General Supercharger Thread
  1. Aug 16, 2022 at 8:03 AM
    #2641
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  2. Aug 16, 2022 at 8:18 AM
    #2642
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The magnuson intake uses the larger 07-13 lower airbox if I recall. Just order one for that year range and you should be good.
    reywcms likes this.
  3. Aug 16, 2022 at 8:32 AM
    #2643
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'm reaching out AFE to see what the cost is to create the filter in the 7R media for more filtration.
    HulkSmurf14 likes this.
  4. Aug 16, 2022 at 8:35 AM
    #2644
    Vizsla
    Vizsla 2 = 2.5
    The Magnuson airbox supplied for 14+ is the 07-13 box with a different lid. The one snivilous posted is correct.
    https://afepower.com/afe-power-31-10146-magnum-flow-pro-dry-s-air-filter
    I will caution you about it though, the oem with rigid frame is way better than the aftermarket for dust/off-road use, the pro-dry/aftermarket clogs up really fast and the edges opposite the pleats pull into the airbox letting lots of dust through. The 14+ box sucks, pic of 07-13 and 14-21 side by side.
  5. Aug 16, 2022 at 8:38 AM
    #2645
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That's great info. What's the part number for the oem rigid? Assuming what's pictured would be the oem.
  6. Aug 16, 2022 at 8:39 AM
    #2646
    Vizsla
    Vizsla 2 = 2.5
    I run 7R on my truck:thumbsup:
    HulkSmurf14 and reywcms[QUOTED] like this.
  7. Aug 16, 2022 at 8:40 AM
    #2647
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    There we go!
  8. Aug 16, 2022 at 8:41 AM
    #2648
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What's your intake setup look like with that?
  9. Aug 16, 2022 at 8:45 AM
    #2649
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    That's what I ran on my Tacoma also. The AFE momentum gt cai has a huge filter!
  10. Aug 16, 2022 at 9:28 AM
    #2650
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Correct, that would be considered a 5.25 second 0-60 run.
    Silver17[QUOTED] and HulkSmurf14 like this.
  11. Aug 16, 2022 at 10:08 AM
    #2651
    Warreng
    Warreng New Member
    I had the POS k&n for the trd air box/sc but just put a stock paper WIX which visually is a 10x better filter and no cleaning required. I dont care if I loose a bit of power as the piece of mind is worth the loss.
  12. Aug 16, 2022 at 10:19 AM
    #2652
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What's interesting there is that I've used both filter elements in very dusty conditions. The paper wix let more dust through than the K&N. Tested this on another tundra same result so who knows lol. Hopefully the 7R filters more out.
    Just to elaborate we removed the lid and inspected into the TB area and into the first portion of the blower tb area and found more dust remanence.
  13. Aug 16, 2022 at 11:28 AM
    #2653
    Warreng
    Warreng New Member
    my biggest comcern with the k&n is how the sides just collapse in and do not hold their shape despite stretching the pleates to make it square again.
    reywcms[QUOTED] likes this.
  14. Aug 16, 2022 at 11:32 AM
    #2654
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    The TRD Filter has been working well on my end...no side wall collapse and good filtering...though, my dust ain't sh!t compared to the SW dust...
  15. Aug 16, 2022 at 3:53 PM
    #2655
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    So my first run in 4WD is a 5.0 sec due to latest info.
    I’ll have to try brake boosting to get better numbers.
  16. Aug 16, 2022 at 3:57 PM
    #2656
    HulkSmurf14
    2014 Tundra Limited
    That's a fast, big truck!!
    Silver17, AZTundra and Saltyhero13 like this.
  17. Aug 16, 2022 at 4:47 PM
    #2657
    Silver17
    Eastern PA
    That’s basically where I’m at too. I’m having trouble getting the dragy to properly read the slope though to give me a “verified” run. I found the flattest road I could around and it reads it as sloped….in both directions in the same section of road! Not possible lol. If that’s reading it as a % grade, then there’s no way it can be right. Might have to mess with how it’s mounted or something.
    That said here was the best I was able to get tonight, and I also listed some pertinent info that would be Included in a proposed Dragy thread.
    5.04 with rollout and 5.26 without. 1800RPM brake boosting.
    77 degrees ambient. 553’ elevation
    Doublecab 4x4 with 33x12.50 Kendas. Stock gears. Stock transmission. 93 octane (1/2 38 gallon tank)
    Harrop w/80mm pulley, 650cc injectors, stock intake (3.5”) and a DAP remote tune.
    The heavy add ons include the bed cap and Go Rhino rear bumper. Under seat storage filled with tools and recovery gear, and a 34”spare tire. Without the cap and gear and some cooler temps I think I could hit some 4s!
  18. Aug 16, 2022 at 5:34 PM
    #2658
    ZPhilip
    Philip
    West Chester, PA
    If you’re talking about mine. Indeed she is, 6400 pound fatty.
  19. Aug 16, 2022 at 6:00 PM
    #2659
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Damn that's fast for these big rigs! I need to order mine lol. Thermal wrapping has begun. I'm waiting for the heat wrap for the intake tube and intercooler lines. I went pretty thick to hopefully create a barrier. We'll see.
  20. Aug 16, 2022 at 6:15 PM
    #2660
    HulkSmurf14
    2014 Tundra Limited
    How much do you love gold?!
  21. Aug 16, 2022 at 6:17 PM
    #2661
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yes
    reywcms and HulkSmurf14[QUOTED] like this.
  22. Aug 16, 2022 at 6:24 PM
    #2662
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Think it came out pretty good. Who doesn’t like gold lol
  23. Aug 16, 2022 at 6:34 PM
    #2663
    HulkSmurf14
    2014 Tundra Limited
    Looking sharp @reywcms !! I dig your catch can setup too!
    reywcms and Saltyhero13 like this.
  24. Aug 16, 2022 at 6:38 PM
    #2664
    HulkSmurf14
    2014 Tundra Limited
    How's everyone's transmissions holding up with the stage 2 setups? Have you upgraded the valve body at all? I know, this is :deadhorse:...
    Saltyhero13 likes this.
  25. Aug 16, 2022 at 6:50 PM
    #2665
    Saltyhero13
    Saltyhero13 Throbbing Member
    Wife: "Honey, have you seen my foil?"
    reywcms[QUOTED] and HulkSmurf14 like this.
  26. Aug 16, 2022 at 6:55 PM
    #2666
    Saltyhero13
    I'm impressed considering no one is optimizing for speed. These are some respectable numbers IMO. Tundra can scoot.
  27. Aug 16, 2022 at 7:09 PM
    #2667
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Thanks!
    HulkSmurf14[QUOTED] likes this.
  28. Aug 16, 2022 at 7:26 PM
    #2668
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Old lady came home immediately said “WTF are you doing now” lol I said “it’s Nasa science you won’t understand”
  29. Aug 17, 2022 at 5:48 AM
    #2669
    Silver17
    Eastern PA
    I need one of you guys with 4.88s or 5.29s to put a smackdown on my time with a solid Dragy run, or get some runs that aren’t measurebly quicker. Then I can decide if it’s worth it for me to regear when I do my LSD install! Lol
  30. Aug 17, 2022 at 5:56 AM
    #2670
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I suspect we will see 4.4-4.7's from some of the more formidable builds.
    Dragy clears the fog. It's like sunshine.
    I hope I'm the slowest. I'm rooting for y'all.
    I missed my 2nd run yesterday - my son is leaving today and wanted to go the the range yesterday to see if he could out-shoot me on the texas star. uh..not yet.
