Get Whitey
Discussion in '1st Gen Builds (2000-2006)' started by MNtundra, Apr 30, 2019.
  1. Apr 30, 2019 at 7:57 AM
    MNtundra
    MNtundra [OP] New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Hello,
    I recently purchased a white stock 2001 access cab 4wd Tundra (pictured below). I want to learn how to wrench on it. The other tundra is it’s twin trucker.
  2. Apr 30, 2019 at 8:11 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    for a budget 2-3" level/lift kit you're looking at Bilstein 5100s, Old Man Emu(OME), or Eibachs. they're pretty much all the same, but I'm leaning towards Eibachs or OMEs personally since the Billys are limited to 1" rear lift, whereas Eibachs for to 1.5". Can't remember what the OME rears do.
    with 2-3" of lift, you're just fine with stock UCAs. no need to go aftermarket unless your OEM ones are shot.
    MNtundra[OP] likes this.
  3. May 1, 2019 at 10:22 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Trimming is pretty easy so I wouldn't worry a lot about that. With your projected 2-3" lift you're going to want to stay at a 33" tire or below I believe.
    I would be a diff drop bracket if going 2" or above. You can get away with it at 2-2.5" I think, but those brackets are so cheap you might as well do it to help with the angles you mentioned.
    I just bought the eibachs since I did not want to reuse my stock coils. Have not installed yet.
    If I were you I would get under it and check everything real good. Check your sway bar and all bushings, all ball joints like tie rod end/Upper ball joint/lower ball joint, your center carrier bearing on your axle, basically just a lot of the stuff that gets worn on these trucks.
    I'm a big believer in fixing these things before they can cause more damage, and before I spend money on 'fun' but not necessity mods.
    Have fun with the truck and ask away and all questions during your build!
  4. May 1, 2019 at 10:35 AM
    OME rears designed for 2.5" in combination with the DAKAR leaf pacs, otherwise you can go with AAL and or shackles level the rear or retain a rake.
    lsaami[QUOTED] likes this.
  5. May 1, 2019 at 4:30 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I like it! the only thing I'd suggest is going with a progressive AAL rather than that linear one. it'll just ride a bit better in the rear.
  6. May 1, 2019 at 5:08 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's a good choice. I almost went that route.
  7. May 3, 2019 at 10:50 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would go with the ICON expansion pack over the Toy-Tech. Just my .02
  8. May 3, 2019 at 2:17 PM
    MNtundra
    Tony
    Minnesnowta
  9. May 4, 2019 at 3:31 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you want to stay cheap just check Craigslist for wheels. There should be a lot,of options if you search 4runner and Tacoma.
  10. Jul 13, 2020 at 8:57 AM
    MNtundra
    Tony
    Minnesnowta
    Like the old school looking wheels on the right Tundy... anyone know what they are?
    Darkness likes this.
  11. Jul 13, 2020 at 9:01 AM
    Ivan Stewart signature wheels.
  12. Jul 13, 2020 at 9:09 AM
    MNtundra
    Tony
    Minnesnowta
    Close, but that’s not them. The ones in the photo taper outward & have “2 pc” bolts around entire circumference. Ivan Stewart wheels taper inward. The ones in photo remind me of American Racing wheels.
  13. Jul 13, 2020 at 10:38 AM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
  14. Aug 17, 2020 at 3:48 PM
    MNtundra
    Tony
    Minnesnowta
    5100’s Front (3rd Notch) & Rear.
  15. Aug 17, 2020 at 7:40 PM
    MNtundra
    Tony
    Minnesnowta
    Talk me into or out of this tire:
    Falken Wildpeak AT3W LT275/70R17 Tire
  16. Aug 17, 2020 at 7:47 PM
    Casper421
    In the woods
    06 DC
    I’ve heard good reviews. @trailbikerider has them and seemed to approve.
  17. Aug 23, 2020 at 7:05 AM
    Professional Hand Model
    Hand Protectors
    The Hellwig 7700 is awesome! You’ll see.
    As far as rear leafs, @Surf_spear_Mex used a certain brand and there is another brand I’ve recco’d before. Both USA Made with USA Steel.
    FrenchToasty likes this.
  18. Aug 23, 2020 at 7:15 AM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    @MNtundra the falkens are great tires with a tuff look to them and perform well...until you get around 30-40k miles. When they wear down they make a loud swarm of bees type road noise. I've had 2 become unbalanced 2 different times. I'm wearing them til summer is over but they are annoying at this point. So for the fair price point they work excellent just not a high mileage performer imo.
    I just installed the ATS HD springs yesterday. I'd really be thinking about leaf pack options over aal or helpers. My oem's were pretty tired and loose. The ride quality on the little trip I've taken with the new ones is a 10 out of 10. Firm but not bouncy. Works great with the 5100's. I got 2 1/4 lift on the rear so they worked in that aspect as well.
    Also I have almost zero body roll now in correlation with new front sway bushings and suspensionmaxx sway links. It feels like a Porsche in the corners errr sorta but close enough lol
  19. Aug 26, 2020 at 8:13 PM
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Yup! This is my 3rd set between my 4Runner and my Tundra. Awesome tire.
