General Supercharger Thread
  1. Feb 4, 2025 at 2:50 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Patiently waiting and limbering up for the VB group buy discount reveal.
  2. Feb 4, 2025 at 2:52 PM
    Cruisers & Co.
    Cruisers & Co. New Member
    Johnny
    1997 Turbocharged Lx450, 1978 FJ40
    I think the way I am going to lay it out is this... Each Item can be purchased at a discount but there will be a bundle that increases the discount as you add others to the cart. Mix and match save as you go type thing
  3. Feb 4, 2025 at 3:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    So I'd be down for the pan. Didn't see it on your website but I'll buy from you since your putting on the group buy for us.
  4. Feb 4, 2025 at 3:07 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Front and back Jack!
  5. Feb 4, 2025 at 3:10 PM
    Cruisers & Co.
    Johnny
    It's not on there yet but will be. Thanks for your support!
  6. Feb 4, 2025 at 3:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Extreme and a pan for this guy too! BANZAI!!!
    bflooks, Mdl, e30cabrio and 2 others like this.
  7. Feb 4, 2025 at 3:23 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
  8. Feb 4, 2025 at 3:28 PM
    NatesNightMare
    Pinetop Az
    another question.. full master bearing kit or mini kit?
    ive only git 55k on my truck.
    300 ish for both mini kits or almost 1k for master
  9. Feb 4, 2025 at 3:30 PM
    ARES35
    Mile high
    They still cheap yo, well at least the backs a few weeks ago. Have 2 sets of rear 29's. Got another and Motive sent me a free set. Thought my rear main gear was bad but it was just u joints and carrier bearing.
    Silver17 and Mdl like this.
  10. Feb 4, 2025 at 3:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ayers and New England Gear Polishing can remove the pattern if you need to use them or sell em.
    HulkSmurf14 and ARES35[QUOTED] like this.
  11. Feb 4, 2025 at 3:46 PM
    Silver17
    Eastern PA
    Have they been quiet since? Hoping to get mine in this month. Guess my future VB will have to wait though for the next shop visit.
    ARES35[QUOTED] and Mdl like this.
  12. Feb 4, 2025 at 4:04 PM
    ARES35
    Mile high
    They both are brand new in the box. Figure id keep one for worse case scenario, other will go to a Tundra owner eventually.
    Tripleconpanna and Mdl[QUOTED] like this.
  13. Feb 4, 2025 at 4:07 PM
    ARES35
    Mile high
    My set does not run silent. Have slight whistle at all rpms and coast hum at 70 down to 50. With the rear window up I can't even hear it. Windows down I sound slightly like a old school dump truck, but nothing alarming. About to change over to 85w-140 GL5 for I've hit 495 miles. Mostly for the speedmaster lsd though.
    Mdl and Silver17[QUOTED] like this.
  14. Feb 4, 2025 at 4:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My rears are noisy at 55-60 but that is on me. I had a good pattern but still a little deep I should of went a few thousandths shallower. Got 1500 miles on them, the front have 510 on them and are quiet. Once it warms up Ill be swapping out the rears for a REM'd set.
    Silver17[QUOTED] and ARES35 like this.
  15. Feb 4, 2025 at 4:14 PM
    ARES35
    Mile high
    Running 80/85-140 weight?
  16. Feb 4, 2025 at 4:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I ran both 80/90 and 85/140 still noise. I've spoken/emailed with Ken, Zuk, and have a game plan.
    ARES35[QUOTED] and reywcms like this.
  17. Feb 4, 2025 at 5:10 PM
    NatesNightMare
    Pinetop Az
    rears are $102 and fronts are $333 on Amazon
    ARES35[QUOTED] and HulkSmurf14 like this.
  18. Feb 4, 2025 at 5:36 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Me, too! Thanks again, Johnny!
  19. Feb 4, 2025 at 7:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    There are those that will say they are noisy like Nitro's can be. Most shops will get a great pattern with good backlash and call it good. I did. But have whine 55-60 and decel/coast. Will be swapped out and reset.
    On my fronts I had a nice pattern but thought of my rears. I went another .003 reduction from what I thought was on and they are totally silent running in awd and 4x4 locked.
    Ken was saying most shops still go by a little deep is good. The 5.29 pinion has huge teeth with a lot of purchase to back off a little bit without sacrificing strength. @Silver17
    Might be worth it to ask the install shop to try a little shallower than too deep.
    e30cabrio, Silver17, reywcms and 2 others like this.
