General Supercharger Thread
  1. Jun 24, 2022 at 8:28 AM
    #2311
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Thanks! :)I already have the wire harness running to the passenger side. I’m sure that will work too?
  2. Jun 24, 2022 at 8:31 AM
    #2312
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    This is the place that had it for $2300 on sale. Currently $2650. But it's also the Sequoia fit kit. Only thing it doesn't have is a short PVC hose. This appears to be the "updated" model number. The only one I can find for the Tundra specific is slightly over $2800 and has the earlier part number attached. the "updated" part number for Tundras can't be found.
    https://parts.villagetoyota.com/p/Toyota__/TRD-Supercharger-Fit-Kit/69529158/PTR290C110.html
    Silver17[QUOTED] likes this.
  3. Jun 24, 2022 at 8:33 AM
    #2313
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yea that works also
    vq35721[QUOTED] likes this.
  4. Jun 24, 2022 at 8:33 AM
    #2314
    M3Tundra-JK
    Scott
    2005 GX470
    rent a 5 or 6 lb pulley puller from your local auto parts store. they're free with a deposit!
    snivilous[OP] likes this.
  5. Jun 24, 2022 at 9:11 AM
    #2315
    Saltyhero13
    Saltyhero13 Throbbing Member
    "I do not want headers....I do not want headers....I do not..."
    reywcms and vq35721[QUOTED] like this.
  6. Jun 24, 2022 at 9:27 AM
    #2316
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I used a harmonic balancer puller and put a ring of steel behind the pulley for it to grab onto
    Also idk how you plan to reinstall the new pulley, I pulled the whole nose cone off and used a press since the bolt method that URD provided seemed janky as fuck and I thought it was gonna strip the shaft out. Good time to replace the coupler too.
  7. Jun 24, 2022 at 9:32 AM
    #2317
    M3Tundra-JK
    Scott
    2005 GX470
    When I did the Tacoma, I had pulled the entire supercharger off for other things. Place new pulley in toaster oven at 400 for idk, 20-30 minutes. Needs to be heated in garage close to s/c so it doesn't cool down between oven and s/c. Allows it to expand enough that it goes on A LOT easier with the URD tool
  8. Jun 24, 2022 at 9:35 AM
    #2318
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I often change concentric bearings on large electric motors at work which is the same concept. I use a puller similar to what snivilous used for removal, and when installing the new bearings we have a bearing cone heater. Let it sit on there until it’s 150 degrees above ambient and they slide on like butter. If you can get your hands on one of those to somehow reinstall, that would be the easiest. I’m sure they’re expensive to buy for yourself though.
  9. Jun 24, 2022 at 10:11 AM
    #2319
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I used to these swaps a lot on the supercharged cobras and Lightning’s. I’ll most likely use that same style puller and installed as they are press on also.
  10. Jun 25, 2022 at 11:39 AM
    #2320
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Same.
    I'm sure they do great work but I just couldn't justify spending 5x more for the same job.
  11. Jun 25, 2022 at 11:43 AM
    #2321
    M3Tundra-JK
    Scott
    2005 GX470
    I'll be doing the install myself. Any tips and tricks from someone who installed their own?
  12. Jun 25, 2022 at 11:51 AM
    #2322
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Blow out / Vacuum out the area around the intake manifold before removing.
    Buy a metric thread chasing kit and clean out the holes before you start installing the new stuff, mine were full of crap and the bolts wouldn't thread all the way in.
  13. Jun 25, 2022 at 2:00 PM
    #2323
    snivilous
    SW UT
    The bolts that hold the Magnuson down are a bitch to get a tool to. I feel like last time I pulled the blower it was less of a pain, but the first time I had to take an open end and bend it at like 60deg to fit around the bolt (nut?) and clear everything.
    Also if you plan to do a pulley I would install that first. I would also swap the coupler out for one of the fancier aftermarket ones before installation, the coupler that came on mine was shot almost instantly after installing it, and pulling the nose cone with the blower installed is a bit of a bitch.
    Everything else is pretty straightforward.
  14. Jun 25, 2022 at 6:14 PM
    #2324
    M3Tundra-JK
    Scott
    2005 GX470
    Is the Tundra Magnuson coupler the same spring loaded style they use on the Tacoma? If so ya I'll swap that out for sure.
  15. Jun 25, 2022 at 9:55 PM
    #2325
    snivilous
    SW UT
    I assume so? If the swapped one is the "solid" coupler then yes. All it is is a puck with 6 holes iirc. The one I pulled off I don't think had any springs though but it was awhile ago I did that.
    mustang67408 likes this.
  16. Jun 26, 2022 at 8:39 AM
    #2326
    M3Tundra-JK
    Scott
    2005 GX470
    Top is stock Tacoma Magnuson couple, bottom is aftermarket solid
  17. Jun 26, 2022 at 8:40 AM
    #2327
    M3Tundra-JK
    Scott
    2005 GX470
    I found some additional motivation to get the truck done, gonna be a shelby killer so I can park next to this fool with too much money at the Espresso & Exhaust meet lol
    mustang67408, 1UP, reywcms and 5 others like this.
  18. Jun 26, 2022 at 3:10 PM
    #2328
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Superchargers online sells a redesigned coupler (with round holes vs oval holes that are prone to fail). I recall it being around $150 or so.
    M3Tundra-JK[QUOTED] likes this.
