General Supercharger Thread
  1. Jan 26, 2025 at 2:55 PM
    bflooks
    bflooks New Member
    Metrowest MA
    @e30cabrio - got nothing to offer except best wishes with everything. You'll get it!
    e30cabrio likes this.
  2. Jan 26, 2025 at 3:36 PM
    blenton
    blenton New Member
    Not a bad idea. I purposely have my throttle settings dumbed down a little bit for low traction (winter) situations. They are still a hair up from stock settings, but quite muted compared to a ‘spicy’ tune. I tow a lot with my truck, so tow haul remained virtually the same as stock, which is more aggressive but still very predictable even with the SC. They are dialed about right so that I hardly notice a difference in throttle response going from loaded without trailer to loaded up with trailer.
    Oof. What a bummer. I know it’s only a general direction, but I’d be chasing down wiring, looking for a pinched wire or bad pin. I know it’s been suggested to look at the pins, but on more than one occasion I’ve seen myself or friends accidentally pinch a wire or bend a pin on a harness while doing major work on a vehicle such as a transmission or motor. Could still be a critter causing coincidental collateral chaos..?
    Also, as has been noted, you can hook up HPTuners and verify throttle with the key on but motor off.
    Best of luck. If needed, I have a working OE TB I could lend. You’d still have to wait a few days for it to show up, but it’s available.
    Mdl likes this.
  3. Jan 26, 2025 at 3:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Not sure where they are at in diagnostics. I'd be tracing tb and maf wires to ecu. When I swapped engines I had a few wires get dinged up. They looked good but no continuity to ecu. Hopefully they got the wiring schematics and can check continuity from Tb and maf back to the ecu pins.
    e30cabrio[QUOTED] and blenton like this.
  4. Jan 26, 2025 at 3:59 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The shop was going to pull out the coolant reservior and trace wires. I found nothing in a search but figured all it can be is the pedal. I got a Duralast at Auto Zone and it works!
    Wtf?????
    Silver17, Mdl, bflooks and 1 other person like this.
  5. Jan 26, 2025 at 4:28 PM
    centex
    centex New Member
    If it makes you feel better, I’m having communication issues with my tuning so I’m unable to get the appropriate logs for the tuner. Trying to chase down the wiring harness to see if something is tapped in to it.
  6. Jan 26, 2025 at 4:31 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Pedal? As in gas pedal? Seriously?
    Mdl likes this.
  7. Jan 26, 2025 at 4:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wow! That's a new one for me. Will keep it noted for trouble shooting!
    e30cabrio[QUOTED] likes this.
  8. Jan 26, 2025 at 4:53 PM
    e30cabrio
    Yes, the entire pedal had to go to replace the sensor, The truck is home, it also solved the gear drop-down. My logic was worst case, I'll bring it back.
  9. Jan 26, 2025 at 4:54 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Congrats!
  10. Jan 26, 2025 at 5:27 PM
    e30cabrio
    I'm sorry that's happening, it sucks when things don't work.
    I need to put the RCF TB Back on & get logs, it's idling high but feels good.
    armyoffoo and HulkSmurf14 like this.
  11. Jan 26, 2025 at 5:59 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Wow, I would have never guessed the pedal went bad...weird coincidence?
    Saltyhero13 and Mdl like this.
  12. Jan 26, 2025 at 6:01 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Do you have a Maestro, or another head unit that taps into OBD2 (not just the plug, actual wire taps)? I was running into the same problem with mine, had to disable OBD2 in the head unit before scans would work.
    Mdl likes this.
  13. Jan 26, 2025 at 6:27 PM
    e30cabrio
    It was a hail Mary & I'm thrilled it was right.
  14. Jan 26, 2025 at 6:40 PM
    centex
    centex New Member
    Yes I do. I’ll have to check into disabling obd2 in the head unit. I ran out of daylight before I could trace for actual wire taps.
  15. Jan 26, 2025 at 8:53 PM
    centex
    centex New Member
    @armyoffoo That was it. Disabled the obd2 on the head unit and every channel lit up.
    @TurboKits note for future reference. Folks that can’t read the channels that have aftermarket head units that plug into the obd2, have them disable that to read properly.
  16. Jan 26, 2025 at 9:22 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    BigAl, ZPhilip, nasher75 and 5 others like this.
  17. Jan 26, 2025 at 9:33 PM
    centex
    centex New Member
    To further prove this, I’ve been having with tech stream 18 and my mcvi pro losing comms with the truck. After disabling the obd2 in the head unit, zero issues communicating or monitoring.
  18. Jan 27, 2025 at 2:48 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Congrats! What a winning kind of evening for the electrical gremlin warriors you and @e30cabrio are.
    HulkSmurf14 likes this.
  19. Jan 27, 2025 at 4:35 AM
    e30cabrio
    Anyone have a stock 5.7 & need plugs? I have 8 11 mile Iridium NGKs
    Free to a good home.
    :D
    AZTundra, Tripleconpanna and nasher75 like this.
  20. Jan 27, 2025 at 6:19 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    For you guys out there that have spent time tuning on this platfrom in original to increased levels of boost, did you find any benefit to run a colder step plug when running original boost/pulley on Magnusson or other kits? I know Magnuson suggests OEM heat range plug with their original set up. I've always run colder plugs on boosted engines, but I know the boost levels are pretty low with original pulleys.
    Mdl and nobodyintexas like this.
  21. Jan 27, 2025 at 6:28 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    from the peanut gallery....
    when I had my Harrop installed, the installer recommended cooler plugs
    so I did.
    and it's been fine.
    this was with original pulley & injectors.
    I'm still running the cooler plugs with smaller pulley & larger injectors.
    nasher75[QUOTED] likes this.
  22. Jan 27, 2025 at 6:35 AM
    TurboKits
    TurboKits New Member
    Great news!
  23. Jan 27, 2025 at 6:35 AM
    TurboKits
    Excellent, just got your latest log email. I'll look over it shortly! Definitely keep that turned off until we are 100% done with everything... Hate to see a connectivity issue during a flash!!
    bflooks and centex[QUOTED] like this.
  24. Jan 27, 2025 at 6:35 AM
    centex
    centex New Member
    I'm going one step colder on my turbo kit just for the added safety along with larger injectors.
    Mdl and TurboKits like this.
  25. Jan 27, 2025 at 6:37 AM
    TurboKits
    For boost it's typically 1 step colder for every 10 PSI. So 0-10 PSI, 1 step, 10-20 PSI 2 step...
    Mdl, armyoffoo, reywcms and 1 other person like this.
  26. Jan 27, 2025 at 6:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went 2 steps colder and i went tighter on the gap. As well as updated to the Lexus coil packs
    NatesNightMare, Mdl and TurboKits like this.
  27. Jan 27, 2025 at 6:40 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Thanks. My installer recommended we install 1 step colder plugs when I dropped off the truck, even though Magnuson does not call for it. It made sense to me so I agreed.
  28. Jan 27, 2025 at 6:45 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Magnuson used to call for IKH22 (I believe 1 step colder) on their kit as it comes. It even specifies this on the sticker of the lid for my magnuson intake box. I went down a pulley and am at around 8.5-9psi and I’ve been using IKH24 with no issues so far.
    snivilous[OP] and jhrrld like this.
  29. Jan 27, 2025 at 6:47 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    My 2650 kit from maggy came with IKH22 plugs as well.
    Silver17[QUOTED] likes this.
  30. Jan 27, 2025 at 6:53 AM
    e30cabrio
    I just started it & am back to a slew of codes & no throttle. WTF?
