General Supercharger Thread
  1. Aug 17, 2022 at 10:10 AM
    #2671
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I might bite the bullet now that I know the Amazon warranty thing. Assuming the previous testing I did with my phone was even remotely correct I'd expect sub 4.5s, and my supercharger setup is fairly basic so most are probably faster than me.
  2. Aug 17, 2022 at 10:39 AM
    #2672
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Well did a first drive and idle in traffic/drive through. Idling for 13min the iat got to 20 deg above ambient. Ambient temp was 81. Normally I would see temps begin to climb almost immediately idling. Seems like its prolonging heatsoak which is good. Driving I saw 10 deg above ambient at 81 deg ambient. Drive time was about 30 min. Interesting data so far.
  3. Aug 17, 2022 at 10:41 AM
    #2673
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I wish I would've taken a thermal gun to the box to see temps before and after. Oh well.
    HulkSmurf14 likes this.
  4. Aug 17, 2022 at 11:00 AM
    #2674
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    It works because NASA...I bet it's helping reduce temperatures...how much, doesn't matter, much like MPG :monocle:
    Saltyhero13 likes this.
  5. Aug 17, 2022 at 11:01 AM
    #2675
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL exactly because NASA.
  6. Aug 17, 2022 at 11:05 AM
    #2676
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Some troglodyte is going to think that it's a catalytic converter and make a grab for it because it's shiny. ;)
    reywcms and Saltyhero13 like this.
  7. Aug 17, 2022 at 11:14 AM
    #2677
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If yourself and @Downytide (if he joins in on the fun) can both hit 4.5 or better it may make my mind up on gears since you’re both using 5.29s and 35s which is still a lower effective ratio than my stock gears and 33s. Although Downy also has an IPT VB and headers. I can’t remember what mods everyone has which is why we should include it on our posts with 0-60 times.
  8. Aug 17, 2022 at 12:11 PM
    #2678
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Reach out to OTT about the IPT VB vs tuning. If i remember correctly, Justin said over on TW that they can adjust the torque tables or shift tables or pressures idk, but could do the adjustments via HPTuners where it pretty much does the same. unless you've done other mods to actually need the IPT VB
  9. Aug 17, 2022 at 12:18 PM
    #2679
    M3Tundra-JK
    Scott
    2005 GX470
    That may be for the 4th to 5th gear flair ups that occur with the Taco transmission....
  10. Aug 17, 2022 at 12:56 PM
    #2680
    Silver17
    Eastern PA
    My tune does already do this, but my understanding is it’s more of a bandaid and is not a substitute for the IPT valve body.
  11. Aug 17, 2022 at 1:35 PM
    #2681
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    You will have to give me couple of weeks, trying to line up with guys @ OTT for tune session, I'm having issue with first gear shifting at 5k rpm, with 5k rpm shift, I'm averaging 5.9s 0-100kmh, that's 5.6s based on calculation of time * 0.95 , which is verified by racelogic performance box which is pretty accurate.
    Silver17[QUOTED] and reywcms like this.
  12. Aug 17, 2022 at 1:51 PM
    #2682
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I def won't be the fastest lol
  13. Aug 17, 2022 at 1:59 PM
    #2683
    Silver17
    Eastern PA
  14. Aug 18, 2022 at 10:32 AM
    #2684
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    I'd join the fun if it weren't for the 24's.
    reywcms likes this.
  15. Aug 18, 2022 at 11:12 AM
    #2685
    Silver17
    Eastern PA
    Why let the 24s stop ya?
    M3Tundra-JK likes this.
  16. Aug 18, 2022 at 11:20 AM
    #2686
    nags
    nags New Member
    I'll get smoked with them on lol. Someone let me borrow some lightweight 20's real quick.
  17. Aug 18, 2022 at 11:27 AM
    #2687
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    get some wheel's and tires that are 29 inches tall in total to simulate running 5.29 gears.
    reywcms likes this.
  18. Aug 18, 2022 at 11:35 AM
    #2688
    Silver17
    Eastern PA
    Nahh, it can’t be that big of a hinderance. You’ve already got the RCSB advantage over us! If my porker can do 5 seconds then yours must be on another level especially with the extra mods. That is if it can hook up, is that a 4wd or 2wd?
  19. Aug 18, 2022 at 11:37 AM
    #2689
    nags
    nags New Member
    2wd. With I think every single bolt-on I can get really. I'm not hooking up for shit. :bikewheelie:
  20. Aug 18, 2022 at 11:40 AM
    #2690
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I empathize with your 2wd situation.
    you are dead on. 2HI is for long black marks.
  21. Aug 18, 2022 at 11:41 AM
    #2691
    M3Tundra-JK
    Scott
    2005 GX470
    Caltracs traction bars?
  22. Aug 18, 2022 at 1:28 PM
    #2692
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Today on NASA science we wrapped the heat exchanger lines. Thanks to Fedex on the delayed wrap for the intake tube. That'll have to be tomorrow.
  23. Aug 18, 2022 at 1:30 PM
    #2693
    HulkSmurf14
    2014 Tundra Limited
    Yeeeeeehaw! Nice work! Looks good and has function too!
    reywcms likes this.
  24. Aug 18, 2022 at 1:31 PM
    #2694
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The wrap for the lines is thick so it should absolutely help some. Thanks!
    HulkSmurf14[QUOTED] likes this.
  25. Aug 18, 2022 at 2:23 PM
    #2695
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Ya'll better watch out this nasa shit is going to lead to sub 3 sec draggy times.
  26. Aug 18, 2022 at 2:28 PM
    #2696
    HulkSmurf14
    2014 Tundra Limited
    Hahaha To infinity and beyond!!!
    Saltyhero13, reywcms and Black@Blue19 like this.
  27. Aug 18, 2022 at 2:30 PM
    #2697
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Would I be faster if I wrapped my transmission cooler lines?
    Nvm
    Nobody cares
  28. Aug 18, 2022 at 3:08 PM
    #2698
    M3Tundra-JK
    Scott
    2005 GX470
    Yo, 20 row Setrab over here waiting to be installed!
  29. Aug 18, 2022 at 3:12 PM
    #2699
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Not gonna lie
    I had a shop put mine in.
    best $450 I ever spent
    that kit works damn good
  30. Aug 18, 2022 at 3:19 PM
    #2700
    Silver17
    Eastern PA
    I hereby declare @reywcms changes his “New Member” status to “Gold Member”.
    1UP, omgboost, Saltyhero13 and 4 others like this.
