General Supercharger Thread
  1. Mar 23, 2022 at 3:50 PM
    #1531
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Saltyhero13[QUOTED] likes this.
  2. Mar 23, 2022 at 4:18 PM
    #1532
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just imagine the people with stock trucks who have nearly a 15% power loss, especially if you aren't geared. Sounds slow af :rofl:
  3. Mar 23, 2022 at 4:28 PM
    #1533
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    It can’t be very stimulating
  4. Mar 23, 2022 at 4:38 PM
    #1534
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I just put a 200lb. Cap on my bed and I’m thinking it feels slower. Can’t imagine having that much extra rotating mass.
  5. Mar 23, 2022 at 4:43 PM
    #1535
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    It’s kind of like body dysmorphia but with our trucks lol
    Silver17[QUOTED] likes this.
  6. Mar 23, 2022 at 5:03 PM
    #1536
    Saltyhero13
    Saltyhero13 Throbbing Member
    I didn't particularly care for that set up I was more interested in the vehicle performance before and after the mods.
  7. Mar 23, 2022 at 5:12 PM
    #1537
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    It would be kind of cool if Toyota let you choose different gears if you build a tundra. Ford and dodge will let you do it but I don’t think Toyota does. Atleast have one other option would be nice, if you know you’ll go with larger tires
  8. Mar 24, 2022 at 3:19 AM
    #1538
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    yup.
    I'll 2nd @snivilous on the Stock truck on big tires....normal driving must feel like you are towing a Mastercraft X26.
    Pardon me for bringing this up in a Blower thread -
    one of the more mathematically inclined hombre's around here could probably pull a MPG/efficiency loss from those figgers as well. If one were so inclined.
  9. Mar 24, 2022 at 4:13 AM
    #1539
    Saltyhero13
    At one point the host takes it on a drive and claims he is getting 11.8MPG (7:25 mins) and in the comments he says he is getting 11.5 MPG hand calculated with the 529 regear.
  10. Mar 24, 2022 at 4:36 AM
    #1540
    nobodyintexas
    nobodyintexas What?
    South of Houston
    so...a stock truck gets ~15? big tires get ~12? seems right, as has been hashed in 4,253 threads so far.
    I wonder if his 11.8 is because the blower is into boost more than a stock truck just to get the unsprung weight moving. or, said differently, the driver simply having the ability to push the skinny pedal & make the truck move a LOT faster than stock.
    Extended city driving gets me down to 14mpg.
    now that I have a few 1000 miles on the stage 2....if I stay out of open loop/PE, my mileage* calculates very accurately on the scanguage II. However, once you open it up, it appears the larger injectors completely wreck the calculation algorithms. on-ramps & passing cars are quite enjoyable.
    *the dash MPG is hosed...it says I get 27.5 mpg. and a full tank has a range of 715 miles. Hello Elon!
    omgboost and Saltyhero13[QUOTED] like this.
  11. Mar 24, 2022 at 4:48 AM
    #1541
    nobodyintexas
    nobodyintexas What?
    South of Houston
  12. Mar 24, 2022 at 4:50 AM
    #1542
    Silver17
    Eastern PA
    I have a theory on the MPG readout. I think the scangauge would ordinarily track mileage fairly accurately once you calibrate through the “fillup” procedure despite the larger injectors. I think the reason it becomes less accurate when you do more WOT is because our Harrop setups are using boost referenced fuel pressure regulators. Out of boost it maintains a pretty steady 43ish PSI, but under boost it jumps up to more like 50. That is something the computer can’t really measure and it still thinks we are running at a constant 43psi, and therefore skews fuel flow rate and MPG readout.
  13. Mar 27, 2022 at 5:50 PM
    #1543
    Saltyhero13
    That is who I used. Inquiring about their Stage 3 offering.
    • Harrop Engineering TVS2650 supercharger system
    • OEM Lexus RC F 84mm throttle body
    • Prospeed Autosports 4.50" air-intake system
    • ZPE GripTec 80mm supercharger pulley
    • DeatschWerks 650cc/min fuel injectors
    • Harrop Engineering high-flow fuel pump
    • NGK LFR6AIX-11 spark plugs
    • Genuine OEM Toyota coolant
    • Custom Calibration via HP Tuners or VF Tuner
    • Optional:
    https://nationalspeedinc.com/packages/toyota/toyota-truck/2007-2021-tundra/tundra-xk50-platform/
  14. Mar 27, 2022 at 5:53 PM
    #1544
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    That's almost my identical install minus the RCF throttle body. I wonder if I should have done that.
