General Supercharger Thread
  1. Dec 12, 2024 at 11:41 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just received more pulleys for the 1900 Magnuson, this also included a batch of 4Runner/FJC specific hubs (the pulley offset is different) and I updated the pulley design to clear the 4Runner snout a bit better since they utilize the same Tundra pulley. Maybe getting all the hardware will motivate me to mess with the 95mm throttle body again :D
    I also got about 550 parts of various things I designed for my friends shock rebuilding company in Salt Lake City.
    Warreng, ARES35, HulkSmurf14 and 13 others like this.
  2. Dec 12, 2024 at 1:46 PM
    bflooks
    bflooks New Member
    Metrowest MA
  3. Dec 12, 2024 at 2:06 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    e30cabrio and bflooks[QUOTED] like this.
  4. Dec 12, 2024 at 2:17 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Gotcha. Do you. I was just adding to the robust list of sources provided and adding another forum member to mix.
    HulkSmurf14, Wynnded and carn_dogg like this.
  5. Dec 12, 2024 at 2:37 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Damn, I wonder about those 880's. Anyone on here running those? @TurboKits can you shed some light on this for me? Do these require a harness like the prospeeds or does it use the OEM harness much like the DW650's do?
  6. Dec 12, 2024 at 2:50 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I've been waiting for someone to report running them too.
  7. Dec 12, 2024 at 4:32 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I'm debating on pulling the trigger for the 880's. I'm getting tired of extended starts with the Denso 750's by fiveO!
  8. Dec 12, 2024 at 4:49 PM
    carn_dogg
    Pat
    Eastern Shore MD
    How extended are we talking? Like twice the amount of turn over?
    no change if you leave the key on for a sec to run the fuel pump?
  9. Dec 12, 2024 at 5:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The first start up of the day. I turn the key wait for 43psi and it starts right up. After its warm I usually wait a second and it fires up. But sometimes it will go into a second round of start cycle and fire up half way through. Other times there are no issues, go figure.
    I tried increasing/ decreasing IC adding air etc. It's mostly just annoying .
    Wynnded likes this.
  10. Dec 12, 2024 at 5:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was just going to ask you if you made any head way on the 95mm TB.
    ARES35 and snivilous[QUOTED][OP] like this.
  11. Dec 12, 2024 at 5:45 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    "It's yer tune." -FiveO ;):rofl:
  12. Dec 12, 2024 at 6:12 PM
    snivilous
    SW UT
    Absolutely nothing. But I'm going to order some more parts for other projects in two weeks or so, and thinking throw a RevB throttle body together that has an integrated lip for the throttle plate to seal against.
    I guess that'd leave me with two RevA prototypes to auction off or something :rofl:
  13. Dec 12, 2024 at 6:17 PM
    blenton
    blenton New Member
    Wall Art.
  14. Dec 12, 2024 at 6:22 PM
    snivilous
    SW UT
    Got a whole box of pulleys and hubs that won't work for one reason or another already, what's another few pounds of throttle bodies :D
  15. Dec 12, 2024 at 6:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yeah. And trying to tell him it's not and others have some issues doesn't matter.
    Wynnded[QUOTED] likes this.
  16. Dec 12, 2024 at 7:09 PM
    blenton
    blenton New Member
    You can send me a box of them. I’ll bring them in to the house next week and show the Mrs.
    ‘Well, I did some work on the truck, but I don’t know where these go. They must not be necessary. Leftovers? It seems to run ok so I’ll guess we’ll just send it..’
    Mdl, bflooks, e30cabrio and 1 other person like this.
  17. Dec 13, 2024 at 9:19 AM
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    I was tuned by you guys a few years ago. Truck runs great. But I have changes I would like to make. Is it possible to get an unlocked tune that I can tweak or do I need to start from scratch?
    NatesNightMare likes this.
  18. Dec 13, 2024 at 10:19 AM
    JustDSM
    JustDSM New Member
    Justin
    We do not provide an unlocked file.
    Work with your retailer, or send us an email, and we can accommodate. We have quite significantly updated our calibration since you've were tuned (based on your statement), so I'd encourage you to get updated to our latest file.
    ssmokedz[QUOTED] likes this.
