General Supercharger Thread
  1. Sep 6, 2024 at 7:51 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Question for all of you SC folks towing heavy - how much KR Feedback are you seeing during throttle/load changes? We think we've hit the point where we are logging and seeing so much that we're essentially fighting the normal Toyota functions, meaning no tuning is going to stop the computers from learning and anticipating, then adjusting back accordingly. Really just looking for confirmation others see it, and that (like ECTs), we aren't trying to work out a problem that essentially doesn't exist.
  2. Sep 6, 2024 at 9:53 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I haven’t ever logged towing, so I can’t give you truly useful information. That said, every time I ever look at the live data on my SG3 it always has KCLV at 17 (which I believe is a good thing) and knock feedback at -3 when coasting and 0 under any varying load that I’ve observed it. I’m sure it is moving from that and I’m just not logging it or catching it with my eyes as a drive. What kind of numbers are you seeing in logs? @snivilous had some good input on what is common to see with these values before, linked below. https://www.tundras.com/threads/general-supercharger-thread.85513/page-375#post-3371740
    Wynnded and Mdl like this.
  3. Sep 6, 2024 at 9:55 AM
    blenton
    blenton New Member
    What ECT’s are you seeing? Pulling 8k enclosed at 70 mph I’m seeing 208F max in 5th gear if I’m riding the boost line and trans lockup. If I need more power, it kicks down to 4th and ECT’s drop a few degrees with more coolant flow (I’m assuming). It will start to climb a degree or two if I’m needing sustained power climbing a grade but still usually an degree or two than 5th gear.
    Mdl and bflooks[QUOTED] like this.
  4. Sep 6, 2024 at 10:04 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    sounds about right. thats what mine will do as i watch temps while towing. my temps will climb if not trans locked while towing and for the most part im riding boost line if not in it slightly
  5. Sep 6, 2024 at 10:43 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm right there with you. Like, spot on.
    Mdl likes this.
  6. Sep 6, 2024 at 10:47 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Thanks for the link! I'll get reading up on it. And I'll get you the specifics. @TurboKits has seen it and the small tweaks have not made any difference in my driving/towing experience which has us believing it is just normal. Figured it was worthy of a quick ask since it's not turbo specific.
  7. Sep 6, 2024 at 3:45 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Uhh does anyone need this MRP 4.5" intake tube? Also had a 3d printed filter adapter from the project I was doing. Tube I think is usually $95. Say shipping plus $40?
  8. Sep 6, 2024 at 3:52 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Also have some spark plugs for s/c Tundra/Tacoma left over. Say $5 each + shipping?
    Open to offers on this stuff. Just cleaning out tool boxes
  9. Sep 6, 2024 at 5:23 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Right coils came.
    ssmokedz, reywcms, Wynnded and 3 others like this.
  10. Sep 6, 2024 at 7:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are the left ones on back order?:rofl:
    Sorry, at work they regularly ask me if I'm ever going to grow up . . . :tinfoilhat:
  11. Sep 6, 2024 at 8:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Did you just want newer coils than the Lexus 90919-02269 ones? One has a denso part number vs the Toyota one.
    e30cabrio[QUOTED] likes this.
  12. Sep 6, 2024 at 8:11 PM
    e30cabrio
    In case the eBay coils fail, I want to be able to replace them.
    HulkSmurf14 and Mdl like this.
  13. Sep 6, 2024 at 8:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hopefully you were able to return those other coils. The Denso's were a decent price.
  14. Sep 6, 2024 at 8:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hopefully will pickup the 880cc turbokits injectors next month. The 750cc Five O's gave me a few extended starts...
    ARES35, TurboKits, reywcms and 3 others like this.
  15. Sep 6, 2024 at 8:20 PM
    e30cabrio
    Yup, I refused them when they came.
    Mdl likes this.
  16. Sep 7, 2024 at 1:30 AM
    Shmuckatelly
    Shmuckatelly New Member
    2015 Tundra Limited
    Big 3 + Aux Battery, Aux Lights, Air Tank, B81s, CS055R Springs, Air Bags
    Setting up a dual battery system here. I thought about it and then went with a deep cycle AGM. There are two issues with Lithium: Cold and Fire.
    Call me Doubting Thomas, but there are so many bad first-hand experiences with batteries in the cold I was having none of it. My own personal experience is limited to having one of those 5ah tool batteries dying because I left it in the cab overnight in freezing conditions.
    To my knowledge, you can't put out a lithium battery once it catches fire. The fire just keeps burning until it runs out of fuel. Did you see the news story https://asia.nikkei.com/Business/Au...under-pressure-following-South-Korea-EV-blaze about the Benz catching fire in a parking garage over there in Korea? Burned up 140 other cars. I would strongly suggest anything other than a Chinese made device!! :rofl:
  17. Sep 7, 2024 at 6:56 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    You should install a supercharger.
  18. Sep 7, 2024 at 9:25 AM
    e30cabrio
    I did AGM, no battery is worth 600+
    Anyone rebuild TRD calipers?
    https://www.tundras.com/threads/sold.147797/#post-3702705
  19. Sep 7, 2024 at 10:11 AM
    pursuit2550
    pursuit2550 New Member
    Don't know about rebuilding but there was another thread on another brand of big brake kits and TRD was discussed. I believe pads and rotors were on back order with no time frame IIRC.
  20. Sep 7, 2024 at 10:13 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I haven't done a triple piston one but it's not difficult. Pop out the pistons(clean them up), hone, install new seals...
    Did you find a TRD seal kit?
  21. Sep 7, 2024 at 10:15 AM
    AZTundra
    Paul
    Phoenix, AZ
  22. Sep 7, 2024 at 10:17 AM
    e30cabrio
    I'm in no hurry, I just installed new rotors and pads so it'll be years until I need to install them.
    Thanks!
    HulkSmurf14, Mdl and AZTundra like this.
  23. Sep 7, 2024 at 3:02 PM
    M3Tundra-JK
    Scott
    2005 GX470
    They are the ST-65 Stoptech calipers for reference. Slightly bigger pistons than the ST-60 that SOS sells for their BBK
  24. Sep 7, 2024 at 3:03 PM
    e30cabrio
    Thanks. I need to find brackets.
  25. Sep 7, 2024 at 3:05 PM
    M3Tundra-JK
    Scott
    2005 GX470
  26. Sep 7, 2024 at 4:12 PM
    e30cabrio
    They don't list them, I sent messages to them and several other retailers.
    Thanks.
  27. Sep 7, 2024 at 4:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Do the stop tech st65 brackets work on the trd's?
  28. Sep 7, 2024 at 4:46 PM
    e30cabrio
    I believe they are ST65's I also sent a message through Centric's site asking for them (and the rebuild kit)
    Mdl[QUOTED] likes this.
  29. Sep 8, 2024 at 1:11 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @ARES35 how's that vented carbon fiber hood working out?
    ARES35, reywcms and Wynnded like this.
  30. Sep 8, 2024 at 7:39 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    If you run into an issue obtaining the brackets, I have a 380 kit NIB, and can offer the brackets up in order to produce copies.
