General Supercharger Thread
  1. Jun 2, 2024 at 11:39 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    Yeah thats also what I was thinking. If anything I would go up in size to a 2ltr but I dont think the trouble of changing out the fittings is worth it
  2. Jun 2, 2024 at 2:44 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep works well. I’ll be snagging one this summer most likely.
  3. Jun 2, 2024 at 2:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I saw a carbon fiber one with a front scoop like the one pictured. Any issues with rain? I've been eyeing it off and on. May pick it up...
  4. Jun 2, 2024 at 3:00 PM
    NatesNightMare
    Pinetop Az
    Sent you a message
    Mdl[QUOTED] likes this.
  5. Jun 2, 2024 at 3:11 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Man that's pretty slick looking! Figure removal of all the dents I received, new hood would probably be cheaper. Dig the looks of this!
    Mdl and reywcms[QUOTED] like this.
  6. Jun 2, 2024 at 3:12 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Should match his carbon fenders well
    HulkSmurf14, Mdl and ARES35[QUOTED] like this.
  7. Jun 2, 2024 at 3:13 PM
    ARES35
    Mile high
    My fenders took a beating also......maybe go CF fenders also. This is all dependent on what the adjuster says.
    reywcms[QUOTED] and Mdl like this.
  8. Jun 2, 2024 at 3:18 PM
    ARES35
    Mile high
    My concern also is rain. I ran a CF hood on an old nitrous SER sentra, yeah it was ricer'ed out, I was young lol. It had inserts I could put on for rain/ snow. Wonder if these options are the same deal?
    reywcms, HulkSmurf14 and Mdl[QUOTED] like this.
  9. Jun 2, 2024 at 3:23 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Pic attached
  10. Jun 2, 2024 at 3:25 PM
    ARES35
    Mile high
    Looks like some nice pieces! Are these widebody? Right now with stock and fender im running flush. Be sweet if these were flush without the fender flares.
  11. Jun 2, 2024 at 3:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The site said rain wasn't an issue and some made block for the vents.
    ARES35[QUOTED] likes this.
  12. Jun 2, 2024 at 3:25 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes this is wide body for all the travel clearance
    ARES35[QUOTED] and Mdl like this.
  13. Jun 2, 2024 at 3:27 PM
    ARES35
    Mile high
    Understood. This hood had plastic inserts that wing nutted on for storms. But if they say rain isn't a issue then so be it.
  14. Jun 2, 2024 at 3:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Does it need to be pinned?
    ARES35 likes this.
  15. Jun 2, 2024 at 3:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea we pinned it. Should absolutely be pinned
    HulkSmurf14, Mdl[QUOTED] and ARES35 like this.
  16. Jun 2, 2024 at 3:35 PM
    ARES35
    Mile high
    From what I remember back in the day always pin CF hoods...but I wasn't sure if now days maybe they didn't need pinning. Good info.
    Mdl, HulkSmurf14 and reywcms[QUOTED] like this.
  17. Jun 2, 2024 at 3:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Pinning is still needed at high speeds...or if it's latched solidly...is that a word?
    ARES35 and Mdl like this.
  18. Jun 2, 2024 at 3:39 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The carbon fiber company highly recommended pinning even though it's reinforced.
    NatesNightMare and ARES35 like this.
  19. Jun 2, 2024 at 3:40 PM
    ARES35
    Mile high
    Bear with me but from what I remember the lite weight of CF and highway speeds could be a bad mix. Pin for that extra insurance.
    NatesNightMare and Mdl like this.
  20. Jun 2, 2024 at 3:40 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Mdl and HulkSmurf14 like this.
  21. Jun 2, 2024 at 3:42 PM
    HulkSmurf14
    2014 Tundra Limited
    Agreed! ^^
  22. Jun 2, 2024 at 3:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    HulkSmurf14 likes this.
  23. Jun 2, 2024 at 3:55 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    That only has 1/2" NPT ports, I would look for something with 3/4" inlet/outlet or you will introduce a restriction. Honestly, a larger reservoir only prolongs heat soak, you will still get to the same IATs as before, it will just take marginally longer to get there. A larger reservoir won't give you any delta difference between ambient and IATs.
    Source: I bought the over-priced ProSpeed reservoir. I get the same IAT temperature delta as before, it just takes a couple of minutes longer to get there. Being made of metal and located in the engine bay doesn't help it with the heat soak either.
  24. Jun 2, 2024 at 3:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  25. Jun 2, 2024 at 3:59 PM
    e30cabrio
  26. Jun 2, 2024 at 4:01 PM
    e30cabrio
    Seeing as it is over 90 80% of the time, I'll move on from adding water. Only 105 now. lol
    Thanks
  27. Jun 2, 2024 at 4:05 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, it just delays the inevitable. You need something to actively cool off the charge or the heat exchanger. Either a low % water meth injection, or one of those intercooler sprayers that straps to the heat exchanger and sprays onto the fins to cool it down.
  28. Jun 2, 2024 at 4:22 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    What would be cool is something like a fuel chiller. It's basically a box with a aluminum tubing curled up inside with ends that terminate in fittings for connecting your fuel system to. The inside of the box is then filled with ice and the tubing and fluid within are cooled by the ice. The only issue with the fuel chillers is they are also 3/8" tubing, which would reduce flow in our use case. But if one could be made with 3/4 aluminum tubing, large mouth for ice and a petcock to drain it, that'd be the way to go. Once your IATs hit their usual delta, pull into a corner store, drain and fill with fresh ice...good to go.
    e30cabrio, NatesNightMare and ARES35 like this.
  29. Jun 2, 2024 at 4:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes you’ll want to pin it the latch isn’t enough alone no matter the speed.
    ARES35 likes this.
  30. Jun 2, 2024 at 5:12 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I doubt that would be an issue with a well designed hood. I would bet they don't run inserts on the hood so it's easy to tear through the carbon. Maybe @reywcms can comment on how the hood is attached at the front and at the hinge line and if there's metallic inserts bonded in.
