General Supercharger Thread
  1. Apr 25, 2024 at 9:15 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    In addition to these I have a Carista, something else for Android devices & about 1/2 dozen stand alone BMW, Audi & VW DONGLES...
    lol
    I have no clue what the internetZ calls a dongle museum, but here is mine:
    Retired (available if someone wants)
    ToyoBaru BR86Z ECU TEK, & OVI Tune
    Current HP Tune, Simon for BMW & Techstream for the Tree.
    Ponderosa_Pine, koditten and AZTundra like this.
  2. Apr 25, 2024 at 10:22 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    What's the best way to do this?
  3. Apr 25, 2024 at 10:38 AM
    AZTundra
    Paul
    Phoenix, AZ
  4. Apr 25, 2024 at 10:41 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    https://www.amazon.com/dp/B08W8KGV6T
    https://deatschwerks.com/collections/all/products/fphwk-10-hd
    I ran the hot wire kit from battery to the canister plug. Spliced it to the pos/neg pump wires. I capped and heat-shrinked the fuel pump pos/neg wires from the fuel pump module.
    I was told there would be no voltage drop doing it this way. I've seen a bus bar stud bulkhead connection installed on top of canister to keep the same gage wire.
    It's on with ignition so you can also install an inertia switch.
  5. Apr 25, 2024 at 10:58 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was lurking on a few posts about coolant bypass for TB and transmission. @Saltyhero13 @Silver17 then led me to Prospeed offering the valve body kit like IPT.
    I plan on doing it with the Transgo kits myself in the future. Watched John at IPT do the valve body. Not too bad of a job.
    What interest me was ProSpeed also using the Transgo kit. Just found it interesting...transgo instructions on the table.
  6. Apr 25, 2024 at 11:12 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    PROSPEED said they were releasing some Tundra transmission related items "Soon" TM but I haven't seen anything. Curious to see what the labor cost will be on the IPTs since we know what the Transgo kits generally go for.
    nobodyintexas likes this.
  7. Apr 25, 2024 at 11:16 AM
    e30cabrio
    No clue about best, but I direct wired to the battery, ran the wire to the pump and used the pump power to energize the solenoid & got a spade kit from the basket to the pump.
    No issues with power since I did it
    ARES35, helidave[QUOTED] and Mdl like this.
  8. Apr 25, 2024 at 11:19 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If I didn't have to prime the system to not cause extended starts this is the way. Thanks for mentioning the fuel pump module power wire used instead of ignition source!
    Edit: aftermarket fpr causing system to not maintain pressure after shutdown.
    helidave and e30cabrio[QUOTED] like this.
  9. Apr 25, 2024 at 11:22 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    really really...what do these shift kits do if they don't fundamentally strengthen the internals?
    do they increase the shift pressure? on the same friction plates that fail if you overload the damn thing?
    I'm asking this from a position of ignorance.
    Mdl and Saltyhero13[QUOTED] like this.
  10. Apr 25, 2024 at 11:28 AM
    e30cabrio
    Spitballing that you become the Mach 5!!!! (maybe go mach 5)???
    And if that were so what would 3836.35 translate to in a 0-60 & 1/4 mile????
    lol
  11. Apr 25, 2024 at 11:31 AM
    Saltyhero13
    From my understanding yes with the transmission as the same failure point. I haven't experienced the shift problems others have but I'm not pushing high power #s that others are on their builds.
    nobodyintexas[QUOTED] likes this.
  12. Apr 25, 2024 at 11:46 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The valve body kits or IPT ones replace accumulators and upgrades valves and plugs that fail causing leakage which leads to clutch slippage. It firms up pressure so you have almost direct engagement with no overlap. This helps eliminate clutch pack slippage reducing burnt packs. When shifting one gear is overlapping another giving you that smooth transition, as I was told. You'll hear people say after a shift kit you get whiplash shifts.
    The kits also upgrade parts that wear preventing torque converter and clutch pack issues.
  13. Apr 25, 2024 at 1:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  14. Apr 25, 2024 at 1:48 PM
    e30cabrio
    At or under 600 HP/TQ the trans is ok? (he asked hopefully) :p
    Mdl likes this.
  15. Apr 25, 2024 at 2:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I toasted one transmission...also.
    Current one has been going strong since 2013. I have the 1970's shift kit as John from IPT calls it. I have metal accumulators in C3,B3 and C2 with limiting rods in each. It prevents shift overlap in 2-3-4 and has direct clutch engagement. A few of us put them in back on tundratalk. John says it doesn't hurt and a built valve body would be more beneficial.
    ARES35 likes this.
  16. Apr 25, 2024 at 2:08 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    All the parts arriving today! Finally have more Magnuson 1900 parts as well as another half dozen 76mm pulleys for the 2650
  17. Apr 25, 2024 at 2:28 PM
    e30cabrio
    Really want to install the Siv pulley, just so not into lifting the SC.
    snivilous[OP] likes this.
  18. Apr 25, 2024 at 2:30 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's pulling the radiator....
    And you'd probably need to update your tune...
    HulkSmurf14, ARES35, Mdl and 2 others like this.
  19. Apr 25, 2024 at 2:32 PM
    e30cabrio
    It's funny you say that, I have a Mishimoto I have not installed yet, I got mired in the BMW motor swap & while I was in there boondoggle that consumed the winter.
  20. Apr 25, 2024 at 2:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    2.0 for 1900 in? I know...just to have!
    Ordered!
    ARES35 and snivilous[QUOTED][OP] like this.
  21. Apr 25, 2024 at 2:39 PM
    koditten
    Kirk
    Midland of the Mitten
    My kit is identical except for the case!
    e30cabrio[QUOTED] likes this.
  22. Apr 25, 2024 at 2:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I only removed idler pulley and crossover to remove snout. Did it 3x's chasing that air leak and snivs modular pulley install.
  23. Apr 25, 2024 at 2:46 PM
    snivilous
    SW UT
    I'll get it shipped out Monday! It'd be tomorrow but currently packing to take the other supercharged toy racing this weekend :D
  24. Apr 25, 2024 at 2:49 PM
    e30cabrio
    Story on that monster transporter?????
  25. Apr 25, 2024 at 2:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No rush as it's a ways out before it will be used. Thanks and have fun!
    snivilous[QUOTED][OP] likes this.
  26. Apr 25, 2024 at 2:52 PM
    snivilous
    SW UT
    It was listed for $9k, and I had already been looking at toter homes and then found out you don't need anything special to buy a semi and register it as a a motorhome :D has sleeping quarters, tons of storage, and will haul everything I own at 80mph while getting the same or better mpg as the tundra :rofl: it is absolutely awesome, and now the tundra can live a life of relaxation and this thing doesn't even know it's loaded with the buggy on it. For the price it was too cheap to not experiment with!
  27. Apr 25, 2024 at 3:18 PM
    e30cabrio
    I just got to it in the buggy thread. lol
    I had not been in there in a while, been reading this entire time, finally got to 2-5 when you introduced the new character in the sniv show!
    :D
  28. Apr 25, 2024 at 3:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The rain today reminds me that I still need to install (buy) a PowerTrax lsd, go AWD and (keep dreaming) of building that forged built 5.7. If other obligations and money didn't get in the way.:rolleyes:
    bflooks, armyoffoo, reywcms and 8 others like this.
  29. Apr 25, 2024 at 3:31 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Still don't have the balls to run the 70mm!...yet. Last I remember @Wynnded is but wonder if anyone else has popped one in the 2650
  30. Apr 25, 2024 at 3:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Chain mail gloves....;)
