General Supercharger Thread
  1. Nov 20, 2024 at 8:21 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    damn the bearing kits are a bit over 1k then if you get the motive gears bout the same as a name brand kit lol. guess these will be on the long term list lol
  2. Nov 20, 2024 at 8:22 PM
    NatesNightMare
    Pinetop Az
    now on another note with the 3" pipes ive been noticing quite a bit of backfire pops
    reywcms likes this.
  3. Nov 20, 2024 at 8:47 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Same here, but only planning to go 35's from 34's on my next tires. We do a lot of highway miles on trips and I like to keep the revs down. 4.30's, 34's, and a Harrop 80mm and I feel like I have plenty of torque, hell, too much without AWD in the wet.
  4. Nov 20, 2024 at 8:49 PM
    NatesNightMare
    Pinetop Az
    same i do more driving without towing than anything. i think the inbetween with the 4.88s would be best suited for me as well
    reywcms likes this.
  5. Nov 20, 2024 at 9:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Glad those shifts 4-5 are working out. I believe the AI/cruise portion will lock up 4th. I'll see it sometimes when I'm data logging.
  6. Nov 21, 2024 at 4:48 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @ZPhilip shared the link in the gear thread you can get the rear bearing kit for 400. ECGS has the front for 382 after applying the 15% off code. Add 170 for the gears, and you just got an entire gear package for under 1000 bucks. That’s at least 450 bucks cheaper than I have ever seen an entire package sold for, and that was probably pre stupid inflation era.
  7. Nov 21, 2024 at 4:52 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Screaming good deal right there! Almost offsets the entire cost of a Powertrax.
    e30cabrio and Silver17[QUOTED] like this.
  8. Nov 21, 2024 at 6:55 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    And of course, I found that Amazon Yukon sale after I ordered the same set from ECGS for $50 more(with 15% off sale)!
    Mdl and Silver17[QUOTED] like this.
  9. Nov 21, 2024 at 7:02 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    More pics.
    valve body leak test revealed 50% leak.
    They're rebuilding today and will have the transmission fully assembled this evening for installation tomorrow. They had all new bolts, pan, gasket, etc in house already.
  10. Nov 21, 2024 at 8:10 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    This begs the questions, are the materials in the valve body inadequate and/or is the WS fluid too thin for good protection.
    ARES35, Wynnded, HulkSmurf14 and 2 others like this.
  11. Nov 21, 2024 at 8:14 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    @carn_dogg Did they find any broken parts, or is it all worn-down parts and burnt clutches?
  12. Nov 21, 2024 at 8:24 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Im wondering if it makes sense to also throw in new shift solenoids while it's all apart? @Jowett do you have part numbers for those? I may toss in some fresh ones.
    HulkSmurf14 and Mdl like this.
  13. Nov 21, 2024 at 8:26 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Once again, amazing photos. I can tell by the way the things are, that they are things.
    :D
  14. Nov 21, 2024 at 9:00 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    This is what I have for solenoid #s, please double check. Don’t be surprised if they are expensive through Toyota USA.
    35290-34010
    35280-34010
    35210-50010 x 2
    35240-50030 x 2
    35240-50040
    35240-50050
    35240-50060
  15. Nov 21, 2024 at 9:04 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I thought about that too when I was swapping to the built VB. I just did a quick ohm check and applied power to see that they worked. I also attempted to clean them as best I could. Some are a bit spendy.
    reywcms[QUOTED] likes this.
  16. Nov 21, 2024 at 9:05 AM
    VWTim
    Corvallis, OR
    Fwiw, when I replaced a solenoid 2 years ago, I spend the $ for a Toyota part, only for it to made by the same company that was on Amazon for like 35.
  17. Nov 21, 2024 at 9:12 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Toyota USA is VERY expensive on most parts when compared to Japan. Occasionally, something here is actually cheaper, but not the norm.
    @VWTim good info if they are legit parts.
    HulkSmurf14 and reywcms like this.
  18. Nov 21, 2024 at 9:12 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    According IPT the VB is the weakest point in our transmission. The accumulators and shift ports dont seal well and wear out. The use of Trans Go or Sonnex kits by level 10 and IPT are in the built VB's.
    Also keeping the fluid on the cool side under 200 deg help with longevity.
  19. Nov 21, 2024 at 9:13 AM
    carn_dogg
    Pat
    Eastern Shore MD
  20. Nov 21, 2024 at 9:17 AM
    VWTim
    Corvallis, OR
    I had planned to just do a Sonnax zip kit+, but with 190K I'm now thinking of a IPT valve body to help limp my transmission along.
    HulkSmurf14, Mdl[QUOTED] and reywcms like this.
  21. Nov 21, 2024 at 9:36 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    I have the Sonnax Zip Kit and Line Booster that I need to install before pushing snow this season, never mind the requirements of that Supercharger sitting on the shelf.
    A new valve body with bores properly honed, then anodized, and a proper fluid would greatly increase the life of these things.
    Cool fluid = thicker oil film, especially with the group III oil base most of the fluids are manufactured with.
    Mdl, VWTim and reywcms like this.
  22. Nov 21, 2024 at 9:41 AM
    VWTim
    Corvallis, OR
    Fwiw, Nachi is the OEM for at least the S4 solenoid. I paid $200 for it to be in a Toyota bag but appears Nachi is available aftermarket.. unsure if anyone is going far enough to clone them.
    But for $57... https://www.amazon.com/Pithsdp-3524...732210595&sprefix=35240-50050,aps,294&sr=8-11
    reywcms and Mdl like this.
  23. Nov 21, 2024 at 9:46 AM
    blenton
    blenton New Member
    My biggest hesitation is how many counterfeit parts I've seen come from Amazon. Personally I've been sent several - and GOOD counterfeits, at that. After getting burned several times on fakes, the extra cost for a genuine part is just insurance for assurance. Have you been able to find them anywhere besides Amazon? Asking genuinely, not argumentatively.
  24. Nov 21, 2024 at 9:58 AM
    VWTim
    Corvallis, OR
    Your absolutely correct, lots of good counterfeits out there. I thought I also found them in a misc brand box from Napa, but I may be mixing it up with LBJ's.
    But if you're doing the work yourself, a $150/unit savings may be worth a gamble.
    Mdl likes this.
  25. Nov 21, 2024 at 9:58 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    After getting bad spark plugs from Amazon and dealing with multiple misfires where new plugs from the parts store cured the issue.
    I'm hesitant but have taken a gamble on some parts.
    Recently had my chinesium 80 amp relay for $15 melt on my e-fan.
    HulkSmurf14 and blenton like this.
  26. Nov 21, 2024 at 10:11 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Looks like very worn everything. Nothing broken yet, that I've been told.
  27. Nov 21, 2024 at 11:38 AM
    NatesNightMare
    Pinetop Az
    all them burnouts
  28. Nov 21, 2024 at 11:43 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    S4 35240-50050 is $64 + the ride from Japan.
    Is there a Nachi part number?
    HulkSmurf14, VWTim and Mdl like this.
  29. Nov 21, 2024 at 12:50 PM
    carn_dogg
    Pat
    Eastern Shore MD
    lol I wish. One wheel peel? It’s me, open diff guy.
    Mdl likes this.
  30. Nov 21, 2024 at 1:37 PM
    NatesNightMare
    Pinetop Az
    Abell207 likes this.
