General Supercharger Thread
  1. Mar 29, 2025 at 10:48 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    On 35s, sure... but you gain so much more with marginal RPM increase, it's like saying too much power is bad... blasphemous...personally, I'm still on stock gears, 33s, and stock Maggy 1900 pulley and injectors, so I can't talk :anonymous:
  2. Mar 29, 2025 at 11:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    When I was down in Mexico I saw 0-110mph on 35's with 5.29's do pretty good. I usually drive 75-80mph and see rpm's about 2750-2850rpm, a pretty good power/torque area. 4.30 and 4.88 would be quite beneficial above 70mph to ramp up for more speed. I find myself not going for the high mph and just playing with the quick takeoffs.
    Silver17, Wynnded, ARES35 and 3 others like this.
  3. Mar 29, 2025 at 11:34 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    Man right now with 5.29s and 35 at 80 im only at around 2300rpms
    koditten and HulkSmurf14 like this.
  4. Mar 29, 2025 at 11:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'd have to double check but I may be off
    Edit: tires are true 35's
    55mph@1760. 70mph@2200. 75mph@2500. 81@2860rpm
    I just copied from hpt so could be off a little.
    Wynnded and snivilous[OP] like this.
  5. Mar 30, 2025 at 2:07 AM
    NatesNightMare
    Pinetop Az
    Im just saying what im actally seeing when im at 80mph.
    Not calculations
  6. Mar 30, 2025 at 4:14 AM
    bflooks
    bflooks New Member
    Metrowest MA
    You're seeing the same (maybe even a few hundred RPM more) than me and I'm running 33.4" Falkens.
    I made the decision to make 1st almost a safety net/towing reserve gear. It's into second gear really fast unless under heavy load. That is fine for me because it's not hunting for gears up top anymore, which I believe offsets the quick gear shifts from a stop. I did it for decreased drivetrain strain (like @centex I see ~20% calculated load reduction) knowing it tows about as much as it doesn't.
    These discussions are what helps others make their own informed decisions. If I wasn't towing, holding 1st a little longer wouldn't be bad. But I'm also not manually shifting, so it's minimal impact.
    Mdl[QUOTED], ARES35 and HulkSmurf14 like this.
  7. Mar 30, 2025 at 7:00 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That sounds way off. I'm at ~2650rpm at 80mph on speedo. Are you sure you got 5.29s and not 4.88s? :D
    Speedometer reading on all trucks should be:
    RPM / Trans Gear / Diff Gear * Stock Tire Circumference (feet) * 60 minutes / Length of a Mile (feet)
    So 2300 / 0.588 / 5.29 * 32*3.141/12 * 60 / 5280 = 70mph on dash
    All of those should be constants for everyone, the dash only knows stock tires, the trans gears are stock, the only thing that changes is RPM and gearing. Now if you have 4.88s:
    2300 / 0.588 / 4.88 * 32*3.141/12 * 60 / 5280 = ~76mph on dash
    5.29s should be well over 2500rpm to display 80mph on the dash:
    2650 / 0.588 / 5.29 * 32*3.141/12 * 60 / 5280 = ~81mph on dash
    Now if you have the rough country (?) speedometer calibrator thing that's a different story. But 2300rpm sounds exceptionally low otherwise.
    reywcms, Wynnded and ARES35 like this.
  8. Mar 30, 2025 at 8:59 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    For some reason in hpt my rpm in scanner fluctuates about 200rpm up/down. While my dash rpm is steady. Never really looked into it.
  9. Mar 30, 2025 at 9:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  10. Mar 30, 2025 at 9:29 AM
    centex
    centex New Member
    I’m up closer to 3000 at 80 with my 5.29’s and 34’s. And depending on which speedometer I’m looking at I’m within 2-3mph of the dash.
    Mdl likes this.
  11. Mar 30, 2025 at 9:50 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I'm realizing from some of these videos that I really baby my truck
  12. Mar 30, 2025 at 10:47 AM
    NatesNightMare
    Pinetop Az
    Yeah theyre 5.29s
    Now im gonna have to take a trip just to be able to get up to speed to check again but im pretty damn positive im not that high in rpms
    Mdl likes this.
  13. Mar 30, 2025 at 11:16 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Welp....The Magnuson is on it's way!!
    Should be here in a couple more weeks!!
    After seeing and feeling what the TRD Blower did for my Tacoma I cant wait to see what the Magnuson does for the Tundra!!!
    This is going to be the longest few weeks ever!!
