General Supercharger Thread
  1. May 11, 2022 at 8:31 AM
    #1921
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve been pulling the 10amp fuse out of the relay for the intercooler pump as well to take that load off. I haven’t had any issues even just using the charger on the 8amp setting but maybe I’ll use 15 amps from here out.
    Wynnded likes this.
  2. May 11, 2022 at 8:32 AM
    #1922
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    I'll be pulling that as well as the fuel pump fuse per Matt Smith's suggestion moving forward.
  3. May 11, 2022 at 8:55 AM
    #1923
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Does a good jump box suffice or is a charger mandatory for flashing?
  4. May 11, 2022 at 11:32 AM
    #1924
    Saltyhero13
    Saltyhero13 Throbbing Member
    Anyone know if there are any issues running RAS and SDHQ Traction bars?
  5. May 11, 2022 at 3:58 PM
    #1925
    Saltyhero13
    Belay my last on the traction bars. Going to give the RAS a try before going to these traction bars. The bars look like good kit; need to deal with weak OEM leaf springs.
  6. May 11, 2022 at 4:07 PM
    #1926
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Ditto on the leaf springs
    Saltyhero13[QUOTED] likes this.
  7. May 11, 2022 at 4:12 PM
    #1927
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just to throw shit in the pond, I've never once hooked a charger up when flashing :D
    Wynnded, nags and Saltyhero13 like this.
  8. May 11, 2022 at 4:13 PM
    #1928
    Saltyhero13
    The Road Masters claim they reduce/eliminate axle wrap while supporting the rear springs. We shall see.
    On another note I'm hoping I don't hit my rev limiter to where I need the valve body upgrade.
  9. May 11, 2022 at 4:27 PM
    #1929
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I can see how they would slightly mitigate wrap
    but nothing like a traction bar.
    with your level of hp, you need the traction bars and the RAS for your other issues
    Bo-Hunter likes this.
  10. May 11, 2022 at 4:35 PM
    #1930
    Silver17
    Eastern PA
    Give us some feedback on how RAS does with axle wrap. I’m tempted to sometimes remove the airbags and go with RAS instead. The way theyre oriented they should definitely help a lot.
  11. May 11, 2022 at 4:35 PM
    #1931
    Saltyhero13
    Probably wont eliminate it completely.
    Unfortunately it may be either or. It doesn't look like both systems can be used at the same time. The other option is to get a new leafpack at some point.
  12. May 11, 2022 at 4:36 PM
    #1932
    Saltyhero13
    Will do if I go that route. The only way to really check is to mount a camera under the chassis.
    Silver17[QUOTED] likes this.
  13. May 11, 2022 at 5:01 PM
    #1933
    nags
    nags New Member
    Aaaand.
    I'm back in action.
    New ECM came in today and I worked with Matt Smith to get the thing all setup and matched up to my old VIN and get my ProSpeed tune back on. What a pain in the effing dick.
    HP Tuners was useless in this whole mess. ProSpeed told me to hit them up and they can usually fix it if I send them my ECU. I reached out to them.. They basically had me send some logs and told me to try to flash again. Flash failed. "Yep, ECM is bad, you need to buy a new one". And that was basically the end of their help.
  14. May 11, 2022 at 5:43 PM
    #1934
    Silver17
    Eastern PA
    Glad you got it fixed. Lesson learned I guess. Matt Smith is the salt of the earth, glad he was able to help you out. I know I owe him a beer. Sounds like you owe him a whole case! :cheers:
    Saltyhero13 likes this.
  15. May 11, 2022 at 5:45 PM
    #1935
    nags
    nags New Member
    I definitely owe him. Just gotta figure out what and find his address.
    1UP, Saltyhero13 and Silver17[QUOTED] like this.
  16. May 11, 2022 at 6:45 PM
    #1936
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  17. May 11, 2022 at 8:20 PM
    #1937
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    So glad you got er running!!:)
  18. May 11, 2022 at 8:38 PM
    #1938
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I have ras, still does bunny hop in 2wd, there's some axle wrap launching in 4hi, probably can film it but need my kid to set up the gopro
  19. May 12, 2022 at 3:22 AM
    #1939
    nobodyintexas
    nobodyintexas What?
    South of Houston
    <humming Mabaleene by Chuck Berry>
    look at Caddy go...