  20. Feb 4, 2025 at 7:14 PM
    HulkSmurf14
    2014 Tundra Limited
    Race truck parts make race truck noises!
  21. Feb 4, 2025 at 7:37 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I haven't done a tune, but my understanding is 'yes' (depending on the tuner)...
    Basically, the truck just keeps trying to upshift to an OD gear for 'efficiency'. However, in many applications it tends to shift back and forth and does not do it very cleanly (a lot of 'hunting' IMO), which is why I'll move it to S4 if I'm towing or wanting to lock up in 4th...
    Tow/Haul seems to clean it up a bit also, but not a lot...
    HulkSmurf14 and e30cabrio like this.
  22. Feb 4, 2025 at 9:23 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I'll be going 5:29's and Powertrax once my budget recovers from the Supercharger done last month.
    However, I have a lot of pause hearing how so many end up with noisy drivetrain. Have a couple shops near me who did my Hilux gears and lockers 25 years ago but it seems like evem competent shops are getting lash wrong. I'll be doing Sierra gears to hedge my bets
    HulkSmurf14 likes this.
  23. Feb 4, 2025 at 11:06 PM
    NatesNightMare
    Pinetop Az
    ordered the gears,
    maybe ill do a master bearing kit for the rear and a mini for the front
    HulkSmurf14 and Mdl like this.
  24. Feb 5, 2025 at 5:22 AM
    TurboKits
    TurboKits New Member
    Im a little late to this convo, but honestly, some of the best tech troubleshooting and progress I have made on tunes and kit development is driving it home and back in the AM. Since I am used to the drive, it allows me to really focus on the truck (or car) and tune. As I know the roads, I know where I can accelerate, I can test cold cold starts, quick off / on stopping at the gas station. Realistically, the closer you can test it to how it will be driven is always the best. As long as the truck gets back to you clean, undamaged and in one piece. I wouldn't read into it too much.
    In regards to the MAF, other than what looks like some goop or something on the side, some MAF cleaner' probably a solid idea. It doesn't look different to what the MAF should look. If they do deem it failed, let me know so we can send a label to get it back and off to the supplier for testing.
    Thanks!
  25. Feb 5, 2025 at 6:19 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I saw it Sunday, it looks fine (except that "glue"?)
    I'm bringing Armyoffoo's injectors there today & will get the MAF, if you want it I'll send it, if it is good I'd appreciate getting it back, if not use it for R&D.
  26. Feb 5, 2025 at 6:27 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Oh, you gotta send it back to @TurboKits if for no other reason than to have peace of mind. But honestly, if Jesse is willing to send this in for testing to rule it out, that's good for him, good for all of us running that product, and good for you to put that question completely behind you (and maybe some ammo for a refund on any of those expenses from the shop?).
    I'm still really hoping you can get this sorted out quickly. Your situation is my worst nightmare heading into my own swap. You'll figure this out!
  27. Feb 5, 2025 at 7:05 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Looks like I celebrated too soon...got a couple codes yesterday and today, P0102 and P0174. Probably a vacuum leak since I touched/adjusted every vacuum line on the truck with this project. Truck is idling and performing very well, and was starting and idling without issue before yesterday's CEL (still ran great after code). I ordered a smoke machine to identify the leak, if that is the issue. Also going to clean my MAF sensor and fuel filter as a precaution.
    P0102 - Yesterday (first start of the day, popped immediately) - Mass or Volume Air Flow Circuit low Input
    P0174 - Today (idling at red light, system fully up to temp) - System Too Lean Bank 2
    reywcms likes this.
  28. Feb 5, 2025 at 7:25 AM
    e30cabrio
    Boooo, I was thinking maybe I have a vacuum leak, hoping (not optimistic) it is the injectors.
    I got this cheap smoke machine for the BMW, works well, but get the right oil for it.
    https://www.amazon.com/gp/product/B0C7MKZPK3?ie=UTF8
    I used this
    https://www.amazon.com/Smoke-Soluti..._csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM=
    armyoffoo[QUOTED] likes this.
  29. Feb 5, 2025 at 7:35 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
  30. Feb 5, 2025 at 7:44 AM
    e30cabrio
    Looks cooler!
    Please let me know where you connect the hose. If I get the Sequoia back having issue I'll be wanting to check.
    I sprayed maf cleaner around the engine last week and saw no changes in idle but that's an imprecise test.
