General Supercharger Thread
  1. Aug 23, 2022 at 3:51 PM
    #2731
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    My understanding is that Prospeed's fuel system package is nice and all, but if you get larger injectors above what comes with the Magnuson kit (often referred to as green TRD injectors), you will need a custom tune. I think @nobodyintexas said D3 spent most of a day getting his injectors dialed in.
    M3Tundra-JK[QUOTED] likes this.
  2. Aug 23, 2022 at 4:02 PM
    #2732
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Yup
    They spent a full day because nobody had a map for the 2020
    Mine are 650cc Harrop recommended Don’t see the need for larger unless you were going for hp>650
    which would take going into the engine to build it to take that much power
    stick with the trd injectors. You life will be much better
    the maggy will give you a dead reliable 550hp if you install the std parts
  3. Aug 23, 2022 at 6:10 PM
    #2733
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Cool. The 750cc part is what had me worried with the maggy since the trd's are like 530 already.
    So probably just the TRD injectors and a better than TRD fuel pump
    reywcms likes this.
  4. Aug 23, 2022 at 6:15 PM
    #2734
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The TRD injectors are good for 650hp, the pump is the limiting factor from what I’ve read and heard. Tuning for the pump didn’t take my tuner any longer than normal.
  5. Aug 23, 2022 at 6:19 PM
    #2735
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that this has been verified by Viktor.
  6. Aug 24, 2022 at 1:27 AM
    #2736
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Tuning shouldn't be any different, the pump issue is not enough flow at WOT. The pump isn't changing the pressure at the injectors (thus the tune), larger pump just means the pressure is maintained at high throttle so fuel tuning remains consistent.
  7. Aug 24, 2022 at 3:04 AM
    #2737
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    EXACTLY
  8. Aug 24, 2022 at 3:17 AM
    #2738
    nobodyintexas
    nobodyintexas What?
    South of Houston
  9. Aug 24, 2022 at 3:41 AM
    #2739
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Been there done that. I have the pro speed kit including the fuell rails on my Sequoia and honestly I’ve have regretted it since day one. The best place to start is upgrading the fuel pump over what is supplied in the kit. You will start to max out the trd injectors if you want to get above the Magnuson HP tune that is capable of 550hp at the crank. Honestly these stock engines can only handle about 600 hp at the crank roughly 500at the rear wheels so you’re Going to be close enough with the stock TRD injectors. Mine however were at 100% duty cycle with a custom tune which is why I ended up getting the pro speed kit in the first place. I initially lost horsepower over the original tune which I did end up getting back so when I say I would start with the fuel pump get the tune I’m speaking from experience. I’ve had five supercharged vehicles three Magnuson and two Harrops, still have 4 in the stable and I have learned a ton over this journey and a shit ton from ViktorG he’s the man. Upgrade the fuel pump first if your injectors are at 100% duty cycle most of the time then consider upgrading to 650cc injectors and you will be fine to get whatever power necessary up to the engine capabilities.
  10. Aug 24, 2022 at 5:28 AM
    #2740
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  11. Aug 24, 2022 at 5:39 AM
    #2741
    nobodyintexas
    nobodyintexas What?
    South of Houston
  12. Aug 24, 2022 at 6:35 AM
    #2742
    snivilous
    SW UT
    Alright I just bought one, Silver saying you can do the Amazon protection plan and being able to compare the Hilux and Tundra, plus shit on you guys with an old truck and a lowly used Magnuson :D pushed me over the edge. I'll try it out next week when I'm back from work.
  13. Aug 24, 2022 at 6:47 AM
    #2743
    Silver17
    Eastern PA
    Man that was easier than I thought. Mission accomplished. You’re not doing it for us, or even yourself…you do it for science. :monocle:
  14. Aug 24, 2022 at 6:50 AM
    #2744
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    lmao old used maggy’s ftw
  15. Aug 24, 2022 at 8:13 AM
    #2745
    snivilous
    SW UT
    Also @ColoradoTJ can this thread be renamed to "General Supercharger Thread" or something. Since this has a ton of posts but there's still new threads made and people comment on those (like about the magnusons) where they obviously never clicked on this thread since they presumably have no idea what a harrop is.
    Unless the harrop bois don't like that idea :D
    ColoradoTJ, Wynnded, Silver17 and 3 others like this.
  16. Aug 24, 2022 at 8:15 AM
    #2746
    Saltyhero13
    Saltyhero13 Throbbing Member
    +1 and it's "Boost bros" Harrop :cheers: Magnuson
  17. Aug 24, 2022 at 8:16 AM
    #2747
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Good Idea.
    lotsa good info in this thread.
    snivilous[OP] and Saltyhero13 like this.
  18. Aug 24, 2022 at 8:25 AM
    #2748
    M3Tundra-JK
    Scott
    2005 GX470
    I'd LOVE to see the first post turn into a wiki with links...
    snivilous[QUOTED][OP] likes this.
  19. Aug 24, 2022 at 8:26 AM
    #2749
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Whatever happened to the OP?
  20. Aug 24, 2022 at 8:27 AM
    #2750
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    "Boost it or Lose it"
  21. Aug 24, 2022 at 8:28 AM
    #2751
    Saltyhero13
    Never reposted
  22. Aug 24, 2022 at 9:11 AM
    #2752
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    He just lit the fuse and bounced, only 2 posts and both in this thread.
  23. Aug 24, 2022 at 10:55 AM
    #2753
    Saltyhero13
    Probably a Harrop rep "seeding" the thought..."You know you can buy a S/C without a tune right?"
    I kid but it is something I would do.
    HonorNotInner and snivilous[OP] like this.
  24. Aug 24, 2022 at 10:58 AM
    #2754
    BigAl
    BigAl New Member
    Is anyone with the Harrop kit running out of fuel? I read that it includes a DeatschWerks DW300c pump. If not, I'll use this, rather than going to the Walbro 450.
  25. Aug 24, 2022 at 10:58 AM
    #2755
    nobodyintexas
    nobodyintexas What?
    South of Houston
    we are simpatico
    this thread has cost me some $.
    I'm waist deep in this shit.
    and none of y'all are without blame!
  26. Aug 24, 2022 at 10:59 AM
    #2756
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I use the one Harrop sent.
    never has a fueling problem. I'm on the smaller pulley as well.
    My problem is my 3.5 air inlet.
  27. Aug 24, 2022 at 11:05 AM
    #2757
    Silver17
    Eastern PA
    I’m not gonna lie that Harrop stage 1 ran pretty good considering. The biggest thing that sketched me out was it wouldn’t enrich the fueling until the throttle was 70-80% open. Pulling a heavy load on hills where I wasn’t at open enough throttle to get it to richen up, meanwhile it’s sitting at 3500rpm with a big load on the engine and a 14.0 AFR. Yikes, lucky I didn’t blow any piston rings the one time I pulled my camper without a proper tune.
    I have plenty of fuel with the 300c based on my logs. I think it’s more than sufficient even for more power than I’m making. I found a good read on issues with over sizing the pump and that’s not good either. Not sure if I could find it again. Seems to be a trend to put the 450 in though so obviously it’s not an issue for most.
  28. Aug 24, 2022 at 11:11 AM
    #2758
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Geez, I think that even the TRD tune has it set to enrich starting at 50% throttle.
  29. Aug 24, 2022 at 11:11 AM
    #2759
    Done and stickied.
  30. Aug 24, 2022 at 11:14 AM
    #2760
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This is the way
    Jcmf52, Saltyhero13, Texas512 and 2 others like this.
