General Supercharger Thread
  1. May 30, 2022 at 12:18 PM
    #1981
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Sweet. Looks like I'll be saving $100.
    Silver17 likes this.
  2. May 30, 2022 at 12:54 PM
    #1982
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I just went out and unbolted my intake, throttle body, adapter and verified my RC-F throttle body doesn't mount on my TVS2650 without the adapter...if one side of the TB is bolted onto the SC, the TB is about 3/8" from the holes on the other side lining up. I also verified port matching isn't necessary for the adapter on the Harrop...at least on mine it transitions smoothly from the TB to the SC.
    Looking at the picture posted above, my RCF TB won't mount in that orientation because there is a heater hose in the way of the stepper motor and plug, I mounted mine with the plug at the top as specified in Harrop's instructions.
    Silver17 and nags like this.
  3. May 30, 2022 at 12:59 PM
    #1983
    nags
    nags New Member
    So you didn't need to port the snout at all? Just bolted right on?
  4. May 30, 2022 at 1:00 PM
    #1984
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That's correct, bolts on, smooth transition from throttle body to inside the SC snout.
  5. May 30, 2022 at 1:02 PM
    #1985
    nags
    nags New Member
    Well, fuckin' A. Looks like I've got some money to spend.
    Thanks for the clarification.
  6. May 30, 2022 at 1:04 PM
    #1986
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I think the porting is only for the Magnusson SC, as well as the loctite gasket eliminator...the Harrop has an o-ring and the adapter has an o-ring so no gasket material needed.
    nags likes this.
  7. May 30, 2022 at 1:09 PM
    #1987
    nags
    nags New Member
    Adapter is ordered. Now just gotta pull the trigger on a TB.
    M3Tundra-JK and snivilous[OP] like this.
  8. May 30, 2022 at 1:23 PM
    #1988
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yeet that skeet
    nags[QUOTED] likes this.
  9. May 30, 2022 at 1:42 PM
    #1989
    Saltyhero13
    Saltyhero13 Throbbing Member
  10. May 30, 2022 at 3:37 PM
    #1990
    nags
    nags New Member
    Throttle Body ordered .
  11. May 30, 2022 at 3:38 PM
    #1991
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Can we use this with the stock air box?
  12. May 30, 2022 at 6:18 PM
    #1992
    Saltyhero13
    From the link I posted before it implies you can.:
    The Prospeed Billet RCF Throttle Body Adapter Kit for the 2007+ Toyota Sequoia's allows a bolt-on solution to run the larger Lexus RCF throttle body which is a direct plug-in electronically. On supercharged applications, this decreases vacuum before the blower which results in more boost and higher power! This can also be combined with our 4.50” Race Intake system for maximum gains!
    vq35721[QUOTED] likes this.
  13. Jun 1, 2022 at 2:00 PM
    #1993
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I'm debating to go with Prospeed's upgrade and custom tune, how far should I go? I'm thinking:
    - Pulley
    - RCF tb
    Should I go with the 750cc injectors and the pump? anyone has done this and still daily drive it and use it for truck duty? or should I just save up and bring the truck to them one day and get the whole thing built?
    nobodyintexas likes this.
  14. Jun 1, 2022 at 2:10 PM
    #1994
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my vote - bring them the truck. 1000 less headaches.
  15. Jun 1, 2022 at 2:11 PM
    #1995
    nags
    nags New Member
    Ok
    A fact on the headaches. But also looking at probably 10x the labor fee.
  16. Jun 1, 2022 at 2:19 PM
    #1996
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  17. Jun 1, 2022 at 2:33 PM
    #1997
    Downytide
    GTA
    I've thought about that, it's 5000km round trip, and probably takes 1.5 day down (I've driven down to Tampa in similar time), all in all that'll eat up a whole week which will be hard to do, and I figure if I was to ship/bring truck down, I might as well get the shortblock built so I can order the "TRX LOL" plate.
  18. Jun 1, 2022 at 2:35 PM
    #1998
    Saltyhero13
    :popcorn:
  19. Jun 1, 2022 at 2:36 PM
    #1999
    nags
    nags New Member
    They quoted me $5400 for the install. I did the math every which way to get it to them and back and no matter if I drove or shipped it I was looking at least $1000 each way. And that was with gas prices 6 months ago. So I was realistically looking at about $7500 for the install all said and done. My local shop did it for $1500. I have nothing against ProSpeed by any means. But I just couldn't justify an extra 6 G's.
  20. Jun 1, 2022 at 2:39 PM
    #2000
    Downytide
    GTA
    What did the install consist of? that seems kinda high, I calculated with the s/c kit it took around 15-18hrs all together, that's taking the time too.
  21. Jun 1, 2022 at 2:41 PM
    #2001
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    For the time being if you’re looking to make a little more power I’d do the RCF TB, smaller pulley, and a minimum of 650cc injectors. That should be good for 600ish whp on a hub dyno with your other mods for sure. Then if you blow it up down the road, just swap those parts over to your new built block if that’s your end game. Any time it’s going to wind up at the Prospeed shop though you’re going to take it home with a massive bill is what I gather. They do premium work at a premium price. I bet you would probably get a little more affordable built engine from XAT.
    Edit: probably want the Prospeed fuel rails or parallel the rails with larger fuel lines as well.
    Saltyhero13 and nags like this.
  22. Jun 1, 2022 at 2:42 PM
    #2002
    nags
    nags New Member
    Not sure. I think a lot of it is you're paying for the name. My shop charged me 15hrs at $100/hr. That's where the $1500 came from. And it was their first time doing an SC on a Tundra. This is direct from their email. Didn't mention anything more;
    "Total labor time for this would be around 40 hours total at $5400"
  23. Jun 1, 2022 at 2:42 PM
    #2003
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Do your own labor everywhere possible, or find a local you trust, don't over-pay a speed shop.
    M3Tundra-JK likes this.
  24. Jun 1, 2022 at 2:43 PM
    #2004
    nags
    nags New Member
    That's my end game right there. Especially being that they're local.
    Silver17[QUOTED] likes this.
  25. Jun 1, 2022 at 2:44 PM
    #2005
    Silver17
    Eastern PA
    Those numbers though are based on what I’ve seen from the Harrop supercharged trucks on the web. Not sure how easy it is to get those numbers out of the magnuson.
  26. Jun 1, 2022 at 2:44 PM
    #2006
    Saltyhero13
  27. Jun 5, 2022 at 3:33 PM
    #2007
    Silver17
    Eastern PA
    Was it this thread that I read someone mentioned their intercooler pump relay was sticking? I noticed mine just started doing it, both sticking on and off. Only 6k miles on it since the install. I know it’s a cheap easy to replace part. I’m wondering if there is a beefier alternative than buying another one from Harrop.
  28. Jun 5, 2022 at 3:42 PM
    #2008
    Saltyhero13
    Yeah I think it was @nobodyintexas that had that issue
  29. Jun 5, 2022 at 3:52 PM
    #2009
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Yup
    I banged on the relay and it stopped
    it happened 3 times to me
    not recently though
    it only happened when I used accessory and then shut it off
    never happened when I started the truck and turned it off properly
    The relay is the issue. One of these days I’ll replace it with a better one
    too hot now
  30. Jun 5, 2022 at 4:47 PM
    #2010
    Silver17
    Eastern PA
    I only noticed mine was acting up because I tied in my LED DRLs with that relay. I’ll have to do some research. Maybe I can find the same relay but a different brand. The brand they sourced obviously sucks.
