General Supercharger Thread
  1. Jun 5, 2022 at 5:41 PM
    #2011
    Saltyhero13
    Saltyhero13 Throbbing Member
    Does it stick without the LED tied to the relay?
  2. Jun 5, 2022 at 5:47 PM
    #2012
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I have not tried cause it would be a pain to undo my wiring, but electrically it wouldn’t make sense that it would cause it to stick. The DRLs draw about 1 amp and are tied into the load side of the relay. I spliced directly into the wire feeding the pump and not the control (trigger) circuit.
  3. Jun 5, 2022 at 5:55 PM
    #2013
    Saltyhero13
    I don't disagree but if the problem came with the connection of the LEDs to the relay it is likely related to the install unless the relay was damaged or a connection is loose.
  4. Jun 5, 2022 at 6:09 PM
    #2014
    Silver17
    Eastern PA
    I do understand your thought, but the issue just started and I’ve had the LEDs wired this way for several months.
  5. Jun 5, 2022 at 6:46 PM
    #2015
    Saltyhero13
    So the answer was no. :)
  6. Jun 6, 2022 at 1:59 AM
    #2016
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I’m wired into the fog backlight too
    it happened twice before the fogs, once after
    back in my car stereo days, I would have fixed this easy. I had a box of Bosch single pole single throws laying around
    today. Not so much
  7. Jun 6, 2022 at 5:33 AM
    #2017
    Saltyhero13
    I've seen relays get stuck by contact welding in high power applications, I don't think that is the case here especially not if the relay is able to toggle back between the two states.
    The more likely culprit can be vibration not sure if it is possible to dampen it in this application but it may be easier and cheaper than replacing it (not that relays are prohibitively expensive).
  8. Jun 6, 2022 at 5:36 AM
    #2018
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ...and I'm still adding about 2oz's of coolant to the intercooler each couple of months.
    not complaining...just reminding y'all to check your coolant.
    might be because it's already Africa-hot in Houston.
    vq35721 likes this.
  9. Jun 6, 2022 at 5:37 AM
    #2019
    Saltyhero13
    No noticeable leaks?
  10. Jun 6, 2022 at 5:39 AM
    #2020
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not yet.
    I'll do a better job looking in a couple weeks, when I do the next oil change.
    I use the red stuff, so it should be easy to see....
    Saltyhero13[QUOTED] likes this.
  11. Jun 6, 2022 at 6:33 AM
    #2021
    Saltyhero13
  12. Jun 6, 2022 at 6:34 AM
    #2022
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Ooowie
    TIpQEQEePHRtoS_eoFF0VcygfRotnFK4nBj_ZIab_f493011c93b60562e9d125b2c57929f4fe597752.jpg
    M3Tundra-JK likes this.
  13. Jun 6, 2022 at 6:36 AM
    #2023
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yesssss....
    Saltyhero13 and nags[QUOTED] like this.
  14. Jun 6, 2022 at 6:37 AM
    #2024
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I learn every time I watch that dude. (which is not hard when you are me)
  15. Jun 6, 2022 at 6:40 AM
    #2025
    Saltyhero13
    He is a great explainer. Even his long videos are dense with info.
  16. Jun 6, 2022 at 11:19 AM
    #2026
    nags
    nags New Member
    Here goes. Just sent some fresh logs off to ProSpeed.
    EE0AjnDOR1xs8mBhqRijUEx6IjdNIV76mHwdi63X_5e18a1f560cc5d89514cb9c8868ed0ac3fdbc2ad.jpg
    chugs, snivilous[OP], reywcms and 9 others like this.
  17. Jun 6, 2022 at 1:15 PM
    #2027
    Silver17
    Eastern PA
    I’ll give mine another look but I think it’s leveled out the last few times I checked. It should eventually work out all of the air pockets and stop needing to be topped off. If it continues to need more added I’d start looking for a leak just in case. I pray none of us ever have to deal with the leaking heat exchanger cores in the blower. Some of the first Harrop units for our trucks had a defect and leaked coolant into the intakes. It killed at least 1 engine I’m aware of. This is probably not the case, but it’s good to be aware anyway.
  18. Jun 6, 2022 at 7:30 PM
    #2028
    Silver17
    Eastern PA
  19. Jun 7, 2022 at 8:11 AM
    #2029
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Lead the way! just saw that there's going to be "redeye" TRX, and Raptor R is ready to drop, we going to have to put in extra work to get that "TRXLOL" plate.
  20. Jun 7, 2022 at 8:14 AM
    #2030
    nags
    nags New Member
    Don't think I have enough money for that plate.
    I'm pretty much at the end of the road unless I do a forged bottom end or build my heads. And I'm told both will make this no longer reliable enough for a daily.
  21. Jun 7, 2022 at 8:43 AM
    #2031
    Downytide
    GTA
    Is that what XAT/Prospeed feedback? I'd assume with a built bottom end and 700hp at crank it should be ok as long as we are not under wot at high load constantly.
    snivilous[OP] likes this.
  22. Jun 7, 2022 at 8:43 AM
    #2032
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Is it worth the $$$
  23. Jun 7, 2022 at 8:44 AM
    #2033
    nags
    nags New Member
    Definitely didn't notice any night and day difference or anything.. But having done just about everything else I can do... Seemed worth it to put the cherry on top.
    vq35721[QUOTED] and M3Tundra-JK like this.
  24. Jun 7, 2022 at 8:47 AM
    #2034
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Same reason I kept all the mods on my TRD S/C Tacoma build mild, and NOT wild. Sure the bearings on the s/c needed replacing when I sold it, but it was installed on the truck pretty much since day 1 and got 90k miles on it before I sold with no issues. Will be going the same route when putting the TRD S/C on the Tundra. Want to get many many miles out of this thing!
  25. Jun 7, 2022 at 8:52 AM
    #2035
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Is the RCF TB and Larger intake from them? I had this on my list of things to add lol
  26. Jun 7, 2022 at 9:42 AM
    #2036
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Huh? How does a properly assembled forged short block and head work make it any less reliable. Maybe you would see a little more oil usage, but we should all be keeping an eye on that anyways. I'm no expert though and want to learn, so please tell us what you've been told from Prospeed and/or XAT.
  27. Jun 7, 2022 at 10:24 AM
    #2037
    nags
    nags New Member
    Yes. I already had the intake but just added the RCF throttle body.
    reywcms[QUOTED] likes this.
  28. Jun 7, 2022 at 10:27 AM
    #2038
    nags
    nags New Member
    This was mostly info from talking to Matt Smith.
    Although XAT did tell me they wouldn't want to go too crazy for a street truck either when I was there talking to them. His own truck has the Whipple and nothing more.
  29. Jun 7, 2022 at 10:36 AM
    #2039
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    FYI on Prospeeds own blog when they tested the RCF throttle body modification it added ZERO HP and less than 30 FP of torque and the torque gain was at 6000 RPM
    M3Tundra-JK and reywcms like this.
  30. Jun 7, 2022 at 10:55 AM
    #2040
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Good info
