General Supercharger Thread
  1. Apr 20, 2024 at 1:38 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No issues here with my AEM units as well
    ARES35, snivilous[OP] and Silver17 like this.
  2. Apr 20, 2024 at 2:13 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I had to look up who that is. I had a clock like this as a kid :p
    ARES35, Fastlane47 and Wynnded like this.
  3. Apr 20, 2024 at 2:30 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Yup, not glamorous, but blends in nicely on the steering column.
  4. Apr 20, 2024 at 3:10 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I like it. I’d consider that if mine takes a dump.
    ARES35, HulkSmurf14 and Mdl like this.
  5. Apr 20, 2024 at 5:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My gauge works fine, it seems to be the sensor that's the issue. Is AEM using one that's different than the one that's paired with the Innovate?
    ARES35 and HulkSmurf14 like this.
  6. Apr 20, 2024 at 6:14 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    My Innovate is working great and has never shown an issue...my fingers are crossed to not jinks myself though...it's been about a year and I think and 7k miles from 0 elevation to 8,000...all good here so far...on 2uzs, I've read, it's imperative to let it sit for 30 second upon startup before rolling or at leat once the SAIP turns off before you drive... I'm following thus logic on the Tundra...
    ARES35, e30cabrio and snivilous[OP] like this.
  7. Apr 20, 2024 at 10:36 PM
    pursuit2550
    pursuit2550 New Member
    Got my SC in today and started installing the heat exchanger and pump for now. I got to looking at the Magnuson tune install instructions and it says to make sure you truck has the latest stock ECM software/tune before you install the Magnuson Tune. Is there a way to check with a regular scan tool and a way to know what is the latest software update?
    reywcms and ARES35 like this.
  8. Apr 21, 2024 at 6:32 AM
    JustDSM
    JustDSM New Member
    Justin
    Most handheld scanners will report the Calibration ID. You can determine if your ID is the latest by reviewing the TSB documents for the various updates that have occurred.
    Post your Cal ID and I’ll let you know what the most current ID is for your ECU.
    Wynnded likes this.
  9. Apr 21, 2024 at 6:48 AM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Running Innovative also. Only issue thus far is AFR showing dash lines once in a while. I just press both buttons for the menu and let it sit. It always reverts back displaying AF after:notsure:
    Wynnded likes this.
  10. Apr 21, 2024 at 6:51 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Does it read "O2 HEATER" in the upper right hand corner when this happens?
    ARES35[QUOTED] likes this.
  11. Apr 21, 2024 at 6:54 AM
    ARES35
    Mile high
    Yes sir it does. I used to restart the truck but going into the menu and back usually clears up the issue. I take it as a nuisance.
    Wynnded[QUOTED] likes this.
  12. Apr 21, 2024 at 6:55 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Computer came Friday. Forgot about the compressor.
    bflooks, reywcms and ARES35 like this.
  13. Apr 21, 2024 at 6:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hmm, I've just assumed that this meant that there was an issue with the heater circuit in the sensor itself, I'll have to give your idea a try and see how mine responds.
    e30cabrio and ARES35[QUOTED] like this.
  14. Apr 21, 2024 at 6:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ew ya, that's kind of in the way huh...
    Mdl, e30cabrio[QUOTED] and ARES35 like this.
  15. Apr 21, 2024 at 6:59 AM
    ARES35
    Mile high
    I was getting tired datlogging and having to restart the truck at lights, etc. Tried that and it always clears out. Annoying but it works for me.
  16. Apr 21, 2024 at 7:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've just been leaving it alone to come back on it's own, I'll have to get out for a Sunday drive today.
  17. Apr 21, 2024 at 7:02 AM
    ARES35
    Mile high
    Please update for I was wondering if my weird method was a fluke lol
  18. Apr 21, 2024 at 7:04 AM
    e30cabrio
    Only totally.
    lol
  19. Apr 21, 2024 at 7:15 AM
    ARES35
    Mile high
    Guys with FFV keep an eye on you Eth content! I had reset density a few months ago and noticed it was back up in the 20's. Power enrich A/F was wandering while messing with timing so thought MAF table needed re-adjustment, although odd I thought. Saw 20%, reset and now back at in the 10's
    Mdl, helidave and e30cabrio like this.
  20. Apr 21, 2024 at 7:17 AM
    e30cabrio
    This is why I'm swapping a non flex ECU.
  21. Apr 21, 2024 at 7:20 AM
    ARES35
    Mile high
    Good call FFV is annoying and makes tuning a bitch......nows it in my process to always watch eth den......wish there was a way to clear out the ECU calculating from the fuel pump sensor but I haven't seen a way when searching:facepalm:
  22. Apr 21, 2024 at 7:44 AM
    e30cabrio
    I'm sick of having to drive around with my computer to reset the damn thing.
    I have the obstacles out of the way & the small bottom harness off HOW THE HELL do I get the big, upper one off???
  23. Apr 21, 2024 at 8:10 AM
    e30cabrio
    Non flex is in, damn that fucker was married to the truck. Had to pry it from under the dash to push it out.
    The tab on top that needed to pull up the rails on both sides broke, I had to individually pry them.
    Toyota could take a lesson from BMW on ECU placement, the one in my Z3 has a sealed with a gasket compartment that is easily accessible & one big old telecom like connector that is secure but comes off easily when unlatched.
  24. Apr 21, 2024 at 8:16 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Both the levers on mine broke too after about the 5th time I had my ecu out. Luckily you can push those side pieces down by hand and they'll still lock up solid. I wasn't able to find a replacement for just the grey lever and pivot
    Mdl, e30cabrio and Wynnded like this.
  25. Apr 21, 2024 at 8:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, they're a "good time". You might try opening the actual ECU some time, boy howdy!
    Mdl and helidave like this.
  26. Apr 21, 2024 at 9:44 AM
    e30cabrio
    Got it in, wrote my tune (thanks for the deal on credits JustDSM) no luck on the key "just working" of course) jumped pin 4 & 13 which I found online as how people have reset the immobilizer, but they have Xmas tree lights & I just have 4HI so tried in TS but it says my keys are registered. (oddly after I do that process, it starts for a second once)
    Leaving the pins jumped for 30 minutes & hoping that does it
  27. Apr 21, 2024 at 9:49 AM
    VWTim
    Corvallis, OR
    Do you have to erase other keys for there to be room to add more? The immobilizer on my wife's LS430 was like that. Had to delete a key to be able to add another.
    M3Tundra-JK and Mdl like this.
  28. Apr 21, 2024 at 9:58 AM
    e30cabrio
    Not sure. I found another video jumping 4&12 and now have the Xmas tree. Hopefully at 10:30 it will start
    M3Tundra-JK and VWTim like this.
  29. Apr 21, 2024 at 10:55 AM
    e30cabrio
    30 minutes nope, unregistered all but the master in TS, registered all (4 keys) nope.
    Looking for a solution :(
  30. Apr 21, 2024 at 11:06 AM
    helidave
    flagstaff
    2015 DC 4x4
    You sure it's the immobilizer and not something else? Any codes?
