General Supercharger Thread
  1. Aug 26, 2025 at 8:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Couple updates here. Congrats to @texasrho83 who is joining this group of misfits lol. He's taking my whipple 2.9 and I'll be moving to @blenton gen6 3.0. Plans to start off with the 3.0 pulley and see how it does with the motor package etc. Should be plenty of power for the use case. We chatted yesterday on the fuel system a bit and interesting thing we talked about was dual pumps and whether or not it actually flow too much for the small basket? I'll be moving to the 880cc injectors and billet rails etc as well.
  2. Aug 26, 2025 at 9:07 AM
    bflooks
    bflooks New Member
    Metrowest MA
    that Prospeed and @Winks4x4Toy solution with the reservoir/surge/secondary tank does seem like an interesting idea, though I'm not sure how well it would work without the MOTEC controlling the additional pumps. Taking the edge off the demand makes sense to me, and probably helps alleviate your concern, even if it is only a single pump in each. Maybe? IDK, just throwing a thought out there.
    Really can't wait to see your build come together. Be nice to not have to worry about the power plant and to shrink the risk landscape down to just the trans.
    Oh! And kudos to all of you guys being able to make things work regarding the buys/sells/swaps
  3. Aug 26, 2025 at 9:35 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  4. Aug 26, 2025 at 11:39 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Man. Sucks being in the middle of trying to sell my house but wanting to get the truck stuff going...I'll have reach out to the forum members when it's time to search for a new SC with engine build.
  5. Aug 26, 2025 at 12:25 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Well I'm sure pops could be swayed for his when you're ready lol
  6. Aug 26, 2025 at 2:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  7. Aug 26, 2025 at 3:24 PM
    AZTundra
    Paul
    Phoenix, AZ
    Mdl and HulkSmurf14 like this.
  8. Aug 26, 2025 at 3:34 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't use my dash speakers. Pretty sure I pulled them out actually.
  9. Aug 26, 2025 at 3:34 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I guess not in Ludicrous mode Model S P90Ds aren't that fast. Just pissed one off coming into my community. He zipped between speed "humps", I kept up until finally I went around 'cause I don't need to practically stop for them.
    He even had a preparing for Ludicrous Mode plate frame & the plate was a pained attempt at Ludicrous. lol
    bwahaaaaa
    The Tesla Model S P90D was a performance-oriented, all-wheel-drive electric sedan featuring a 90 kWh battery and "Ludicrous Mode" for extreme acceleration, achieving 0-60 mph in around 2.8 seconds with a combined 762 hp output.Launched around 2015-2016, it was known for its fast, quiet operation and the benefits of free lifetime Supercharging, though it requires a specific adapter for newer fast-charging stations.
  10. Aug 26, 2025 at 5:25 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Awwwe yeah! Welcome back!! I sense some smiles being had!
  11. Aug 27, 2025 at 4:52 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    Welp DW300 and DW650 injector ordering moved up. I'm going to have to drop the fuel tank to bolt up my forward hangers for the traction bars, so might as well swap out fuel pump while I'm at it. It's okay to run the bigger fuel pump with my stock maggie injectors, basically fuel not needed will go down the return until i get smaller pulley and injectors installed and a tune correct?
  12. Aug 27, 2025 at 5:21 AM
    centex
    centex New Member
    You’ll want a tune for the bigger injectors as they do inject more fuel per squirt than the factory ones which will cause some running issues.
    HulkSmurf14 likes this.
  13. Aug 27, 2025 at 5:39 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    not to piss in anyone's cereal...but
    a P90D is
    3.2sec 0-60
    2.8 in Ludicrous.
    11.5 1/4 mile.
    it would be tough for ANYTHING to beat that sexy ole sedan.
    think about that....it's 10 years old.
    HulkSmurf14 and M3Tundra-JK like this.
  14. Aug 27, 2025 at 5:42 AM
    centex
    centex New Member
    Battery degradation explains why he beat it.
  15. Aug 27, 2025 at 5:44 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Inappropriate spacing leaves me a little concerned that you're losing your touch...
  16. Aug 27, 2025 at 5:45 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I bunch the appropriate subjects.
  17. Aug 27, 2025 at 5:46 AM
    Tripleconpanna
    :monocle:
  18. Aug 27, 2025 at 6:17 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    Just doing the fuel pump as I have to remove tank to bolt up the forward brackets for my traction bars. Will wait to install the injectors until I'm ready.
  19. Aug 27, 2025 at 6:32 AM
    centex
    centex New Member
    Then no need for a tune.
    jhrrld and HulkSmurf14 like this.
  20. Aug 27, 2025 at 6:39 AM
    e30cabrio
    Not my fault if his Tesla is degraded, I just enjoyed staying with him three times & then blasting past when I went over the bump. bwahaaaaa
    0& my Dragy skills have not improved, I got a 7 second run last week :p
  21. Aug 27, 2025 at 8:55 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    For sale in CA with low miles. No idea if it’s a good deal or not, but seems nice.
    Tripleconpanna and HulkSmurf14 like this.
  22. Aug 27, 2025 at 10:13 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thought it was going to be another SC for sale...whew!
  23. Aug 27, 2025 at 12:05 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Here's a 1900 body for $2100:
    https://www.ebay.com/itm/396995370011
    I'd be tempted to get it for the GX, but it's kind of a shame to have two vehicles with derpy blowers
  24. Aug 27, 2025 at 12:59 PM
    Silver17
    Northeast
    A gutted 1900 supercharger could make a pretty decent boost ready manifold for a turbo guy on a budget.
    :monocle:
  25. Aug 27, 2025 at 1:04 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I was literally looking at it wondering how well it would work. I don't know enough about it, and I wasn't necessarily thinking gut/seal/install, but I'm curious what the smaht guy @snivilous says.
  26. Aug 27, 2025 at 1:15 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'd be curious how far off a Holley LS fabbed intake manifold is for our trucks I bet not very
  27. Aug 27, 2025 at 1:17 PM
    snivilous
    SW UT
    I don't see why it wouldn't work. Hell you could have a second intercooler if you wanted too :rofl: I wasn't lying when I used it as a metaphor the other day hahaha
  28. Aug 27, 2025 at 1:20 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Finally got truck back never thought id see the day! Roof replaced now I can get to work and mod some more shit. Owner made a tik tok I guess so I screen shot it lol
  29. Aug 27, 2025 at 1:37 PM
    bflooks
    bflooks New Member
    Metrowest MA
    No. lol
    I have no reason nor desire to run more lines and add any additional fluids anywhere near my intake or combustion chambers ever again. I'd just be looking for a pre-formed manifold and I'd try to get every port on the thing sealed off. More intercooler... wtf is wrong with you people? I can barely fill a glass of water without puckering and it's been 8 months. :rofl:
  30. Aug 27, 2025 at 1:42 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    It works- gutted Eatons etc were done on the cobras and the TT ford gt's many moons ago. Before Sullivan came out with a manifold for them.
    Wynnded, Mdl, HulkSmurf14 and 4 others like this.
