General Supercharger Thread
  1. Mar 5, 2025 at 8:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Thanks. I'll give it a try tomorrow. Does make some sense. I've switched over the years from Toyota/ Idemitsu/ valvoline and now dex3.
  2. Mar 6, 2025 at 4:26 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've read that as well, so I did that before my full IPT transmission install, only I used VFTuner. When I mentioned what I had done to John (IPT), he said that they really don't do that as a matter of course. They prefer to wait to see how the new transmission behaves first, then if there are anomalies, they may suggest a learned values reset. FWTW...
  3. Mar 6, 2025 at 7:58 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Haven't looked into tech stream hardly- is this something we can download to a pc etc? What's the field to reset? I'm now thinking of running ws until the valve body swap happens no sense in wasting the dex I have.
    Saltyhero13 and HulkSmurf14 like this.
  4. Mar 6, 2025 at 7:59 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    You can do it with 2-way obd scanners too, if you dont want to mess with techstream
  5. Mar 6, 2025 at 9:15 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    so shop calls and says the lash is like 15 thousandth and will have a whine if they dont shim it down to spec at like 6. i said i was expecting a whine with gears but if its not bad i can live with it. they said theyll check
    HulkSmurf14 likes this.
  6. Mar 6, 2025 at 9:34 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Won't that cause premature wear on the gears?
    Tripleconpanna and HulkSmurf14 like this.
  7. Mar 6, 2025 at 9:41 AM
    helidave
    flagstaff
    2015 DC 4x4
    You shouldn't EXPECT whine with gears, and you certainly shouldn't accept more than double the spec just because some gears whine when setup perfectly.
  8. Mar 6, 2025 at 9:45 AM
    mass-hole
    mass-hole New Member
    I am seriously considering a supercharger for my LX570, and was pretty set on the Harrop, but with the news that the Gen 6 Whipple might be on the way, what are thoughts of using the Whipple instead? I think the whipple should work other than needing to get a custom tune.
    My primary use case would be for towing a 5500 lb travel trailer in the Rocky Mountains, I live at 6500'. Not looking for big power, just to get back the 20% power loss from being at 6500'(and then some) in the most efficient way possible. I wanna keep IAT's low when pulling grades at higher temperatures.
    HulkSmurf14, Silver17 and e30cabrio like this.
  9. Mar 6, 2025 at 9:51 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Backlash should be near .007.
    Wynnded, HulkSmurf14 and reywcms like this.
  10. Mar 6, 2025 at 10:07 AM
    e30cabrio
    Licensed to burn rubber!
  11. Mar 6, 2025 at 10:14 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Why would they even call to tell you it's at 15. They should call if it's within spec or a hair out.
    "Hey how's it going, we suck at our job and were wondering if that's okay with you"
  12. Mar 6, 2025 at 10:16 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    This is it. Lol 4.88 nitros in the old man’s rig zero whine. There should be zero noise excepted.
  13. Mar 6, 2025 at 10:18 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    They all should have a custom tune done as the tunes included leave much to be desired. Still no word from our Whipple contact so I wouldn’t hold your breath for the gen6 just yet. If it was confirmed it’d be in my kitchen already.
  14. Mar 6, 2025 at 10:18 AM
    snivilous
    SW UT
    Can't go wrong with any of them. I would think the Whipple would be good from the potential to overdrive it more than most superchargers (though I haven't looked into that specifically, but since they have massive pulleys would make sense) and that's what you'll need to get the power back.
    Have you looked at the turbocharger option from Turbokits too?
  15. Mar 6, 2025 at 10:46 AM
    mass-hole
    The problem with turbos is they are usually pretty low efficiency at low boost. Like <60%. The compressor maps I have seen for the TVS2650 seem to be in the 68-70% range at 1.25 PR right up to 55 lb/min.
    Not that I would be creating much heat at that low of boost, but still, at 1.25PR and 60% efficiency you are still looking at a 161F compressor outlet temp on a hot day with no intercooling.
  16. Mar 6, 2025 at 10:47 AM
    centex
    centex New Member
    So shim it to 6. Gears shouldn’t whine. Mine don’t in either my blazer or tundra. 4.88’s and 5.29’s respectively.
  17. Mar 6, 2025 at 10:52 AM
    centex
    centex New Member
    I’ll be up at that altitude next week. I’ll let you know how the turbo does but I’m not expecting any issues. Turbos like load so towing puts a load on and they’ll come online quick. I don’t know if @bflooks towed at that elevation but he did a lot of testing while towing. Maybe he could offer some insight.
  18. Mar 6, 2025 at 11:05 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @bflooks towed throughout the hills of Franconia Notch and surrounding areas. Didn't have any issues pulling his trailer. He's a fellow Mass peep.
    bflooks, HulkSmurf14 and e30cabrio like this.
