General Supercharger Thread
  1. Jun 6, 2025 at 12:45 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Thanks for pushing me to piece together something on my own. I still wanted to have a clean and OEM'ish setup, so I did not go as bare bones as you suggested, but I did end up saving about $700 with my setup using the following... Actual all in for me (installing myself) was $636.39 vs. $1299 + tax and shipping using GCS, but I have to admit that he does put together a very nice kit... Keep in mind I'm in California so all my prices included tax and shipping.
    Hayden 689 Cooler (Amazon) $86.72
    OEM Cooling Brick, Hard Lines, and Hoses to trans side (eBay kit) $332.80
    Mounting Bracket Kit with mounting hardware, AN Fittings, and Grommets (Forum Member "Jmunk") $100.00
    OEM Hose Clamps X 6 and OEM Hardline Mounting Bolts X 2 (toyotapartsdeal.com) $34.49
    7ft. Gates 27059 Trans Cooler Hose (oreilly) $49.63
    2qts Toyota ATF WS (Amazon) $32.75
    Total = $636.39
    I know there are cheaper ways to do this, but wanted to share my actual all in price for those who want options. Like I said, I wanted a clean and OEM'ish install so I went for a custom mounting bracket already designed and sold by a fellow forum member...
  2. Jun 6, 2025 at 1:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    HulkSmurf14 and koditten like this.
  3. Jun 6, 2025 at 3:46 PM
    centex
    centex New Member
    Just dropped mine at UPS. Hopefully it helps get you yours soon!
    bflooks[QUOTED] likes this.
  4. Jun 6, 2025 at 4:00 PM
    blenton
    blenton New Member
    My thermal blanket is sitting unused on the shelf, no ETA on my SC rebuild from Whipple. I'd be happy to send the blanket your way if you are itching to get going on it.
  5. Jun 6, 2025 at 4:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I should be good. It is supposed to be here on the 13th. I still have to pull it and press on the new snout bearings.
    I appreciate the offer though. Enjoy the weekend.
    blenton[QUOTED] and HulkSmurf14 like this.
  6. Jun 6, 2025 at 6:31 PM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    I might have missed in this thread… I’m needing to upgrade my ecm. No one I’ve seen or found has something compatible. XAT is telling me about an add on deal… I forget exact name. I’m setting mine up for more street fun and can’t get over 132mph and need to be able to control Trac system for better hook up. Ideas ?
  7. Jun 6, 2025 at 6:36 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Motec
  8. Jun 6, 2025 at 6:36 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Do you already have a built engine? Are you requiring a stand alone tuning option? The oem ecm can be tuned and optimized past your goals. HP Tuners, VF Tuning, etc can muster out some power with the right builds. Sounds like you need a LSD like a Powertrax...better than that, you should consider the Sequoia transfercase AWD swap...bolts right in and traction becomes just a word with the right tires...share more of what you have and you'll get more help...
    M3Tundra-JK, Mdl and blenton like this.
  9. Jun 6, 2025 at 6:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Only $10-$15k but you're in control, than!
    Mdl and reywcms[QUOTED] like this.
  10. Jun 6, 2025 at 6:59 PM
    centex
    centex New Member
    I need more details on this build. 132mph is no easy feat.
  11. Jun 6, 2025 at 7:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've seen a. stock tundra hit 150mph on long open roads in TX. I believe it was before hpt and removing the abs module or something like that. Mph recorded based on gps.
    I searched tundratalk but couldn't find the video, 2013-2014.
    Silver17, reywcms and HulkSmurf14 like this.
  12. Jun 6, 2025 at 8:25 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Can't be that hard, I've had mine over 120 with the 5.29s too as I recall and it was still accelerating. I'm more curious about why it stops at 132 if the governor is disabled?
    Silver17, Mdl, reywcms and 4 others like this.
  13. Jun 6, 2025 at 10:06 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Right.. I’ve had mine over 120 in the dirt
    Silver17 likes this.
  14. Jun 6, 2025 at 10:19 PM
    blenton
    blenton New Member
    Oh yea? Well I've had mine triple digit speeds with my enclosed trailer in tow.. :boink:
    carn_dogg and Mdl like this.
  15. Jun 7, 2025 at 2:58 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    115 up a 7% grade. By accident actually.
    carn_dogg likes this.
