General Supercharger Thread
  1. Feb 1, 2025 at 3:44 PM
    centex
    centex New Member
    Extreme here.
    bflooks likes this.
  2. Feb 1, 2025 at 3:50 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    What are we looking at for a potential price? I’d be down for a extreme VB depending on cost.
  3. Feb 1, 2025 at 3:53 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I'll add you to the list so Johnny can figure out numbers and let everyone know next week. Specifically called it "potential participants" for your exact question.
    Abell207[QUOTED] likes this.
  4. Feb 1, 2025 at 3:57 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Got off my ass and made some progress on my larger throttle body/5" intake project. I got the 3URFE snout removed and the GM snout installed, and "mounted" my replacement coolant reservoir. Next is removing and replacing the radiator shroud coolant expansion, relocating and replacing the PS reservoir and re-plumbing SC coolant to use the new reservoir...then the intake should be able to rotate down and fit right behind the headlight...for now. The plan is to put the filter element in the space where the SAIS air pumps are normally mounted, in the wheel well.
  5. Feb 1, 2025 at 4:03 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Looks like if you're running a super/turbo setup extreme is the best bet. Please jot me down for the extreme VB.
    bflooks likes this.
  6. Feb 1, 2025 at 4:12 PM
    bflooks
    bflooks New Member
    Metrowest MA
    From Wholesale Auto, but maybe @Cruisers & Co. can confirm, this is in response to my concern over harsh or violent shifts with the Extreme:
    "The shifts will be cleaner, slightly firm in your instance but not aggressive or violent."
    ARES35[QUOTED] and Mdl like this.
  7. Feb 1, 2025 at 4:41 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Looking good! I've been eyeing going from 4.5 to 5 inch intake. I found a few candidate intakes to fab up. What brand did you use?
  8. Feb 1, 2025 at 4:42 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I'm in for an extreme VB as well!
    bflooks likes this.
  9. Feb 1, 2025 at 4:47 PM
    bflooks
    bflooks New Member
    Metrowest MA
    To assist in the discussion, just keep adding/editing this list with your username and VB option.
    @Cruisers & Co. Does the version of VB upgrade matter or does either apply (nomad & extreme)?
    Nomad: https://cruisersandcompany.com/products/tundra-series-6-speed-nomad-valve-body
    Extreme:
    https://cruisersandcompany.com/products/tundra-3ur-fe-6-speed-extreme-heavy-duty-valve-body
    Manufacturer Link:
    https://automatictransmission.com.au/select-your-vehicle/toyota/tundra/5-7l-v8-petrol-with-6-speed-auto/?make=Toyota&model=Tundra&series=5.7L V8 Petrol with 6 Speed Auto
    Potential Group Buy Participants
    Valve Body:
    @bflooks (extreme)
    @reywcms (extreme)
    @Silver17 (extreme)
    @centex (extreme)
    @ARES35 (extreme)
    @Abell207 (extreme)
    @HulkSmurf14 (extreme)
    Trifecta (or other combo):
    @Bluecobra (?)
  10. Feb 1, 2025 at 4:50 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I bought a 5" 90* with 18" legs from Summit racing I think (bulk aluminum intake tubing), MAF fitting from MRP, HPS Silicone 4.25" to 5" 90* with 6" legs, and a few AN and NPT bungs from Vibrant performance.
    Mdl[QUOTED] and HulkSmurf14 like this.
  11. Feb 1, 2025 at 5:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Cool. I saw a 30 degree 5 inch intake with 7 inch legs each side that will work.
    armyoffoo[QUOTED] likes this.
  12. Feb 1, 2025 at 6:36 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    So, just confirming, tune would be required (ideal) for the valve body swap to be effective, correct??
    Mdl and HulkSmurf14 like this.
  13. Feb 1, 2025 at 6:45 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Between just spending 13k+ & NOT having my truck I'm out on the VB for now :(
  14. Feb 1, 2025 at 6:50 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I don’t believe a tune is required to realize the mechanical benefits of the modified valve body.
    Lucid Tundra, bflooks, Mdl and 4 others like this.
  15. Feb 1, 2025 at 7:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No tune is necessary. Plug and play or swap and play.
  16. Feb 1, 2025 at 7:45 PM
    Tripleconpanna
    Sounds like a PNW work party :D
  17. Feb 1, 2025 at 8:08 PM
    Cruisers & Co.
    Cruisers & Co. New Member
    Johnny
    1997 Turbocharged Lx450, 1978 FJ40
    Great list so far! All of WAT products are on the table for this group buy. I think the way I’d like to approach the nomad vs extreme is by seeing what power everyone is making vs their expected/potential power they’d like to hit. For example if you’re at a stage 1 turbo but expect to go stage 2 relatively soon and make 700+ hp then the extreme would be the way to go. For those that have a bolt on SC and will not shoot for more then the nomad will be the better option. This will be a case by case basis and we will reach out to anyone who orders to confirm.
    Shifting harshness will depend on the setup. Nomad is crisper than stock and Extreme is crisper than nomad. There is a trade off in harshness with the ability to hold the added hp/tq but this is why we will reach out to confirm the end output.
    Replacing the valve body is a plug and play mechanical item so it shouldn’t require a retune.
    ssmokedz, Silver17, AZTundra and 3 others like this.
  18. Feb 1, 2025 at 8:12 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  19. Feb 1, 2025 at 8:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  20. Feb 1, 2025 at 8:18 PM
    Saltyhero13
    and an air straightener if we are going to upsell and spend other peoples money...
    Mdl[QUOTED] likes this.
  21. Feb 1, 2025 at 8:19 PM
    centex
    centex New Member
    Stage 2 turbo and I tow so the extreme is what I want. I like a good firm and quick, not hard, shift. Don’t need this barking tires on gear shifts.
  22. Feb 1, 2025 at 8:32 PM
    Saltyhero13
    Stupid question: I take it you mean WHP?
  23. Feb 1, 2025 at 8:40 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I’m down for the extreme valve body.
  24. Feb 1, 2025 at 8:56 PM
    Cruisers & Co.
    Johnny
    Not stupid at all, I should’ve expanded my abbreviation when using it for the first time
    WAT - Wholesale Automatic Transmissions
  25. Feb 1, 2025 at 10:32 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I would recommend a complete drain and fill of the atf. Get the fluid out of the torque converter and cleaning up the solenoids so your good to go with no clutch debri to gum up your new VB.
  26. Feb 1, 2025 at 10:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Cruisers & Co. Would WAT sell C2, B3 and C2 accumulator springs for the ab60 Valve body? I have a built vb but would like stiffer shifts 2-4. Thanks!
  27. Feb 1, 2025 at 11:08 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    question is what would the pricing be?
  28. Feb 2, 2025 at 12:13 AM
    Saltyhero13
    I should have narrowed my quote down. The write up of the Extreme VB clarified what I was asking about.
    Mdl likes this.
  29. Feb 2, 2025 at 1:02 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And... I gotta ask?. How would a Wholesale Automatic Transmission extreme VB shift be harsh compared to an IPT /Level10 VB upgrade? Both use sonaxx parts and various MOJO to give the edge....just had to put it out there.
  30. Feb 2, 2025 at 1:23 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You stated "overhauled HD Transmissions". WAT stated they do only a standard oem build on transmissions. Do they have a heavy duty ab60? Or just offer an extreme or nomad build VB?
    NatesNightMare and Wynnded like this.