  19. Mar 6, 2025 at 11:14 AM
    mass-hole
    That would be sweet. Im sure the turbos work but at the 3-5 psi range I would be running in, I am not sure it would be the ideal solution.
    I don't think the turbo kit wouldn't work, I am just not convinced its the best solution for my use case. If I was going for power and was planning on running 7+ PSI then sure.
    I just want the 5.7L to not feel like its always maxed out and needing to downshift. If I am towing along at 2800 rpm, a mosquito could fart and it has to drop a gear. My old F150 Ecoboost could pull in 5th gear at 2200 rpm and still had a decent amount of power in reserve for headwinds or a small hill. One downshift to 4th at 3000 rpm and it could pull all but the steepest hills.
  20. Mar 6, 2025 at 11:16 AM
    NatesNightMare
    Pinetop Az
    how hard is it to re shim? need my truck this weekend and they said it would be a few days before they could get the shims
  21. Mar 6, 2025 at 11:36 AM
    snivilous
    SW UT
    Then blower and let her chew! If you're ever down south you're welcome to take my truck for a rip for comparisons sake, though obviously it's pretty apples to oranges.
    The biggest issue with Whipple imo is they've had QC issues so far, and seem to take excruciating long to deliver anything, even current stuff. There's two people that have messaged me from like 8+ months ago somehow waiting on Whipple's. Maybe after the issues with the current Whipple and the Gen 6 coming out they paused production, but I would have a hard time waiting very long when there's other options on the market ready to go, and they'll all do what you want. If you're a few months out then play it by ear so you can get the new shiny blower, if you want to throw cash tomorrow then send it with the Harrop and dont look back.
  22. Mar 6, 2025 at 11:37 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I remember we discussed this before. The Whipple has larger displacement of course which is nice, but is limited to a hard ceiling of 18k rpm. If the plan is to overdrive the blower I’d just look at the big picture in that regard. Here was a post I made about it prior with more detailed information. https://www.tundras.com/threads/general-supercharger-thread.85513/page-593#post-3682192
    Saltyhero13, Mdl and e30cabrio like this.
  23. Mar 6, 2025 at 11:42 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Don't shims come with the gear kits? And don't most shops who do this work have shims they can use? Make sure they shum it to spec or closer so you're not pissed!
    Blow it, Use a Maggy, Send it...happiest truck driving is done in boost!
    Tripleconpanna and Mdl like this.
  24. Mar 6, 2025 at 11:45 AM
    snivilous
    SW UT
    They're noobs :rolleyes:
    And if they're anything like the place I took my tundra to, are absolutely incompetent when it comes to an IFS diff and don't want to keep taking it apart since they can't figure out how to it set it up.
  25. Mar 6, 2025 at 12:00 PM
    centex
    centex New Member
    Gears aren't something you run and then pull out and reshim and redo. It's not hard but it does take knowledge on how to do it right. It's a lot of install, measure, adjust. They need to set it up right the first time.
  26. Mar 6, 2025 at 12:05 PM
    centex
    centex New Member
    Gear it. The transmission gearing in these trucks is to tall and so they compensate with 4.30's in the rear but that's not enough. I'm running 5.29's and am about to drop from 34 to 33 just to better help the gearing situation out. I was a little shocked at how much my tundra seemed to struggle towing my rzr as compared to my silverado. Where the silverado just casually loped along in 5th gear even with 34's, the tundra had to be in 4th. Added the 5.29's and now the tundra can run in 5th just fine.
    Turbos don't necessarily need to be in boost to help add power. They can sit at 0psi and just that can be enough to help it out.
    Either way, forced induction is a key ingredient to successful towing capabilities.
  27. Mar 6, 2025 at 12:31 PM
    mass-hole
    Yes, the 6 speed gearing is pretty atrocious but my LX has the 8 speed that has much better gearing, and is basically the same as the the domestic truck's 8 and 10 speed. Even regearing to 3.91's would be more than enough to compensate for 37's and would still put my gear ratios shorter than a Tundra with 5.29's.
    I may go to 3.91's at some point, just havent gotten there yet.
    ssmokedz and HulkSmurf14 like this.
  28. Mar 6, 2025 at 12:39 PM
    NatesNightMare
    Pinetop Az
    they had me come test drive. the mech test drove and the bossman. mech has hearing issues so the biss drove and he had same thought as i. get the whine on decel almost none on accel. he said as it sits its fine and wont harm anything now or down the road. be picking it in bout an hour
  29. Mar 6, 2025 at 12:40 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Well let’s move you along then… I have the 3.91 diffs from my wife’s 200 Series, they need a new home. 3 hours west of Boston.
    Wynnded, bflooks and Mdl like this.
  30. Mar 6, 2025 at 12:46 PM
    helidave
    flagstaff
    2015 DC 4x4
    Did they re-shim it to spec before all this?
    Tripleconpanna, Land Bruiser and Mdl like this.