  14. Mar 30, 2025 at 11:16 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And your ecu was reprogrammed for the new gear ratio?
  15. Mar 30, 2025 at 11:17 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And a reason stuff doesn't break!:D
  16. Mar 30, 2025 at 11:44 AM
    NatesNightMare
    Pinetop Az
    Yep, after I had the gears done I had ott redo it for the gears
    Tundra Texan and Mdl[QUOTED] like this.
  17. Mar 30, 2025 at 12:07 PM
    centex
    centex New Member
    I really need to get this tune finished so I can start doing this stuff.
  18. Mar 30, 2025 at 12:44 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Patience. Good things come to those who wait. :)
    Mdl likes this.
  19. Mar 30, 2025 at 1:02 PM
    centex
    centex New Member
    Got another revision in my inbox and then up the boost.
  20. Mar 30, 2025 at 2:03 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Hmmm...so you should regear the Tundra after getting the Magnuson installed?
    I did get my Tacoma regeared back in the day but figured the Tundra would be fine.
    I mean if it needs to be regeared I'm fine with that especially since I'll be doing a lot of towing.
    bflooks, HulkSmurf14 and Mdl like this.
  21. Mar 30, 2025 at 2:11 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    If you’re gonna do a lot of towing, def regear it. At the minimum, have the gears REM polished.
  22. Mar 30, 2025 at 2:20 PM
    centex
    centex New Member
    Don’t have to but it’s so much better geared than not geared.
  23. Mar 30, 2025 at 3:15 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    I'll leave that bit until after it's Supercharged.
    That way I can be totally ignorant as far as the Wife goes....
    Whoops........
  24. Mar 30, 2025 at 3:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @bflooks is a good guy to hit up on re-gearing and towing without big ol' tires.
    I ran for 14 years with stock gearing, 4.30 and the little tvs1900 and 34 inch tires. Re-grared to 5.29 and although I lost some top end its way more fun and usable with 35's.
  25. Mar 30, 2025 at 4:56 PM
    centex
    centex New Member
    Him and I both gained a full 2mpg and a usable 5th gear when towing when we geared to 5.29’s. I’d love to try towing on stock size tires with the gears.
  26. Mar 30, 2025 at 7:24 PM
    bflooks
    bflooks New Member
    Metrowest MA
    BLUF: 5.29s, a traction device in the rear, enjoy it.
    TL;DR: Even naturally aspirated, the regear opened up another gear while towing with heavy 33s about half the time (forced induction made that 100% of the time). Calculated load dropped ~20% (which is really a drop throughout the entire drivetrain) and RPM deltas are negligible in the grand scheme of things, (mostly seen at highway speeds). It feels light and is both responsive and predictable. Also doesn't hunt for gears or lock/unlock the TC when cruising. It just does what you want it to with minimal effort.
    The gearing is still my favorite and highest impact mod I've done, even after going forced induction. It's great seeing more people making the jump. If it is an either/or option, I'd choose gears first.
    I'm just one opinion, though. Forced induction wasn't really in my plans and I was focused on longevity/towing performance. Lots of success stories of people towing heavy without gearing, with and without power adders. I'm just here saying these trucks respond extremely well to regearing. Gearing + power adder = nirvana
  27. Mar 30, 2025 at 7:49 PM
    centex
    centex New Member
    I’ve yet to tow with FI. Next weekend will be my first time. Looking forward to pulling some hills.
    bflooks, VWTim and HulkSmurf14 like this.
  28. Mar 30, 2025 at 9:59 PM
    NatesNightMare
    Pinetop Az
    I have yet to tow as well and will be soon so now ive got to pull the camper out soon and do the 50mi tow break in for the new gears
    bflooks likes this.
  29. Mar 31, 2025 at 3:06 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Someone to watch this upcoming towing season is @Silver17
    We have the exact same travel trailer and tow within only a few hundred pounds of one another (based on scales). I think his gear install is still pending, but I'm hopeful he shares his reviews after they're done.
    Silver17 likes this.
  30. Mar 31, 2025 at 4:05 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The waiting is killing me, it just keeps getting pushed off. Sorry for holding your ECGS tools hostage. It’s tough because I need the truck for some upcoming weekend projects, yet also need to get it done before our first trip in May. There’s a reason I tried to have it scheduled for mid February! I know he will probably have it for 2 weeks. I wish I had a better option.
    Good news, I just got FedEx shipping confirmation from Australia for the valve body.
    ssmokedz, M3Tundra-JK, Mdl and 4 others like this.
