General Supercharger Thread
  1. Aug 14, 2024 at 10:59 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    not sure if this was asked or answered but why not also run an external intercooler as well?
  2. Aug 14, 2024 at 11:21 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The external unit is the heat exchanger like a radiator. air to water setup essentially
    HulkSmurf14 likes this.
  3. Aug 14, 2024 at 11:53 AM
    pursuit2550
    pursuit2550 New Member
    Thinking out loud here. It makes sense, block the heat coming up from the valley plate, butttt. 2, things that stand out. 1. Just like it keeps heat from heating the SC, I would venture to say it also keeps heat in the SC since the blanket doesn't let it dissipate the heat. 2. The whole engine compartment is pretty much the same heat around the engine. So blocking heat from the bottom doesn't do much when the whole SC is basically in an oven.
    NatesNightMare likes this.
  4. Aug 14, 2024 at 12:07 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would think the best bet would be a thin piece of foam/insulation, don't fill the whole valley. That will keep the engine heat away, while also giving the blower room for airflow under it and pull heat off. But I also suspect the difference is negligible either way since the whole thing is an oven like you said.
    Now if the whole blower was sealed up from the rest of the engine bay, then I bet there'd be a big difference. Like the setups with the blower sticking out the hood, do that and insulate below it so it's not an aluminum block in an oven, I bet that really drops IATs.
    e30cabrio and reywcms like this.
  5. Aug 14, 2024 at 12:29 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Does anyone know the length of the intake manifold/supercharger mounting studs at the front of the engine?
  6. Aug 14, 2024 at 12:43 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Is the w/ end tanks, or just the core?
  7. Aug 14, 2024 at 12:44 PM
    snivilous
    SW UT
    38-40mm from my shitty scan:
  8. Aug 14, 2024 at 12:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    With end tanks
  9. Aug 14, 2024 at 12:54 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Appreciate it, but I need the total length, including what's threaded into the heads. I can probably remove mine with the blower still installed, but wanted to see if anyone had the info before I tried. The spacers came with screws to replace the studs, but I would rather keep the studs to make it easier to locate the supercharger and prevent slipping during reinstallation.
    Probably going with one of the stainless steel options here:
    https://www.mcmaster.com/products/threaded-rods/setup-studs~/
    snivilous[QUOTED][OP] likes this.
  10. Aug 14, 2024 at 12:57 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I can see the insulation being more beneficial for a downflow blower. It keeps the manifold/pan where the heat exchanger is located and the last part the air touches before entering the engine from getting as hot from the valley, meanwhile the rotor pack is mounted up above and dissipates heat to the engine bay as normal. On an upflow you can’t really insulate the area around the heat exchanger (the lid) so when you insulate the bottom you’re just insulating the rotor pack.
    e30cabrio and nobodyintexas like this.
  11. Aug 14, 2024 at 1:02 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Toyota was nice enough to supply this info, but only because there is a part # split.
    e30cabrio, armyoffoo and reywcms like this.
  12. Aug 14, 2024 at 1:14 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Here’s the 49.5mm stud, about 13mm threads into the block. 38mm is pretty close.
  13. Aug 14, 2024 at 1:14 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I don’t think any level of insulation will make a material difference
    koditten and NatesNightMare like this.
  14. Aug 14, 2024 at 1:25 PM
    Silver17
    Northeast
    reywcms likes this.
  15. Aug 14, 2024 at 1:25 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Perfect, thank you!
    reywcms likes this.
  16. Aug 14, 2024 at 1:54 PM
    JohnWhicker
    JohnWhicker New Member
    Super charger gas millage? tell me this ain't true LOL. I am on my second tank of 93 from Costco.
  17. Aug 14, 2024 at 1:55 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm lucky to get 9 city
  18. Aug 14, 2024 at 1:59 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I was going to ask you about mileage
    my hwy miles improved a smidge after the blower
  19. Aug 14, 2024 at 2:01 PM
    JohnWhicker
    6726 LOL. Still in diapers if you ask me.
  20. Aug 14, 2024 at 2:04 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Dash gas mileage and estimates are off if you've replaced the injectors, the computer doesn't account for that or the additional airflow from the SC, and the numbers are incorrect. Only way is to manually do the math every fill up, or use a ScanGauge to display a recalculated value.
  21. Aug 14, 2024 at 2:05 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    in use the scanguage 3
    it is very accurate once you run the first tank
  22. Aug 14, 2024 at 2:05 PM
    JohnWhicker
    Yeah I am about to get the ScanGauge 3 if I find an elegant way to install it. I like non-intrusive stuff.
    https://www.amazon.com/gp/product/B0BFBQZZMC?smid=A3NXQNUYKZG65G
    koditten likes this.
  23. Aug 14, 2024 at 2:22 PM
    e30cabrio
  24. Aug 14, 2024 at 4:29 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    every time someone mentions a sequoia, I miss our 2006
    it was our best vehicle.
    e30cabrio[QUOTED] likes this.
  25. Aug 14, 2024 at 4:43 PM
    snivilous
    SW UT
    Scale the injector flow. You have 535s now, stock is like 440, so 535/440 = 1.21. Divide your read out by 1.21 and I bet it's pretty close. ie like 13.x :D
  26. Aug 14, 2024 at 6:53 PM
    NatesNightMare
    Pinetop Az
    so i seem to get into boost Very fast/easy. it doesnt seem like it has the power/kick it had after i got the tune.
    we have traveled with our tow camper. im not getting any codes etc. ive checked all fittings, bolts etc
    not sure if im getting way to used to it or i actually have something weird going on
  27. Aug 14, 2024 at 7:00 PM
    koditten
    Kirk
    Midland of the Mitten
    Disconnect the battery and make it learn your drive style over again?
  28. Aug 14, 2024 at 7:28 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    I get into boost very quickly. A lite jab in part throttle can hit 4/5 psi easily. I have PE come in at 25 though so I dump some fuel to combat part throttle boost. What's your A/F when getting on it?
  29. Aug 14, 2024 at 7:36 PM
    NatesNightMare
    Pinetop Az
    i have an OTT tune so i dont see 10s at any boost. i usually wont see that unless im in higher boosts
    ARES35[QUOTED] likes this.
  30. Aug 14, 2024 at 7:48 PM
    ARES35
    Mile high
    I guess as long as you don't have knock. I had knock in part throttle especially in mountains so I've richened it up. I aim for mid 10's but will sometimes ramp in lower depending on load.