  19. Dec 13, 2024 at 6:07 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    This AB60 teardown video from a 200 series by that Australian company is awesome and worth the watch. I’d buy stuff from these guys. I also learned a few things about the AB60 which are kind of unique such as for gears 1-4 it doesn’t disengage clutches to switch gears, it just keeps locking up additional ones until the 4-5 change where it disengages, and then does the same as 1-4 for the 5-6 change. They also have a good one on valve bodies rebuilds I’ll add below.
    https://m.youtube.com/watch?v=BFyZJLE-aIk&t=1888s&pp=2AHgDpACAQ==
    https://m.youtube.com/watch?v=L7MrxcEjHbQ
  20. Dec 13, 2024 at 7:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The transmission oil cooler video is great too. They state best temp is under (90 deg C)194 deg. And running cool (45-50 deg C) 113-122 deg is ok. Running (110-120 deg C) 230-248 deg is too hot. Will degrade oil seals...
    These are all general temps and didn't mention specific models. Without my atf thermostat my fluid was 150-170 deg. My current thermostat this summer (85 deg) didn't go over 197 deg.
    https://m.youtube.com/watch?v=DyU3LIpA-Mg
  21. Dec 13, 2024 at 8:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I like at minute 31:30 the cause is overheated oil causing c1 to fail in 1st gear probably in 4hi in sand... @reywcms. Keep em cool and a built Valve Body!
  22. Dec 13, 2024 at 8:28 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Never see near 230 pan temp in the sand but definitely planning on additional cooling either way with naca ducts on the rear fenders with coolers. Maybe try these Aussies out
  23. Dec 13, 2024 at 8:52 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I saw 231 (converter temp) sitting in traffic today, and 248 a few nights ago doing a really short pavement climb (2wd) into a neighborhood that probably took all of about 30-40 seconds in 2nd gear (very steep driveway)
    I've only had my SC3 for about a month now, but those temps really concern me. I never saw anything that high in my '08 even when towing...
    I'm starting to think it might be a good idea to pin the t-stat...
    We don't see freezing temps expect for a few days a year out here on the coast, and according to everything I've heard/read it wouldn't be an issue until it's really in the negative temps.
    Can anyone in here think of a reason for me to NOT do that to my '21 (at least until I've got a cooler installed)????
  24. Dec 13, 2024 at 8:55 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Had mine pinned since day 1
  25. Dec 13, 2024 at 9:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Last winter in 20-30 deg temps with no thermostat or warming puck I saw 150-170 degrees. It took about 15 minutes to come up to 150 deg.
  26. Dec 13, 2024 at 9:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hmm extreme or nomad unit lol
    ARES35, Silver17 and Mdl like this.
  27. Dec 13, 2024 at 9:20 PM
    blenton
    blenton New Member
    The tstat or the throttle? :mudding:
    ARES35, e30cabrio and Tripleconpanna like this.
  28. Dec 13, 2024 at 9:20 PM
    Tripleconpanna
    So, I'm not SC'd or anything...
    Am I still able to drive the vehicle normally prior to it reaching temp?? Usually, I don't spend a lot of time sitting in the driveway waiting to warm up prior to driving off; normally speaking, I just allow the oil to circulate and warm for a minute or two then I'm off... However, prior to it getting up to temp, I do try to keep the RPMs under 3k and stay out of the skinny pedal :thumbsup:
    ...or would pinning it cause any additional risk(s) prior to the fluids coming up to temp? In other words, would it force me to allow the truck to 'warm up' longer prior taking off after it has sat for a bit??
    HulkSmurf14 and Mdl[QUOTED] like this.
  29. Dec 13, 2024 at 9:21 PM
    Tripleconpanna
    You're also having yours rebuilt right now :laugh:
    Sorry, I had to... :anonymous:
  30. Dec 13, 2024 at 9:22 PM
    snivilous
    SW UT
    Those temperatures are crazy, 248???
    I recommend to everyone to pin the thermostat, and personally I have the torque converter lockup in 4/5/6 which drastically helps cooling the converter down to pan temp (wouldn't help in traffic though). And of course if you don't have a trans cooler, it costs $300 so I would do that if you dont have one.
