General Supercharger Thread
  1. Oct 22, 2024 at 11:42 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Fwiw, Zuk mentioned the front diffs rarely needing bearings.
    Text from Zuk while mine was being done.
    "Now tapping the races back in with the new washer plates and by the way, the bearings are in very nice near new condition..,..... I don't expect to see worn out bearings hardly ever never in front 9-in clamshells... They only have 100 miles maybe a couple hundred miles on them due to the part-time nature"
  2. Oct 22, 2024 at 12:00 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    i believe yours will be different if youve got the cat back where it bolts up the front part of the stock exhaust.
    i have the rear cats removed and RIGHT at the downstream O2 i have a 2.5 to 3" reducer and its 3 all the way back from there
    Silver17[QUOTED] likes this.
  3. Oct 22, 2024 at 1:02 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Biting tongue, I have SPD & no code
    Silver17[QUOTED] and HulkSmurf14 like this.
  4. Oct 22, 2024 at 1:29 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve always heard these trucks are super sensitive with cats as far as throwing codes using anything but OEM, but no one seems to have an issue with these SPDs (maybe the bigger diamater helps)? I’m so pumped to hear how it sounds without the 2 sets of cats. I have always thought the sound was being held back from being truly awesome with all of my catbacks because of how much the stock cats muffle the sound.
    Mdl and reywcms like this.
  5. Oct 22, 2024 at 1:43 PM
    NatesNightMare
    Pinetop Az
    it wasn't a long time then pop, its done it ever scine i went larger pipes
  6. Oct 22, 2024 at 1:48 PM
    NatesNightMare
    Pinetop Az
    now thinking since its throwing an A/F code that would be the upstream O2 wouldnt it? could the O2 may be failing out?
    becuase doesnt the downstream O2 only monitor the cat?
  7. Oct 22, 2024 at 2:09 PM
    JustDSM
    JustDSM New Member
    Justin
  8. Oct 22, 2024 at 3:08 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Correct
    Mdl likes this.
  9. Oct 22, 2024 at 3:19 PM
    NatesNightMare
    Pinetop Az
    so do you think the up stream O2 is going out?
  10. Oct 22, 2024 at 3:21 PM
    snivilous
    SW UT
    No idea :rofl: swap them around if you're feeling froggy
    Mdl likes this.
  11. Oct 22, 2024 at 3:36 PM
    JustDSM
    JustDSM New Member
    Justin
    Exhaust valve seat cracked.
    Detected via leakdown.
    Vizsla, Wynnded, Mdl and 2 others like this.
  12. Oct 22, 2024 at 5:09 PM
    NatesNightMare
    Pinetop Az
    so maybe bad gasket between header and exhaust flange?
    HulkSmurf14 likes this.
  13. Oct 22, 2024 at 5:13 PM
    NatesNightMare
    Pinetop Az
    what gasket is that called? its a ring that is in there
  14. Oct 22, 2024 at 5:21 PM
    Silver17
    Eastern PA
    Thanks for the tip! So they can be reused easily without damaging them? By this logic, is all that’s really needed the mini install kit? Or is there a kit somewhere in between the mini and the master that may be necessary?
    https://eastcoastgearsupply.com/i-18979366-toyota-9-ifs-mini-install-kit.html
  15. Oct 22, 2024 at 5:58 PM
    NatesNightMare
    Pinetop Az
    ok so ill try replacing the gasket ring and go from there. next will be upstream O2, after that no damn clue o_O
  16. Oct 22, 2024 at 6:03 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I also remember reading that he reuses the factory ring gear bolts. But I would verify that before accepting that as fact.
  17. Oct 22, 2024 at 6:31 PM
    VWTim
    Corvallis, OR
    He did both of my diffs, but for LSD and elocker install, not gears. I went back and looked and he reused both ring gear bolt sets with red loctite.
    ZPhilip[QUOTED], Mdl and reywcms like this.
  18. Oct 22, 2024 at 6:46 PM
    pursuit2550
    pursuit2550 New Member
    Exhaust flange gasket or doughnut gasket, is what I have seen it called. Hard to keep up with all mods, but do you have aftermarket headers? Aftermarket heads usually dont have a gasket. It's a ball socket type of seal.
