General Supercharger Thread
  1. Apr 29, 2024 at 6:43 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Also, just general functionality or need to access things is much easier with the Whipple.
    M3Tundra-JK, Mdl and pursuit2550 like this.
  2. Apr 29, 2024 at 6:44 AM
    pursuit2550
    pursuit2550 New Member
    The way they have explained it to me years ago was, tq helps you get there and HP helps maintain you there. So, yes I prefer higher tq to get you moving faster, quicker.
    Mdl[QUOTED] likes this.
  3. Apr 29, 2024 at 6:48 AM
    pursuit2550
    When I installed the Maggie this weekend, the bolts that hold it down are a bitch to get to. The rest was pretty straight forward, just a lot of steps.
    Mdl likes this.
  4. Apr 29, 2024 at 6:50 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep also didn’t love the coupler going out as often as it did on the 1.9. Removing the blower and replacing wasn’t appealing to me.
    Mdl and pursuit2550[QUOTED] like this.
  5. Apr 29, 2024 at 6:50 AM
    pursuit2550
    I looked at the Whipple but like I said for the price I paid I couldnt think of going another route. I just couldn't see spending close to or over 10k. Maybe if I find a sugar mama, then I will. :D
    Mdl and reywcms[QUOTED] like this.
  6. Apr 29, 2024 at 6:52 AM
    pursuit2550
    I thought you didn't have to remove the blower for the coupler change. Just the snout. How long/miles did you get out of the OEM coupler?
    Mdl and HulkSmurf14 like this.
  7. Apr 29, 2024 at 6:55 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Typically 80-100k miles on a coupler (TVS1900)...or less depending how it came to you (used or new)...you just need to remove a couple things to pop the snout off...water cross-over pipe being one of them...it's not hard and is far easier than installing a fresh supercharger on the Tundra...some have done it within 2 hours...
    Mdl likes this.
  8. Apr 29, 2024 at 6:59 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    IMO (and I have a bigger blower), I don’t think that at the limitations of the stock block that the larger blowers are significantly better than the 1.9. If you go built motor, then you need a larger blower to take advantage of it. I’ve driven 2 trucks with the 1900, and mine with the smaller pulley 2650. Any perceived difference between the two at similar boost levels under 10psi is really just gonna come down to the tune and what pulley or other mods you have. I think our collection of dragy times in the private convo highlights this. The 2650s and whipples are not exactly running away with it. In regards to towing, I definitely prefer the larger blowers over the 1.9 even if the 1.9 has more torque down low simply for the lower IATs and cooler running characteristics in that regard.
    On the coupler note, I’ve seen at least 4 trucks with bad whipple couplers and they haven’t been out that long, and there’s not nearly as many installed. The only blower that seems to have a better coupler track record so far is the Harrop and it’s too soon to say for the Maggie 2650. Just my observations, to take or leave! @Wynnded also went from a 1.9 to a 2650 I believe?
    Mdl, Wynnded, reywcms[QUOTED] and 2 others like this.
  9. Apr 29, 2024 at 7:40 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Mine lasted a year in my use case.
  10. Apr 29, 2024 at 7:47 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    But aint you comoaring the 1900 to a 2.whatever whipple which should be compared to the 2650?
  11. Apr 29, 2024 at 7:52 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Correct I'm comparing the maggy 1.9 to whipple 2.9 since I've owned both.
    At the end of the day the blowers not the limiting factor. The stock block as mentioned above. But from actually owning both and dallying both. There was a noticeable difference.
  12. Apr 29, 2024 at 9:01 AM
    blenton
    blenton New Member
    I have very limited time driving/riding in a factory TRD 1.9 Maggie truck, but compared to my Whipple, @reywcms assessment is spot on. IMO.
    My only regret with the SC is not having done it sooner! From the towing aspect alone, it is a completely different animal. Granted, Whipple took their sweet time coming out with a kit so I’m glad I waited, but seriously, I wish I would have done it sooner.
    HulkSmurf14 and reywcms like this.
  13. Apr 29, 2024 at 9:22 AM
    Silver17
    Eastern PA
    All claims are perceived as a $7k placebo effect until substantiated with a faster dragy time. :p
    Mdl and nobodyintexas like this.
  14. Apr 29, 2024 at 9:34 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    That's how I do it. My zzp coupler has been doing well since 2015. When I had the snout off last year it looked great. As far as I could tell inspecting it.
    HulkSmurf14[QUOTED] likes this.
  15. Apr 29, 2024 at 10:04 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I cobbled mine together for less & can't get dragy to cooperate so my times suck but I do make fur raz boyz cry stoplight to stoplight. (in Mexico)
    lol
    Also, not that anyone cares but I have a PSB 1 lying around & stole its MAP sensor & that was the BMWs problem, boost is now reflecting correctly.
