General Supercharger Thread
  1. Apr 1, 2022 at 4:48 AM
    #1651
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    worth a shot....
  2. Apr 1, 2022 at 4:56 AM
    #1652
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Those are equal to 22s so at least it’s what a lot of people are running once supercharged. I could see it not being an issue under normal driving and short pulls, but if you’re having issues at WOT up above 100mph then it stands to reason in my simple mind that there could be pre-detonation.
    Saltyhero13 and nags like this.
  3. Apr 1, 2022 at 4:58 AM
    #1653
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    I was just trying to figure out which they were equal to. How do you figure that out? Is there an NGK model that is equal to the 24? I'm having better luck finding NGK locally.
  4. Apr 1, 2022 at 5:01 AM
    #1654
    Silver17
    Eastern PA
    I’m using this website. There are several NGK options listed so I cant say what the most direct equivalent is. See if you can find the ones that @nobodyintexas is using with the part number. Either way, I would not deviate from NGK or Denso brands. https://www.sparkplug-crossreference.com/convert/DENSO_PN/IKH24
    Saltyhero13 likes this.
  5. Apr 1, 2022 at 5:12 AM
    #1655
    nags
    nags New Member
    Got it. Going to pick those up right now and bring them to the shop.
    Thanks to all for the help with this. I'll keep you updated.
    Saltyhero13 and Silver17[QUOTED] like this.
  6. Apr 1, 2022 at 5:25 AM
    #1656
    Silver17
    Eastern PA
    Here’s to hoping it’s actually helping you and not sending you on a goose chase. You should check with Matt Smith since you’ve been in contact with him. Tell him you have IKH20s in there now and ask if that could be the issue. Like you said, he’s a smart guy when it comes to these trucks.
    Saltyhero13 and nags[QUOTED] like this.
  7. Apr 1, 2022 at 5:26 AM
    #1657
    nags
    nags New Member
    Ya know, we've talked about everything over the last week but never spark plugs. He's the reason I've got headers on the way as well. Going to message him right now.
    Oh, and the shop is swapping injectors first thing this morning.
  8. Apr 1, 2022 at 5:39 AM
    #1658
    nags
    nags New Member
    Just talked to Matt and he agrees with you about the plugs and had me order a different model of Denso. Headed to get them in a minute.
    Saltyhero13, ZPhilip and Silver17 like this.
  9. Apr 1, 2022 at 11:15 AM
    #1659
    nags
    nags New Member
    On the way to pick up the plugs right now. And as I'm driving I just got this from PS regarding the plugs I'm currently running.
    "We’ve tested the various plug heat ranges in multiple trucks. Because we run the mixtures much richer we found the stock heat range plug to be the best option in most cases. The colder plugs have more tendency to foul, and we found no real benefit to running the colder plug. Some people run the colder plug to mitigate knock, but typically their knock issue is fuel system and or tuning related and the colder plug is just a bandaide. Your truck is picking up ZERO knock, so you are good there. Predetonation is not even a thing.
    There is “Pre Ignition”, “Detonation”, and “Knock”, those are 3 things that are often lumped together and can all kill a motor, but they each happen at different times in the cycle and have different failure modes. The most common is knock, and is the least dangerous. Pre ignition or detonation would kill a stock 5.7 instantly as the pistons are not very strong form the factory
    I’d be willing to bet there is a leak around one of the injectors. I have seen this happen a few times and it can cause missfire issues under boost. The best thing would be to cap the throttle body and pressure/boost test the blower/manifold and see if there are any leaks around the injectors when under pressure".ure
    Saltyhero13 and Silver17 like this.
  10. Apr 1, 2022 at 2:29 PM
    #1660
    Silver17
    Eastern PA
    Well, I guess they know best! Hopefully your shop can find something. If they swap the cylinder 1 injector I wonder if it will follow it.
  11. Apr 2, 2022 at 10:22 AM
    #1661
    nags
    nags New Member
    Just got back from the shop. Plugs made no difference. Swapped the injectors around. Misfire did not follow. Ran the pressure test that ProSpeed recommended and passed with flying colors.
  12. Apr 2, 2022 at 10:54 AM
    #1662
    nobodyintexas
    nobodyintexas What?
    South of Houston
  13. Apr 2, 2022 at 11:13 AM
    #1663
    nags
    nags New Member
  14. Apr 2, 2022 at 11:15 AM
    #1664
    nobodyintexas
    nobodyintexas What?