  15. Mar 27, 2022 at 5:59 PM
    #1545
    Saltyhero13
  16. Mar 28, 2022 at 3:28 AM
    #1546
    nobodyintexas
    nobodyintexas What?
    South of Houston
    @Saltyhero13
    same here. <still eyeballing the 4.5")
    I am intrigued. Ya think this would get you ~500-510whp? @nags - what did you dyno at?
    if you can get an extra 1 psi & "safely stay on A MAF map" I'm all over it.
    I see that's the TB for the 5.0L....sexy.
    Giddy up, Salty.
    Saltyhero13 and nags[QUOTED] like this.
  17. Mar 28, 2022 at 3:58 AM
    #1547
    redrum448
    redrum448 New Member
    Teslas are so cute.....
  18. Mar 28, 2022 at 4:11 AM
    #1548
    nobodyintexas
    nobodyintexas What?
    South of Houston
  19. Mar 28, 2022 at 4:15 AM
    #1549
    redrum448
    my video proves the 918 walks the tesla mechanically( and sounds 1,000,000 times better)
    you gave me a video of a crappy driver evidently....
  20. Mar 28, 2022 at 4:24 AM
    #1550
    nobodyintexas
    nobodyintexas What?
    South of Houston
    top speed, sure. It's a $1mm out of production ride.
    but it takes the WHOLE DAMN TRACK for it to catch up.
    bad driver or not.
    see, in a plaid, my wife could do a 9.3 1/4 mile. (918 does 9.8 WITH A GOOD DRIVER) Plaid doesn't need a "good" driver. that's how the world is changing.
    I don't like this fact any more than you do. The world is changing.
    Saltyhero13 and nags like this.
  21. Mar 28, 2022 at 4:34 AM
    #1551
    redrum448
    we must have watched a different video... the 918 passes it after about 1 second then destroys it
  22. Mar 28, 2022 at 4:47 AM
    #1552
    nags
    nags New Member
    Still in the process of tuning it. I keep getting a misfire on cylinder 1 at WOT runs up around 100mph so that's put a kink in things. It hasn't been on a dyno at all.
    Saltyhero13 likes this.
  23. Mar 28, 2022 at 4:47 AM
    #1553
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ah, I see now. my fault.
    that's an older P100D not a Plaid. HUGE difference.
    my vid shows you the difference a Plaid makes.
    snivilous[OP] and nags like this.
  24. Mar 28, 2022 at 4:51 AM
    #1554
    nobodyintexas
    nobodyintexas What?
    South of Houston
    sending good vibes in your general direction.
    nags[QUOTED] likes this.
  25. Mar 28, 2022 at 4:53 AM
    #1555
    redrum448
    is that the one (or maybe its all) that the battery is dead if they do 10 runs (in insano mode or whatever)
    if so we just need to race 21 times lol ( hell Ill run him 21 times in my tundra:) )
  26. Mar 28, 2022 at 4:53 AM
    #1556
    nags
    nags New Member
    Hopefully that helps cause so far nothing else has. Ruled out plugs and coils so far. ProSpeed had us re-gap the plugs as well. No luck. Another installer suggested maybe an issue with the cat. Will be checking that today.
  27. Mar 28, 2022 at 4:57 AM
    #1557
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I think I would tear my Tundra up if I raced it 21 times.
    this dude drives his plaid home after whooping ass all night.
    _____
    dunno about low battery stuff. this dude races a bunch times in one night. 1/8th mile 6.05sec 120mph!
    https://www.youtube.com/watch?v=UZkxkMjFrrU&ab_channel=TeslaPlaidChannel
  28. Mar 28, 2022 at 4:59 AM
    #1558
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I am not a tuner...as all could tell you. but the sticking point with my truck was the injectors (DW650's). they spent all day on the dyno fiddling with them. are those ruled out via a good tune?
  29. Mar 28, 2022 at 5:00 AM
    #1559
    nags
    nags New Member
    The injectors are brand new with the ProSpeed Fuel system and we're about 8 revisions in to tuning with ProSpeed, so all I can say is ..... I assume so?
    nobodyintexas[QUOTED] likes this.
  30. Mar 28, 2022 at 5:34 AM
    #1560
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Why did you have to show me this? Now I'm trying to find $12K and a trip to VA :bikewheelie:
