General Supercharger Thread
  1. Aug 14, 2022 at 6:12 AM
    #2611
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    nobodyintexas likes this.
  2. Aug 14, 2022 at 8:17 AM
    #2612
    Vizsla
    Vizsla 2 = 2.5
    2 months between runs?, and 20+ mph difference in start isn’t ideal for claiming any gains.
    I’m guessing they did not hook up the optical sensor due to the mph on the scale instead of rpm, if so there won’t be a TQ curve to look at.
  3. Aug 14, 2022 at 8:35 AM
    #2613
    Saltyhero13
    Saltyhero13 Throbbing Member
    I may be mistaken but I think they would be the same for both since OTT is a remote tuner service.
  4. Aug 14, 2022 at 9:30 AM
    #2614
    Saltyhero13
    What parts did you use?
  5. Aug 14, 2022 at 10:28 AM
    #2615
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    He explains the reasons why that was done over on the tw thread. Something along those lines, the Dyno shop didn't hook something up
    Don't know pulley size
  6. Aug 14, 2022 at 10:30 AM
    #2616
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    To make the SABM? Or to monitor temps? I did it the cheap way using 3” duct plate (2) and 3” silicone hose (1) hose clamps (2). Same ones listed on the sabm thread think it was under $20. Also need a 3” holesaw.
    I’m using obd fusion for temp monitoring.
  7. Aug 14, 2022 at 11:02 AM
    #2617
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    so are you ~4 degrees from ambient now?
  8. Aug 14, 2022 at 11:52 AM
    #2618
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Normal driving was consistently 25-35 above. At 70*-90* ambient. In the cooler morning much less. Also noticed the IAT drop quicker than before.
  9. Aug 15, 2022 at 9:51 AM
    #2619
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I finally got a MPVI2 so working out details with John/Justin to remote tune it, won't be on dyno this time but will log it via racelogic performance box, should be more "applicable".
  10. Aug 15, 2022 at 12:23 PM
    #2620
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Sweet! Keep us posted on how it goes. Where'd you snag an MPV12 from?
  11. Aug 15, 2022 at 12:49 PM
    #2621
    Saltyhero13
    nags, M3Tundra-JK and reywcms like this.
  12. Aug 15, 2022 at 3:15 PM
    #2622
    AZTundra
    Paul
    Phoenix, AZ
    Received my Dragy today from Amazon. I'll try to get it set up and run some times on Wednesday if work time allows.
    Saltyhero13, Silver17 and reywcms like this.
  13. Aug 15, 2022 at 3:17 PM
    #2623
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Doing my dragy run tomorrow
    if weather holds
  14. Aug 15, 2022 at 3:19 PM
    #2624
    M3Tundra-JK
    Scott
    2005 GX470
  15. Aug 15, 2022 at 3:55 PM
    #2625
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I got mine too. I just did a little playing to figure it out, but have to try and get a good run in. Seems easy to use.
  16. Aug 15, 2022 at 4:05 PM
    #2626
    Saltyhero13
  17. Aug 15, 2022 at 11:33 PM
    #2627
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    This was my truck actually. The torque clamps don’t work on my truck so we had to use the drum but forgot to recalibrate it for fourth gear on the final run to compare my baseline. But the baseline tune was VFTUNER harrop file.The OTT tune we did with HPTUNERS. The previous run in 3rd gear was 459 Hp/472 tq.
    650cc injectors
    80mm pulley
    JBA long tubes no cats
    5.29’s
    SABM
    35’s
    The baseline was like 104 degrees that day and last Saturday was 96 I think.
    Vizsla, Saltyhero13, Silver17 and 2 others like this.
  18. Aug 15, 2022 at 11:37 PM
    #2628
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    Here is the last 3rd gear run if y’all wanted to look at the TQ curve. Idk if it means much being in 3rd. 31EB35F7-01B1-4AD7-8F24-076CC6356A0B.jpg
    Vizsla and Saltyhero13 like this.
  19. Aug 15, 2022 at 11:45 PM
    #2629
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Make sure you floor it this time :D
  20. Aug 16, 2022 at 3:12 AM
    #2630
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not ideal, but inline with my other runs. I'll do better later today.
    doing a run in the Plaid as well...because.
  21. Aug 16, 2022 at 3:36 AM
    #2631
    nobodyintexas
    nobodyintexas What?
    South of Houston
  22. Aug 16, 2022 at 4:00 AM
    #2632
    Silver17
    Eastern PA
    See on the report where it shows 0-60 (1ft) on the bottom left? Does that indicate the time with 1ft of rollout? I thought that was how most publications do the testing and report their time.
  23. Aug 16, 2022 at 4:04 AM
    #2633
    nobodyintexas
    nobodyintexas What?
    South of Houston
    dunno
    I think that's to replicate a drag strip trip lights.
    but - this was in 4HI - my a/c was on, and no nannies were turned off, & tow/haul was off. not excuses, just saying it was not ideal.
    next run, I'll watch the MAF reading..i want to see how close I get to the 512 limit.
  24. Aug 16, 2022 at 4:08 AM
    #2634
    snivilous
    SW UT
    I swear you are incapable of giving it full boosty bois :facepalm:
  25. Aug 16, 2022 at 4:08 AM
    #2635
    nobodyintexas
    nobodyintexas What?
    South of Houston
    You are not wrong.
    snivilous[QUOTED][OP] likes this.
  26. Aug 16, 2022 at 7:12 AM
    #2636
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What's everyone running for air filters on the maggy? Also, ordered the insulation sleeves to do the following items. Heat exchanger lines, intake tube and adhesive for the airbox itself.
    Bo-Hunter and HulkSmurf14 like this.
  27. Aug 16, 2022 at 7:14 AM
    #2637
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I'm just using the TRD intake setup myself and will likely do the SABM et Al before winter...
    reywcms likes this.
  28. Aug 16, 2022 at 7:46 AM
    #2638
    snivilous
    SW UT
    K&N POS that superchargers online sent when I bought the Magnuson intake. I actually just bought an AFE dry that I'm waiting to install.
  29. Aug 16, 2022 at 7:54 AM
    #2639
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Do you have that part number for the AFE?
  30. Aug 16, 2022 at 7:58 AM
    #2640
    snivilous
    SW UT
    mustang67408 and reywcms[QUOTED] like this.