    South of Houston
    @snivilous pointed me him out to me.....
    read some of his posts.
    I think he lives in a crystal palace in the arctic.
    snivilous[OP] and Saltyhero13 like this.
  15. Apr 2, 2022 at 11:30 AM
    #1665
    nags
    nags New Member
    Oh, and my headers, that said they were in stock, are now 6-8 weeks out. So, that's awesome.
    On Monday the shop is going to pull the cats and look for issues (per Matt Smith) and potentially pull the cat and do a quick run to see if the misfire goes away. If it does... Bye bye cat until the headers get here and I can get to the exhaust shop.
  16. Apr 2, 2022 at 11:55 AM
    #1666
    Silver17
    Eastern PA
    Possible broken valve spring? I read breaking them was more common on the earlier 5.7s.
    mustang67408 likes this.
  17. Apr 2, 2022 at 11:57 AM
    #1667
    nags
    nags New Member
    I guess at this point, anything is possible. No one has mentioned that as of this point until you. I'll bring it up.
    Strange thing is that the truck runs like a beast at all times... Until it hits around top of 4th. And at that point you can pop the Cylinder 1 coil off and right back on and you're back in action without even restarting the truck.
  18. Apr 2, 2022 at 3:59 PM
    #1668
    Silver17
    Eastern PA
    I got the thought from searching for the issue. Go on boosted tundras page and search “misfire” and you’ll get some reading material from over the years.
    nags[QUOTED] likes this.
  19. Apr 2, 2022 at 4:28 PM
    #1669
    Saltyhero13
    Saltyhero13 Throbbing Member
    On the HP forums?
    nags likes this.
  20. Apr 2, 2022 at 4:45 PM
    #1670
    Silver17
    Eastern PA
    It’s a page on Facebook. Lots of good tundra pages on there, but the supercharged tundra knowledge is the most plentiful on that page of anywhere I’ve seen.
    nags and Saltyhero13[QUOTED] like this.
  21. Apr 2, 2022 at 6:20 PM
    #1671
    nags
    nags New Member
    I did that. That's how Matt Smith got involved.
  22. Apr 3, 2022 at 8:15 AM
    #1672
    Silver17
    Eastern PA
    I know it’s been said before, but towing power with the supercharger is truly immense for a gas truck. Was pulling my 32’ 6500 lb. dry travel trailer on Friday. I’ve never burned out with a heavy trailer in tow on dry pavement with minimal throttle input before. The torque throughout the rev range is wild. Can’t imagine with 5.29s on top of it. I found myself passing slow traffic on hills without breaking a sweat. I think it’s going to be a fun camping season with relatively stress free towing.
  23. Apr 4, 2022 at 5:57 PM
    #1673
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If your truck starts running bad and idling at 9:1 AFR and can't maintain an rpm, check your intake since your friend may of installed an onion and part of it may have gotten sucked through your supercharger and fouled the MAF :rofl:
    Kung, nobodyintexas, omgboost and 3 others like this.
  24. Apr 4, 2022 at 6:03 PM
    #1674
    nags
    nags New Member
    Looks like Matt Smith was right from the get go. Bad cat.
  25. Apr 4, 2022 at 6:04 PM
    #1675
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What's the plan? ;)
  26. Apr 4, 2022 at 6:06 PM
    #1676
    snivilous
    SW UT
    To be honest, I may have installed a burrito through the HVAC vent on his 3rd gen 4runner at KOH and it slid down far enough you can't see it anymore :rofl: so I had it coming, I'm just glad this was a simple fix since that burrito has been in his heater core for 2 months now :p
  27. Apr 4, 2022 at 6:07 PM
    #1677
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    How many miles the cats?
  28. Apr 4, 2022 at 6:09 PM
    #1678
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Did the same to a coworkers truck, but with little sleigh bells. Every corner was like Christmas!
    snivilous[QUOTED][OP] likes this.
  29. Apr 4, 2022 at 6:13 PM
    #1679
    nags
    nags New Member
    I'm assuming they're original. If so, about 100k.
    Going Friday to have a custom midpipe with resonators made to replace all cats.
    HonorNotInner[QUOTED] likes this.
  30. Apr 5, 2022 at 3:07 AM
    #1680
    nobodyintexas
    nobodyintexas What?
    South of Houston
    this brought a tear to my eye...
