General Supercharger Thread
  1. May 21, 2024 at 7:01 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I do exactly the same thing as Dave. As long as it's richened out in boost, I usually just let it chew. If it's making 5+ psi or so for an extended period I usually downshift just since I get worried about sitting in boost for that long. I've also seen coolant temps start to climb if it's in boost, even a low amount, for a long duration. I'm not sure what's more stressful, revved out or boost--if it's the same horsepower at the end of the day. Personally that line of stress I'm willing to accept for minutes on end is that 4-5psi mark, then I feel revved out is better.
  2. May 22, 2024 at 3:10 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    e30cabrio and Silver17[QUOTED] like this.
  3. May 22, 2024 at 3:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    as a favor to those that are simpatico with you, can you explain, what you did to change your tune?
    I am in the exact situation & would like to be able to tell my tuner what needs to change.
    is it as simple as moving the PE engagement down a few % points?
  4. May 22, 2024 at 4:27 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Someone like @snivilous would be better at explaining what is needed. Essentially my PE engage has been adjusted to 25 degrees of throttle angle and disengage at 20 degrees. This equates to engaging at 36% TPS and disengaging at 32% TPS. To keep it from going full rich in those scenarios, Dan tweaked the fuel cells in the tune in the 1600-2400rpm for PE. I’d have to compare the files to say 100% what was changed, but Sniv adjusts these things on a regular basis. He also prefers to let it go full rich rather than trying to feather a mid-range AFR as I did if I understood him correctly in prior posts. This was briefly touched on in the most recent posts of the “how to tune with HPtuners” thread if you want to check that out.
  5. May 22, 2024 at 4:34 AM
    bflooks
    bflooks New Member
    Metrowest MA
    @Mdl would you please tell them the solution to keeping cylinders cool while in boost, regardless of RPM? :stirthepot:
    Mdl and Silver17 like this.
  6. May 22, 2024 at 5:06 AM
    Silver17
    Eastern PA
    Momma always says not to have a dependence on meth. That, and alligators are ornery cause they got all them teeth but no toothbrush.
  7. May 22, 2024 at 5:07 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Mama, mama ,Mama says... Great movie!
  8. May 22, 2024 at 5:29 AM
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Do it and don't look back!
    koditten[QUOTED] and Mdl like this.
  9. May 22, 2024 at 5:36 AM
    ssmokedz
    Shelton CT
    That's just plain cool!
  10. May 22, 2024 at 6:12 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Firemandan's fueling setup got me thinking about the cooling sauce...water/methanol. And I'm mainly at a 30% w/m mix just for a little bit of extra cooling.
    I'm at 24 enable 22 disable and may lower it a lite bit as I'm at 4-6 psi pretty early with @snivilous 2.0 pulley.
  11. May 22, 2024 at 6:17 AM
    ssmokedz
    Shelton CT
    After 3 long years on jackstands I finally have my garage back. And the Tundra just barely fits! I did some sketchiness to get the car on the trailer but I didn't die. Threw in a new set of seats so I could at least feel like there was one upgrade done. Passed emissions for the last time on this car. Never has to go again! Then grabbed a quick beer at a brewery with my buddy and his newly whippled rock warrior. Overall it was a good weekend. IMG_3968.png IMG_3961.jpg IMG_3826.jpg IMG_3737.png IMG_3977.jpg IMG_4103.jpg
  12. May 22, 2024 at 6:20 AM
    Silver17
    Eastern PA
    Anyone ever consider just water injection? I think BMW used it on at least one of their engines. It provides cooling without adding fuel or worrying about rotor coatings.
    e30cabrio and Mdl like this.
  13. May 22, 2024 at 6:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Lots do it. Just do not spray at high concentration at low rpm's as it can bog the engine down. I'm really not worried about rotor coating or pitting. Usually those that try to go 100% methanol. That will eat aluminum in a heartbeat.
  14. May 22, 2024 at 6:33 AM
    Silver17
    Eastern PA
    You’re probably fine at your %. At this point I’m just too lazy to have to alter the tune for the increase in fueling from the meth lol.
    e30cabrio, Mdl[QUOTED] and Wynnded like this.
  15. May 22, 2024 at 6:40 AM
    Silver17
    Eastern PA
    You’re gonna have to run you and your buddy’s RW now…. For science.
    e30cabrio, Mdl and Wynnded like this.
  16. May 22, 2024 at 7:02 AM
    ssmokedz
    Shelton CT
    Ya that will definitely happen. We both punched it the other day when i was behind him. I was right on his bumper through first and second but it seemed like he ever so slightly was starting to pull away in 3rd gear. It's almost time for me to throw in the injectors I bought from @Fastlane47 and a smaller pulley and see what i can do. I'm still on the stock maggy.
  17. May 22, 2024 at 7:09 AM
    ssmokedz
    Shelton CT
  18. May 22, 2024 at 7:36 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Saltyhero13 likes this.
  19. May 22, 2024 at 7:38 AM
    ssmokedz
    Shelton CT
    Ya he was smiling and gave me a big thumbs up when I was getting off the highway. I jumped on him not thinking he would floor it but now it has me wondering if he would have pulled me back in or not. This is the second TRX I've messed with and still have not been able to get an actual run in with one. Only @reywcms seems to know what it's like to walk a Rex.
    Saltyhero13, reywcms and e30cabrio like this.
  20. May 22, 2024 at 7:41 AM
    e30cabrio
    I love making the Az racer bois cry.
    lol
    Did it a few times in the BMW last week too!
    :p
  21. May 22, 2024 at 7:45 AM
    ssmokedz
    Shelton CT
    That little car must be fun.
    e30cabrio[QUOTED] likes this.
  22. May 22, 2024 at 7:48 AM
    Silver17
    Eastern PA
    Haha I was wondering if there was a car in front of him, or of he realized when he stomped it that he wasn’t gonna reel you in, and that it was too embarrassing to stay in it any longer and opted to just act as if he wasn’t trying. :rofl:
  23. May 22, 2024 at 7:51 AM
    ssmokedz
    Shelton CT
    Unfortunately, there was cars in front of us both. Total bummer we couldn't have a little more fun. But ya I think he knew either way it wasn't gonna be like he walks away from me :rofl:
  24. May 22, 2024 at 7:58 AM
    e30cabrio
    It is 2800lbs & has at least 350hp, traction is the main issue, I am learning it so I don't pull a cars & coffee exit. :p
    Saltyhero13 and ssmokedz[QUOTED] like this.
  25. May 22, 2024 at 8:05 AM
    ssmokedz
    Shelton CT
    Please I don't want to see a mustang post in here!
  26. May 22, 2024 at 8:06 AM
    Silver17
    Eastern PA
    Not saying the TRXs are not quicker in most cases, but it’s definitely not enough of a difference to care about it sure seems to me. They’re definitely closely enough matched.
  27. May 22, 2024 at 8:09 AM
    ssmokedz
    Shelton CT
    Dead stop drag race the Tundra is outmatched hands down. Launch control, better trans, etc. But on the highway I think the Tundra being lighter makes it about even.
  28. May 22, 2024 at 8:11 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Awesome! No one expects a tundra to do what they do. It's the best part lol
  29. May 22, 2024 at 8:11 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Shit I wish mine was lighter than a trx.
  30. May 22, 2024 at 8:13 AM
    ssmokedz
    Shelton CT
    Ya yours is a big bitch! I'm sure even mine's not MUCH lighter than a TRX.
    e30cabrio and reywcms[QUOTED] like this.