  19. Jun 27, 2022 at 12:07 PM
    #2329
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What gatorback belt is everyone running for the 2.30 maggy pulley?
  20. Jun 27, 2022 at 6:30 PM
    #2330
    Saltyhero13
  21. Jun 28, 2022 at 7:59 AM
    #2331
    Silver17
    Eastern PA
    nobodyintexas and Saltyhero13 like this.
  22. Jun 28, 2022 at 8:33 AM
    #2332
    Saltyhero13
    I was laughing at a comment I saw on Reddit claiming the TTV6 was so fast, then I compared the Gen 2/2.5 specs. That is ok, truck has good enough pep IMO
  23. Jun 28, 2022 at 8:39 AM
    #2333
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I believe it is awful that Toyota chose not to outperform Ford....after all the blather about world class leading performance....or whatever they said.
    I still hold firm to the notion they should have slapped the hybrid crap on the 5.7.
    1UP, Silver17[QUOTED] and Saltyhero13 like this.
  24. Jun 28, 2022 at 8:43 AM
    #2334
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Ponder the hybrid 5.7...with a blower.
    now, that would be class leading.
    1UP, omgboost, Silver17 and 2 others like this.
  25. Jun 28, 2022 at 8:44 AM
    #2335
    Saltyhero13
    Give it five years or a little more. I think ICE to hybrid conversions will be fairly common.
    nobodyintexas[QUOTED] likes this.
  26. Jun 28, 2022 at 9:09 AM
    #2336
    Silver17
    Eastern PA
    It just seems like the hybrid isn’t worth it on this new truck. Essentially zero performance increase vs the non hybrid, lower towing and payload numbers due to the battery and motor weight, and only 1 MPG better. The Ford also has the ability to work like a giant generator. I’m just not sure the hybrid is worth the expense in the tundra. Seems like a flop to me.
    Supercharged 5.7 reigns supreme in the tundra performance world!
  27. Jun 28, 2022 at 10:27 AM
    #2337
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Effortless acceleration, it behaves like a diesel more than ultimate performance truck, I think for most average driver, they "feel" the torque, I recall they had plans to make the TRD Pro more Raptor like during development but that got axed when few other projects that's related also got the boot.
    Keep it in mind too that all the Wildpeak AT3 comes on the new Pro is not the same as the standard AT3W, they are Toyota specific, they are lighter and have much shorter tread depth to help with mpg rating.
    There were aftermarket "hybrid" system before , one was called Vonnen http://vonnen.com/news/ , the system is do-able but it'll be a very complicated system, and probably little to no fuel savings, with minimal performance gain, a hybrid set up works best when the ICE is in atkinson cycle, the 2URFSE (LS600H) can do it, and I believe there were in fact mules running that set up but I think high costs lead them to be axed as well.
    Saltyhero13 likes this.
  28. Jun 28, 2022 at 10:51 AM
    #2338
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    They ( Toyota) should have could have gone a couple different directions!!:)
  29. Jun 28, 2022 at 4:19 PM
    #2339
    Saltyhero13
    RE: Tundra iForce Max. Great points about the Tundra. Early reports say it tows like a dream with the Hybrid set up; it is definitely not optimized for MPGs but I think Toyota was pretty clear about that up front. If it had a battery only mode the range was calculated to be in the single digits on the current battery.
    RE: Aftermarket hybrid upgrade. Vonnen was one of the first out of the gate with a "mass market" system (for the mass market of specific Porsche models :notsure:) but the tech has been around a while.
    They way they've used the pancake motor its basically equivalent to eMeth(a finite temporary boost). It was never intended to be for fuel savings as most traditional hybrids are categorized.
    The low battery capacity, no regen braking, and as you point out ICE motor isn't optimized for efficiency are major drawbacks of this system if they were trying to go for fuel savings.
    Even if the performance gains are temporary the numbers are fairly respectable 5.0sec to 3.6sec. For a bolt on system the design is fairly simple, looks reversible and not overly intrusive. It looks like its a intermediary launching pad project to me.
    For the time being the hybrid space seems primarily focused on zero emissions (full conversion from ICE to EV), it is growing rapidly with an explosion of innovations.
    The group to hit the market with a completely bolt on kit for below $10K (w/installation) will probably make a killing if they can get their product dialed in.
    omgboost likes this.
  30. Jun 29, 2022 at 7:17 AM
    #2340
    Downytide
    GTA
    Should've, could've, those words costs millions if not billions in automotive world, much like the "small" 4.5L duramax that was being worked on back in early 2000's, GM even showed a concept back in 2007 ( https://www.autoblog.com/2007/10/29/sema-2007-chevy-suburban-hd-z71-diesel/ ) , that project was so close before it was axed, at that year's SEMA, toyota also showed a concept Tundra with dually and Hino's 8L diesel, I recall there was serious thought about bringing in the 1VDFTV (4.4L diesel) as an "HD" model with boxed frame throughout.
    At low speed driving with low load, it's battery only, I've had one sneaked up on me with that UFO sound only to scare the bejesus out of me.
    I don't think we will ever get a swap kit for below $10k, just material you are probably looking at $15-25k , you can probably realistically make swap kit with cradles that will place the battery pack between front and rear motor kinda like how F150 Lightning is built, and run the new e-axles that is just a solid axle but with electric motor as third member, I do see that as something picking up steam since that's how most EV commercial vans are built now.
    Saltyhero13[QUOTED] likes this.