    I see that 2650..
    Cadillac Reveals The 685HP 2023 Escalade-V, The Industry's Most Powerful Full Sized SUV
    A supercharged legacy and AWD grip
    Rated at a GM-estimated 682 horsepower at 6,000 engine rpm and 653 lb-ft of torque at 4,400 engine rpm, the Escalade-V’s 6.2L hand-built supercharged and intercooled engine builds on a legacy of supercharged V-8 engines offered in Cadillac V-Series models, those being the second- and third-generation CTS-V models, the XLR-V, and most recently, the CT5-V Blackwing.
    The Escalade-V’s engine shares architectural similarities with the CT5-V Blackwing’s supercharged V-8, but features a larger, 2.65L R2650 TVS supercharger that helps overcome the higher inlet and exhaust restrictions on the full-size SUV application. It spins at up to 13,500 rpm to produce approximately 10 pounds of boost and has an electronically controlled bypass valve for optimal drivability. The supercharger’s unique four-lobe rotors are designed to broaden the engine’s power band, with great low-end torque production and strong high-rpm power.
    The rest of the engine is designed to support the high output and the greater cylinder pressures that come with forced induction, including a durable forged-steel crankshaft, forged steel connecting rods and forged aluminum pistons. The aluminum cylinder heads are stronger and handle heat better than conventional castings. The heads also feature lightweight titanium intake valves.
    A 10-speed automatic transmission pairs with the engine and features calibration for the unique powerband characteristics of its supercharging system.
  20. May 12, 2022 at 4:00 AM
    #1940
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Going out with a bang before transitioning to electric? :monocle:
  21. May 12, 2022 at 4:02 AM
    #1941
    nobodyintexas
    nobodyintexas What?
    South of Houston
    knowing Caddy...going out with a bang. probably literally.
  22. May 12, 2022 at 7:05 AM
    #1942
    Saltyhero13
    That will be great thank you. I'm not expecting it to fully mitigate wrap.
    I'll have to look at the SDHQ and RAS geometry again but it looks like its a mutually exclusive choice.
  23. May 12, 2022 at 7:37 AM
    #1943
    Downytide
    GTA
    I'm not gonna lie, I freaking love it, I would love one in red, hell, if Jeep decides to stuff a Hellephant into a Grand Wagoneer L, sign me the f up! I'll even get the plate says "canyonero".
    I reached out to SDHQ, see if they reply about group buy, the RAS is great for load in the bed, but I notice at the hitch it still sags more than I'd like, right now I'm waiting for some fittings to come in so I can test bags with RAS, if it sucks (which I think would), then I'm going to +3 shackles + bags + SDHQ.
  24. May 12, 2022 at 9:14 AM
    #1944
    ZPhilip
    Philip
    West Chester, PA
    Just for future planning, what’s a new ECM cost?
  25. May 12, 2022 at 1:57 PM
    #1945
    nags
    nags New Member
    Got one on eBay from a part out for $170 shipped. Not horrible but certainly money I wasn't planning on spending.
  26. May 12, 2022 at 4:36 PM
    #1946
    ZPhilip
    Philip
    West Chester, PA
    That’s great. I had over $1k in my head
    nags[QUOTED] likes this.
  27. May 17, 2022 at 4:46 AM
    #1947
    Saltyhero13
  28. May 17, 2022 at 5:12 AM
    #1948
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This right here....
    he nails it. every second of that video had meat in it.
    I wish a ring gap job would cost $1000.00
    but I imagine it would cost north of $5k.
    $15k if you did rod, pistons, bearings, etc.
    I would venture there if I could get the piston job, keep the compression the same....put the motor back together and it run as good as mine does now.
    then, Diderot the 70mm pulley.
    it never ends......
  29. May 17, 2022 at 5:19 AM
    #1949
    nags
    nags New Member
    Went and spoke to these guys yesterday. Starting to sound like I'm going to need a donor motor;
    mfejtln7_8lNL2OZI3NnEF6s4ONerNyxf6Nf-1Y9_e97b6163e0a475e45908d037daba17333df27e56.jpg
    YotaMan likes this.
  30. May 17, 2022 at 5:21 AM
    #1950
    nobodyintexas
    nobodyintexas What?
    South of Houston
    why? what broke?
    or are you building a new motor?