  19. Oct 22, 2024 at 7:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    When I did my auburn lsd my local shop said it's perfectly acceptable to reuse the ring bolts as long as you cleaned up the threads and used red loctite.
    HulkSmurf14, koditten and Wynnded like this.
  20. Oct 22, 2024 at 7:13 PM
    blenton
    blenton New Member
    When I did the Auburn 6 or 7 years ago, my installer was able to reuse all of the bearings and shims and it laid out just about perfect - well enough that I haven't had an issue in 130k miles of decently hard use. The truck had ~80k miles on it when the Auburn was installed. The trick was getting them off without damaging them. This go 'round, I'll replace them all. I'd imagine the fronts would be much easier to reuse, as noted above, because they don't see as many miles (unless you are @e30cabrio and drive around in AWD all the time). I'm sure my front diff has several thousand - if not 10,000 - miles of use on it.
    Also reused ring gear bolts without issue. I don't recall which MFG/Retailer it is that actually recommends reusing the factory bolts because 'they are stronger than the aftermarket bolts available'. I want to say it was ECGS, but I may be mistaken.
    I can't imagine you poor souls running around with a SC'd motor and open rear diff...
  21. Oct 22, 2024 at 7:49 PM
    NatesNightMare
    Pinetop Az
    no, stock headers. stock down past first cat. removed rear cats earlier this year. right after the downstream O2 i went 3" back.
    i went to autozone and got the doughnut one. maybe the old one is starting to let some out and causing the code
    pursuit2550[QUOTED] likes this.
  22. Oct 22, 2024 at 8:29 PM
    VWTim
    Corvallis, OR
    Oh, any stock front diff guys regearing...consider adding the ECGS bushing to replace the axle roller bearing. They're a super common cause of noise in the front ends of these trucks.
    *Edit* I've got the R&R tools around here somewhere if anyone wanted to borrow them. Eaton uses a bushing in their elockers.
  23. Oct 23, 2024 at 3:06 AM
    pursuit2550
  24. Oct 23, 2024 at 5:55 AM
    ZPhilip
    Philip
    West Chester, PA
  25. Oct 23, 2024 at 6:33 AM
    pursuit2550
    I tried looking just now and couldn't find it. Maybe it's just ECGS. :monocle: I haven't really done a deep dive into looking so I just did a broad search. I saw some complete 3rd members but it could also have been for the 1st Gen.
  26. Oct 23, 2024 at 12:38 PM
    pursuit2550
    Currently at work we have a 24 F150 XLT CC V8. Went out to lunch today and my friend stepped on it to get on the highway, holy crap. That thing is a beast. So I look up the specs and 400hp/410tq 13.9 in the 1/4. I never knew those trucks were that fast stock. Just thought I share since I have never been in a new one.
    What does a SC tundra run in the 1/4? Stock is like 15.
    e30cabrio likes this.
  27. Oct 23, 2024 at 1:00 PM
    Silver17
    Eastern PA
    Depends on mods and weight of course. 12.8-13.7ish I’d say is a good range. My best 1/8th was 8.30 @84 which translates to 12.9ish. When I had less mods it was more like a 13.6 1/4. I’m sure on stock tires and extra weight removed it could be a lot better since it weighs 6500lbs. Figure removing even 500 lbs is worth another .5 second in the 1/4. F150s are quick though being lightweight aluminum and the 10 speed.
  28. Oct 23, 2024 at 1:12 PM
    pursuit2550
    I guess I have to be cautious of those trucks then. Still amazing for a 400hp@crank vs 540hp@crank . Also noticed redline is 7k, wow. I guess the 10speed helps too.
    HulkSmurf14 and Silver17[QUOTED] like this.
  29. Oct 23, 2024 at 1:31 PM
    Silver17
    Eastern PA
    A supercrew 4x4 XLT v8 f150 is literally 5100 lbs based on my googling. 5300 max. That’s a LOT lighter of a truck for sure.
  30. Oct 23, 2024 at 1:48 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wow. My RCSB is all of 5280 lbs. Not much extra gear.
