so inches of lift I would assume youll need to do a good amount of trimming.
    Jsena likes this.
  9. May 10, 2017 at 8:27 AM
    Bari2008
    my truck already has bilstein 5100 (front and rear) which can adjust up to 2.5-3" will these shocks work with the spindle lift?
  10. May 10, 2017 at 9:14 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Installing 3" lift shackles and a 6" lift up front will not give you anything close to a factory ride.
    zcarpenter92 likes this.
  11. May 10, 2017 at 9:37 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not smart to stack lifts at all.
  12. May 10, 2017 at 10:21 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    I would say yes but call CST to Confirm. The 3" inch shackles wont give you a full 3 inches of lift in the rear so your front is going to sit up higher after the 3.5 spindles are put on.
    Jsena likes this.
  13. May 10, 2017 at 11:06 AM
    Bari2008
    Thanks guys.
    Jsena likes this.
  14. May 10, 2017 at 2:25 PM
    Boondoc89
    Boondoc89 Shit happens when you party naked
    Doc
    '17 mgm DC TRD 4x4
    No mods
    Long travel!!
  15. Jun 23, 2017 at 9:48 AM
    showtime240
    showtime240 New Member
    Easiest way is the Spindle lift. This will achieve an easy 3.5 inches while keeping mostly stock geometry.
    Look into the Maxtrac or CST spindle.
    Pair these spindles with OME 612, OME 614s, 5110, Icon, Fox, 6112, Boss, Fat Bobs whichever you like for your budget. These will give you an additional 2.5 inch to 3.25 inch lift
    Therefore, paired together you will get anywhere from 6 to 7 inches of front lift.
    ***** These lift Spindles are only for 2wd *****
    The rear is a different story.
  16. Jun 23, 2017 at 9:57 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