  16. Apr 29, 2024 at 10:19 AM
    blenton
    blenton New Member
    Oh, they will both make more power than the stock block can handle so they can deliver near identical power working within that constraint :) Not trying to step on toes or poo-poo the Maggy. But I chose the Whipple on purpose. And, again, I don't have to try and put down the Maggy or Harrop to feel good about my blower - I'd be smiling either way.
    Mdl and Silver17[QUOTED] like this.
  17. Apr 29, 2024 at 10:23 AM
    e30cabrio
    I wanted the Harrop, it was still unavailable when I was ready & then a sub 1k mile used unit appeared on CL & was 3k so it became a no brainer.
    Silver17 likes this.
  18. Apr 29, 2024 at 10:28 AM
    Silver17
    Eastern PA
    Sometimes I see SCOL offer rebuilt 1900s for $2500 for the blower, but you still need the fit kit items of course. It can definitely be done for less if you’re willing to take the time and be patient. I was neither of those things lol.
  19. Apr 29, 2024 at 10:32 AM
    e30cabrio
    I got everything but some hoses the cooler & pump. Seeing as I wanted the upgraded pump & cooler, that was actually a positive.
  20. Apr 29, 2024 at 11:46 AM
    pursuit2550
    I got lucky and found a brand new kit off eBay from a dodge dealer that had 2 kits for $5300.
    Silver17[QUOTED] likes this.
  21. Apr 29, 2024 at 11:48 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    That's good news, parts in stock is even better. I'm chasing down some AFR issues, or maybe not issues, not sure....anyone here have dual wideband sensors, one in each bank's exhaust? My driver's side is a half ratio to 2 ratios richer than passenger when idling, and low RPM driving. Didn't notice anything when I tried spraying carb cleaner for vacuum leaks, and I'm fairly certain I don't have any exhaust leaks...so it's got me stumped.
    I moved the sensors from the collector to the midpipes...had to use some clamp-on housings since my garage is a disaster and welding would likely result in burning down my house...
    e30cabrio[QUOTED] and Mdl like this.
  22. Apr 29, 2024 at 11:56 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Maybe one injector sticking open? I doubt it would be an exhaust restriction as that would run crappy and usually trigger a mil. Both the new sensors or cleaned up old ones?
    armyoffoo[QUOTED] likes this.
  23. Apr 29, 2024 at 12:01 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Could be an injector issue, since the reading is a combo of the 4 on the bank and it differs from the stock sensor in cylinder 5, I could try swapping some injectors around and see what happens. I'm still running the old sensors, calibration passes for both, so I stuck with them and returned the new ones...I could also swap sensors to see if the same AFR is reported.
  24. Apr 29, 2024 at 12:05 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Man you can have a 100 page thread with all your car issues.
  25. Apr 29, 2024 at 12:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Worth a shot. Clean each sensor can you check voltages going to sensor? Just seeing if they are the same.
  26. Apr 29, 2024 at 12:30 PM
    e30cabrio
    The BMW is a nightmare of vacuum hoses that are everywhere & hidden. I got this to chase down leaks, worked great & worth every penny.
    Order mineral oil it does not have any & vegetable oil made shockingly light smoke
    https://www.amazon.com/gp/product/B0C7MKZPK3?ie=UTF8
  27. Apr 29, 2024 at 12:32 PM
    e30cabrio
    Lots of mods on lots of cars = lots of issues, I'm getting close to seriously done though. (no really)
    lol
    Remember:
    I'm e30cabrio, I'm a modaholic
  28. Apr 29, 2024 at 1:05 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I wouldn't get the PoS Prospeed intake, however, without it I wouldn't have investigated an alternative for my situation.
    I would have gotten gauges to read AFR and Boost from day one and I would have skipped Harrop "Stage 1" altogether.
    I would have gotten the GripPro and a way of dealing with axle twist/wheel hop on day one as well.
    For anyone going for 550+ WHP on nonE85 pump gas get a built engine and valvebody.
    Seeing how the turbo is sipping meth I would probably get a meth kit if the injection points can be integrated into a spacer after the rotors.
    Edit: Oh and I would have switched from 0w20 to 5w30 sooner as well.
    ZPhilip, Mdl, armyoffoo and 1 other person like this.
  29. Apr 29, 2024 at 1:12 PM
    Saltyhero13
    The tune was the big delaying factor from what I remember. Whipple was available when I was in the market (late 2020) but the 2019+ tunes weren't, sadly. They offered a big fat discount at the end of 2020 from what I remember just couldn't run it on a stock map.
    Mdl likes this.
  30. Apr 29, 2024 at 1:25 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Good thinking. @armyoffoo what if you hang the sensors outside the exhaust, or what do they read after it's sat awhile and the truck isn't running? They should read max lean then and at least you'd have a bullet point that they're the same in clean air.
    Fastlane47, e30cabrio and armyoffoo like this.
